J’ai plus d’info en passant le niveau de log à “secure” dans /etc/mpd.conf
Dec 05 14:41 : mad: mp3 file header indicates too many frames: 75329116
Dec 05 14:41 : mad: input/Input does not appear to be a mp3 bit stream
Dec 05 14:41 : ffmpeg/mp3: Estimating duration from bitrate, this may be inaccurate
Dec 05 14:41 : ffmpeg/mp3: incomplete frame
Dec 05 14:41 : ffmpeg: decoding failed, frame skipped
Dec 05 14:41 : player: played "http://adwzg3.tdf-cdn.com/8474/nrj_177978.mp3"
J’ai aussi trouvé ça sur un autre forum
volumio.org/forum/web-radio-str … t2587.html
[quote]Hi,
I had the problem with another radio stream: mp3.live.tv-radio.com/fip/all/fiphautdebit.mp3
It did not work with the default installed MPD version in Volumio 1.51 (I cannot recall which one, some 0.18.x I think).
Volumio 1.55 has MPD in version 0.19.1, and the problem with some radio streams still exists. An update of MPD to the 0.19.9 solved the problem for me.
–flokk[/quote]
j’ai installé la version presente dans les backports
# apt-cache policy mpd
mpd:
Installé : 0.19.9-2~bpo8+1
Candidat : 0.19.9-2~bpo8+1
Table de version :
*** 0.19.9-2~bpo8+1 0
100 http://ftp.debian.org/debian/ jessie-backports/main amd64 Packages
100 /var/lib/dpkg/status
0.19.1-1.1 0
500 http://ftp.fr.debian.org/debian/ jessie/main amd64 Packages
Et la Bingo
PS: Reste plus qu’a trouver comment avoir le controle du volume dans le client
