Mt-daapd (firefly) aucune chanson scannée
J’ai installé mt-daapd sur mon petit serveur (sheevaplug) pour pouvoir partager ma bibliotheque. Mais lorsque j’essaie de scanner, il ne trouve aucune chanson.
C’etait d’abord sur un disque dur externe, alors j’ai testé en mettant une chanson dans /home/mwoua/music/ et toujours rien de scanné, sachant que /home/mwoua/music et en droit 666.
Quelqu’un a une idée?
Mon fichier de config si ca peut aider
[code]# $Id: mt-daapd.conf.templ 1660 2007-09-12 13:08:04Z rpedde $
This is the mt-daapd config file.
If you have problems or questions with the format of this file,
direct your questions to rpedde@users.sourceforge.net.
Questions and discussions about the format and content of this
config file can probably be obtained by consulting the wiki:
http://wiki.fireflymediaserver.org/Config_File
Or by asking questions on the forums at
http://forums.fireflymediaserver.org
[general]
web_root (required)
Location of the admin web pages.
If you installed from .RPM, .deb, or tarball with --prefix=/usr, then
this is correct.
If you installed from tarball without --prefix=/usr, then the correct
path is probably /usr/local/share/mt-daapd/admin-root.
web_root = /usr/share/mt-daapd/admin-root
port (required)
What port to listen on. It is possible to use a different
port, but this is the default iTunes port
port = 3689
admin_pw (required)
This is the password to the administrative pages
admin_pw = *****
db_type (required)
This is what kind of backend database to store the song
info in. Valid choices are “sqlite” and “sqlite3”.
db_type = sqlite3
db_parms
This is any extra information the db needs to connect.
in the case of sqlite and sqlite3, this is the name
of the directory to store the database in
If you installed from RPM or .deb, this path likely already
exists. If not, then you must create it. The directory itself
must be writable by the “runas” user.
db_parms = /var/cache/mt-daapd
mp3_dir (required)
Location of the mp3 files to share. Note that because the
files are stored in the database by inode, these must be
in the same physical filesystem.
#mp3_dir = /mnt/freebox/Musiques/
mp3_dir = /home/mwoua/music/
servername (required)
This is both the name of the server as advertised
via rendezvous, and the name of the database
exported via DAAP. Also know as “What shows up in iTunes”.
servername = Firefly Mwoua
runas (required)
This is the user to drop privs to if running as
root. If mt-daapd is not started as root, this
configuration option is ignored. Notice that this
must be specified whether the server is running
as root or not.
This is also ignored on Windows.
runas = mt-daapd
password (optional)
This is the password required to listen to MP3 files
i.e. the password that iTunes prompts for
#password = mp3
extensions (optional)
These are the file extensions that the daap server will
try to index and serve. By default, it only indexes and
serves .mp3 files. It can also server .m4a and .m4p files,
and just about any other files, really. Unfortunately, while
it can attempt to serve other files (.ogg?), iTunes won’t
play them. Perhaps this would be useful on Linux with
Rhythmbox, once it understands daap. (hurry up!)
Failing that, one can use server-side conversion to transcode
non-standard (.ogg, .flac) music to wav on the server side.
See the ssc_* options below.
To be able to index .ogg files, you’ll need to have configured
with --enable-oggvorbis. For .flac, --enable-flac, for .mpc,
–enable-musepack.
extensions = .mp3,.ogg,.flac
ssc_codectypes (optional)
List of codectypes for files that the daap server should
perform internal format conversion and present to clients
as WAV files. The file extensions that these codectypes correspond
to must also be present in ‘extensions’
configuration value, or files are not probed in the first
place.
Valid codectypes:
mp4a - for AAC (.aac, .mp4, .m4a, .m4p)
mpeg - for mp3
wav - for wav
wma - for wma
ogg - for ogg
flac - for flac (.flac, .fla)
mpc for musepack (.mpc, .mpp, .mp+)
alac for alac (.m4a)
Not needed because ffmpeg is enabled (all file types transcoded to wav.
If this behavior is undesired, see the [plugins] section and disable it,
or selectively disable codecs below with the never_transcode option.)
-joshk
ssc_codectypes = ogg,flac,alac
never_transcode (optional)
Comma separated list of formats to never transcode. (Nothing by default)
never_transcode = ogg
ssc_prog (optional)
Program that is used in server side format conversion.
Program must accept following command line syntax:
ssc_prog filename offset length …
Parameter filename is the real name of the file that is
to be converted and streamed, offset is number of bytes
that are skipped from the beginning of the output file
before streaming is started, length is length of the song
in seconds (or zero). All other possible arguments must
be ignored. The resulting wav file (or the rest of
the file after initial seek) is written to the standard
output by the ssc_prog program. This is typically
a script that is a front end for different conversion tools
handling different formats.
ssc_prog = /usr/bin/mt-daapd-ssc.sh
logfile (optional)
This is the file to log to. If this is not configured,
then it will log to the syslog.
Not that the -d switch will control the log verbosity.
By default, it runs at log level 1. Log level 9 will churn
out scads of useless debugging information. Values in between
will vary the amount of logging you get. However, you must log
to a file to see this debugging information (debug information will
not appear in syslog.)
#logfile = /var/log/mt-daapd.log
rescan_interval
How often to check the file system to see if any mp3 files
have been added or removed.
if not specified, the default is 0, which disables background scanning.
If background rescanning is disabled, a scan can still be forced from the
“status” page of the administrative web interface
Setting a rescan_interval lower than the time it takes to rescan
won’t hurt anything, it will just waste CPU, and make connect times
to the daap server longer.
#rescan_interval = 300
always_scan
The default behavior is not not do background rescans of the
filesystem unless there are clients connected. The thought is to
allow the drives to spin down unless they are in use. This might be
of more importance in IDE drives that aren’t designed to be run
24x7. Forcing a scan through the web interface will always work
though, even if no users are connected.
always_scan = 0
scan_type
This sets how aggressively mp3 files should be scanned to determine
file length. There are three values:
0 (Normal)
Just scan the first mp3 frame to try and calculate size. This will
be accurate for most files, but VBR files without an Xing tag will
probably have wildly inaccurate file times. This is the default.
1 (Aggressive)
This checks the bitrates of 10 frames in the middle of the song.
This will still be inaccurate for VBR files without an Xing tag,
but they probably won’t be quite as inaccurate as 0. This takes
more time, obviously, although the time hit will only happen the
first time you scan a particular file.
2 (Painfully aggressive)
This walks through the entire song, counting the number of frames.
This should result in accurate song times, but will take the most
time. Again, this will only have to be incurred the first time
the file is indexed.
scan_type = 2
password = ****
logfile = /var/log/mtdaapd
debuglevel = 4
compress
Whether to use gzip content-encoding when transferring playlists etc.
This was contributed as a patch by Ciamac Moallemi just prior to the 0.2.1
release, and as such, hasn’t gotten as much testing as other features.
This feature should substantially speed up transfers of large databases
and playlists.
It will eventually default to 1, but currently it defaults to 0.
#compress = 0
[plugins]
plugin_dir = /usr/lib/mt-daapd/plugins
plugins = rsp.so,ssc-ffmpeg.so
[scanning]
should playlists be processed at all?
process_playlists = 1
should itunes xml files be processed?
process_itunes = 1
should m3u files be processed?
process_m3u = 1[/code]
edit : dans mes logs j’ai des erreurs
2012-04-03 17:35:36 (4136b000): Firefly Version svn-1696: Starting with debuglevel 4 2012-04-03 17:35:36 (4136b000): Error loading plugin /usr/lib/mt-daapd/plugins/ssc-script.so: plugin declined to load 2012-04-03 17:35:36 (4136b000): Plugin loaded: ssc-ffmpeg/svn-1696 2012-04-03 17:35:36 (4136b000): Plugin loaded: rsp/svn-1696 2012-04-03 17:35:36 (4136b000): Plugin loaded: daap/svn-1696 2012-04-03 17:35:36 (4136b000): Starting signal handler 2012-04-03 17:35:36 (4136b000): Starting rendezvous daemon 2012-04-03 17:35:36 (4136b000): Client running 2012-04-03 17:35:36 (4136b000): Initializing database 2012-04-03 17:35:36 (4136b000): Full reload... 2012-04-03 17:35:37 (4136b000): Starting mp3 scan 2012-04-03 17:35:37 (4136b000): Starting playlist scan 2012-04-03 17:35:37 (4136b000): Updating playlists 2012-04-03 17:35:37 (4136b000): Scanned 0 songs in 0 seconds 2012-04-03 17:35:37 (4136b000): Starting web server from /usr/share/mt-daapd/admin-root on port 3689 2012-04-03 17:35:37 (4136b000): Registering rendezvous names 2012-04-03 17:35:37 (4136b000): Serving 0 songs. Startup complete in 0 seconds 2012-04-03 17:35:43 (42c0f460): Thread 0: Entering ws_returnerror (401: Unauthorized) 2012-04-03 17:35:44 (42c0f460): Thread 1: Entering ws_returnerror (302: Moved) 2012-04-03 17:35:44 (434ff460): Cannot resolve /usr/share/mt-daapd/admin-root//favicon.ico 2012-04-03 17:35:44 (434ff460): Thread 13: Entering ws_returnerror (404: Not found) 2012-04-03 17:35:44 (434ff460): Cannot resolve /usr/share/mt-daapd/admin-root//favicon.ico 2012-04-03 17:35:44 (434ff460): Thread 14: Entering ws_returnerror (404: Not found) 2012-04-03 17:35:44 (434ff460): Cannot resolve /usr/share/mt-daapd/admin-root//favicon.ico 2012-04-03 17:35:44 (434ff460): Thread 15: Entering ws_returnerror (404: Not found) 2012-04-03 17:35:53 (4136b000): Rescanning database 2012-04-03 17:35:53 (4136b000): Starting playlist scan 2012-04-03 17:35:53 (4136b000): Updating playlists 2012-04-03 17:35:53 (4136b000): Scanned 0 songs (was 0) in 0 seconds
