Bien le bonjour tout le monde,
Je suis en train de refaire mon serveur pour le passer sous Debian 8 et la j’ai un petit blocage avec munin.
D’après ce que j’ai pu voir avec le passage a Apache 2.4 il y aurait quelques changement notamment
Qui remplacerait
Order allow, deny
Allow from all
Voila à quoi ressemble le fichier apache.conf qui se trouve dans /etc/munin/
[code]# Enable this for template generation
Alias /munin /var/cache/munin/www
Enable this for cgi-based templates
#Alias /munin-cgi/static /var/cache/munin/www/static
#ScriptAlias /munin-cgi /usr/lib/munin/cgi/munin-cgi-html
#<Location /munin-cgi>
Order allow,deny
Allow from localhost 127.0.0.0/8 ::1
AuthUserFile /etc/munin/munin-htpasswd
AuthName “Munin”
AuthType Basic
require valid-user
<Directory /var/cache/munin/www>
Require ip 192.168.1.0/24
# This file can be used as a .htaccess file, or a part of your apache
# config file.
# For the .htaccess file option to work the munin www directory
# (/var/cache/munin/www) must have "AllowOverride all" or something
# close to that set.
# AuthUserFile /etc/munin/munin-htpasswd
# AuthName "Munin"
# AuthType Basic
# require valid-user
# This next part requires mod_expires to be enabled.
# Set the default expiration time for files to 5 minutes 10 seconds from
# their creation (modification) time. There are probably new files by
# that time.
ExpiresActive On
ExpiresDefault M310
Enables fastcgi for munin-cgi-html if present
SetHandler fastcgi-script
#<Location /munin-cgi/static>
SetHandler None
Enables fastcgi for munin-cgi-graph if present
ScriptAlias /munin-cgi/munin-cgi-graph /usr/lib/munin/cgi/munin-cgi-graph
<Location /munin-cgi/munin-cgi-graph>
# AuthName "Munin"
# AuthType Basic
<IfModule mod_fastcgi.c>
</IfModule>
ScriptAlias /munin-cgi/munin-cgi-html /usr/lib/munin/cgi/munin-cgi-html
<Location /munin-cgi/munin-cgi-html>
# AuthName "Munin"
# AuthType Basic
</IfModule>
Dans /var/www/html il y a un lien pour munin
root@www2:/etc/munin# ls -l /var/www/html/
total 12
-rw-r--r-- 1 root root 11104 juil. 15 02:18 index.html
lrwxrwxrwx 1 root root 20 juil. 15 03:40 munin -> /var/cache/munin/www
Et au niveau des droits des fichiers :
root@www2:/etc/munin# ls -l /var/cache/munin/www
total 256
-rw-r--r-- 1 munin munin 17482 juil. 15 03:55 disk-day.html
-rw-r--r-- 1 munin munin 17522 juil. 15 03:55 disk-month.html
-rw-r--r-- 1 munin munin 17502 juil. 15 03:55 disk-week.html
-rw-r--r-- 1 munin munin 17502 juil. 15 03:55 disk-year.html
-rw-r--r-- 1 munin munin 4270 juil. 15 03:55 exim-day.html
-rw-r--r-- 1 munin munin 4274 juil. 15 03:55 exim-month.html
-rw-r--r-- 1 munin munin 4272 juil. 15 03:55 exim-week.html
-rw-r--r-- 1 munin munin 4272 juil. 15 03:55 exim-year.html
-rw-r--r-- 1 munin munin 3779 juil. 15 03:55 index.html
drwxr-xr-x 3 munin munin 4096 juil. 15 02:20 localdomain
-rw-r--r-- 1 munin munin 3593 juil. 15 03:55 munin-day.html
-rw-r--r-- 1 munin munin 3595 juil. 15 03:55 munin-month.html
-rw-r--r-- 1 munin munin 3594 juil. 15 03:55 munin-week.html
-rw-r--r-- 1 munin munin 3594 juil. 15 03:55 munin-year.html
-rw-r--r-- 1 munin munin 6900 juil. 15 03:55 network-day.html
-rw-r--r-- 1 munin munin 6912 juil. 15 03:55 network-month.html
-rw-r--r-- 1 munin munin 6906 juil. 15 03:55 network-week.html
-rw-r--r-- 1 munin munin 6906 juil. 15 03:55 network-year.html
-rw-r--r-- 1 munin munin 3254 juil. 15 03:55 problems.html
-rw-r--r-- 1 munin munin 6121 juil. 15 03:55 processes-day.html
-rw-r--r-- 1 munin munin 6131 juil. 15 03:55 processes-month.html
-rw-r--r-- 1 munin munin 6126 juil. 15 03:55 processes-week.html
-rw-r--r-- 1 munin munin 6126 juil. 15 03:55 processes-year.html
drwxr-xr-x 2 munin munin 4096 juil. 15 02:20 static
-rw-r--r-- 1 munin munin 10117 juil. 15 03:55 system-day.html
-rw-r--r-- 1 munin munin 10139 juil. 15 03:55 system-month.html
-rw-r--r-- 1 munin munin 10128 juil. 15 03:55 system-week.html
-rw-r--r-- 1 munin munin 10128 juil. 15 03:55 system-year.html
Quelqu’un aurait une petite idée sur le sujet ?
