J’ai un problème avec la configuration de Mysql-Server.5.5.33.
J’ai suivi le tutoriel d’Alsacréations sur l’installation et la configuration de ce dernier.
J’ai effectué exactement les même modifications que sur le tutoriel mais mysql ne veux plus redémarrer.
[code]nano /etc/mysql/my.cnf
The MySQL database server configuration file.
You can copy this to one of:
- “/etc/mysql/my.cnf” to set global options,
- “~/.my.cnf” to set user-specific options.
One can use all long options that the program supports.
Run program with --help to get a list of available options and with
–print-defaults to see which it would actually understand and use.
For explanations see
http://dev.mysql.com/doc/mysql/en/server-system-variables.html
This will be passed to all mysql clients
It has been reported that passwords should be enclosed with ticks/quotes
escpecially if they contain “#” chars…
Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
default-character-set = utf8
Here is entries for some specific programs
The following values assume you have at least 32M ram
This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
* Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
default-collation = utf8_general_ci
skip-external-locking
Instead of skip-networking the default is now to listen only on
localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
* Fine Tuning
key_buffer = 32M
max_allowed_packet = 16M
thread_stack = 192K
thread_cache_size = 8
This replaces the startup script and checks MyISAM tables if needed
the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
* Query Cache Configuration
query_cache_limit = 2M
query_cache_size = 32M
* Logging and Replication
Both location gets rotated by the cronjob.
Be aware that this log type is a performance killer.
As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
Here you can see queries with especially long duration
log_slow_queries = /var/log/mysql/mysql-slow.log
long_query_time = 2
#log-queries-not-using-indexes
The following can be used as easy to replay backup logs or for replication.
note: if you are setting up a replication slave, see README.Debian about
other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
#expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
* InnoDB
InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
Read the manual for more InnoDB related options. There are many!
* Security Features
Read the manual, too, if you want chroot!
chroot = /var/lib/mysql/
For generating SSL certificates I recommend the OpenSSL GUI “tinyca”.
ssl-ca=/etc/mysql/cacert.pem
ssl-cert=/etc/mysql/server-cert.pem
ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
* IMPORTANT: Additional settings that can override those from this file!
The files must end with ‘.cnf’, otherwise they’ll be ignored.
!includedir /etc/mysql/conf.d/
language = /usr/share/mysql/french[/code]
Les derniers logs de mysql :
[code]cat /var/log/syslog | grep mysql
Dec 29 17:18:00 lisa /etc/init.d/mysql[10237]: 0 processes alive and ‘/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping’ resulted in
Dec 29 17:18:00 lisa /etc/init.d/mysql[10237]: #007/usr/bin/mysqladmin: connect to server at ‘localhost’ failed
Dec 29 17:18:00 lisa /etc/init.d/mysql[10237]: error: ‘Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)‘
Dec 29 17:18:00 lisa /etc/init.d/mysql[10237]: Check that mysqld is running and that the socket: ‘/var/run/mysqld/mysqld.sock’ exists!
Dec 29 17:19:13 lisa mysqld_safe: Starting mysqld daemon with databases from /var/lib/mysql
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 [Warning] The syntax ‘–log-slow-queries’ is deprecated and will be removed in a future release. Please use ‘–slow-query-log’/’–slow-query-log-file’ instead.
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 [Note] Plugin ‘FEDERATED’ is disabled.
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: The InnoDB memory heap is disabled
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Mutexes and rw_locks use GCC atomic builtins
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Compressed tables use zlib 1.2.7
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Using Linux native AIO
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Initializing buffer pool, size = 128.0M
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Completed initialization of buffer pool
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: highest supported file format is Barracuda.
Dec 29 17:19:13 lisa mysqld: 131229 17:19:13 InnoDB: Waiting for the background threads to start
Dec 29 17:19:14 lisa mysqld: 131229 17:19:14 InnoDB: 5.5.33 started; log sequence number 1595685
Dec 29 17:19:14 lisa mysqld: 131229 17:19:14 [ERROR] /usr/sbin/mysqld: unknown variable 'default-character-set=utf8’
Dec 29 17:19:14 lisa mysqld: 131229 17:19:14 [ERROR] Aborting
Dec 29 17:19:14 lisa mysqld: 131229 17:19:14 InnoDB: Starting shutdown…
Dec 29 17:19:15 lisa mysqld: 131229 17:19:15 InnoDB: Shutdown completed; log sequence number 1595685
Dec 29 17:19:15 lisa mysqld: 131229 17:19:15 [Note] /usr/sbin/mysqld: Shutdown complete
Dec 29 17:19:15 lisa mysqld_safe: mysqld from pid file /var/run/mysqld/mysqld.pid ended
Dec 29 17:19:27 lisa /etc/init.d/mysql[10994]: 0 processes alive and ‘/usr/bin/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping’ resulted in
Dec 29 17:19:27 lisa /etc/init.d/mysql[10994]: #007/usr/bin/mysqladmin: connect to server at ‘localhost’ failed
Dec 29 17:19:27 lisa /etc/init.d/mysql[10994]: error: 'Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)'
Dec 29 17:19:27 lisa /etc/init.d/mysql[10994]: Check that mysqld is running and that the socket: ‘/var/run/mysqld/mysqld.sock’ exists![/code]
Comment puis-je régler ce problème génant ?
Merci beaucoup
Cordialement
