j’ai bien commenter la ligne, redemarrer le serveur mysql, mais mon problème reste toujours le même.
A la moindre commande mysql, avec le bon mots de pass.
“ERROR 1045 (28000): Access denied for user ‘root’@‘localhost’ (using password: YES)”
merci de votre aide. Si vous avez d’autre suggestion ^^.
En tant normal, j’aurais reformater pour partir sur des bases saines. Mais sur dedié, c’est pas aussi simple.
Edit:
Parceque des configuration vaus mieux qu’un message d’erreur:
[code]
The MySQL database server configuration file.
You can copy this to one of:
- “/etc/mysql/my.cnf” to set global options,
- “~/.my.cnf” to set user-specific options.
One can use all long options that the program supports.
Run program with --help to get a list of available options and with
–print-defaults to see which it would actually understand and use.
For explanations see
This will be passed to all mysql clients
It has been reported that passwords should be enclosed with ticks/quotes
escpecially if they contain “#” chars…
Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
Here is entries for some specific programs
The following values assume you have at least 32M ram
This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
* Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
Instead of skip-networking the default is now to listen only on
localhost which is more compatible and is not less secure.
#bind-address = 127.0.0.1
* Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 192K
thread_cache_size = 8
This replaces the startup script and checks MyISAM tables if needed
the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
* Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
* Logging and Replication
Both location gets rotated by the cronjob.
Be aware that this log type is a performance killer.
As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
The following can be used as easy to replay backup logs or for replication.
note: if you are setting up a replication slave, see README.Debian about
other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
* InnoDB
InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
Read the manual for more InnoDB related options. There are many!
* Security Features
Read the manual, too, if you want chroot!
chroot = /var/lib/mysql/
For generating SSL certificates I recommend the OpenSSL GUI “tinyca”.
ssl-ca=/etc/mysql/cacert.pem
ssl-cert=/etc/mysql/server-cert.pem
ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
* IMPORTANT: Additional settings that can override those from this file!
The files must end with ‘.cnf’, otherwise they’ll be ignored.
!includedir /etc/mysql/conf.d/[/code]
