J’ai la même erreur grrr que je lance avec putty avec password ou avec un navigateur internet pour configurer le log ocsreports celà m’affiche cette erreur =/. Si tout ce charabia peut vous aider alors je vous le met j’ai trouvé ça dans syslog
“May 25 13:32:17 localhost mysqld[2341]: 070525 13:32:17 InnoDB: Started; log sequence number 0 43655
May 25 13:32:17 localhost mysqld[2341]: 070525 13:32:17 [Note] /usr/sbin/mysqld: ready for connections.
May 25 13:32:17 localhost mysqld[2341]: Version: ‘5.0.32-Debian_7etch1-log’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 Debian etch distribution
May 25 13:32:18 localhost /etc/mysql/debian-start[2381]: Upgrading MySQL tables if necessary.
May 25 13:32:19 localhost /etc/mysql/debian-start[2387]: Checking for crashed MySQL tables.
May 25 13:39:01 localhost /USR/SBIN/CRON[2398]: (root) CMD ( [ -d /var/lib/php4 ] && find /var/lib/php4/ -type f -cmin +$(/usr/lib/php4/maxlifetime) -print0 | xargs -r -0 rm)
May 25 13:39:01 localhost /USR/SBIN/CRON[2399]: (root) CMD ( [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
May 25 13:40:16 localhost mysqld[2341]: 070525 13:40:16 [Note] /usr/sbin/mysqld: Normal shutdown
May 25 13:40:16 localhost mysqld[2341]: 070525 13:40:16 InnoDB: Starting shutdown…
May 25 13:40:19 localhost mysqld[2341]: 070525 13:40:19 InnoDB: Shutdown completed; log sequence number 0 43655
May 25 13:40:19 localhost mysqld[2341]: 070525 13:40:19 [Note] /usr/sbin/mysqld: Shutdown complete
May 25 13:40:19 localhost mysqld_safe[2437]: ended
May 25 13:40:47 localhost mysqld_safe[2491]: started
May 25 13:40:47 localhost mysqld[2494]: 070525 13:40:47 InnoDB: Started; log sequence number 0 43655
May 25 13:40:47 localhost mysqld[2494]: 070525 13:40:47 [Note] /usr/sbin/mysqld: ready for connections.
May 25 13:40:47 localhost mysqld[2494]: Version: ‘5.0.32-Debian_7etch1-log’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 0 Debian etch distribution
May 25 13:44:51 localhost mysqld[2494]: 070525 13:44:51 [Note] /usr/sbin/mysqld: Normal shutdown
May 25 13:44:51 localhost mysqld[2494]: 070525 13:44:51 InnoDB: Starting shutdown…
May 25 13:44:53 localhost mysqld[2494]: 070525 13:44:53 InnoDB: Shutdown completed; log sequence number 0 43655
May 25 13:44:53 localhost mysqld[2494]: 070525 13:44:53 [Note] /usr/sbin/mysqld: Shutdown complete
May 25 13:44:53 localhost mysqld_safe[2526]: ended
May 25 14:07:44 localhost mysqld_safe[2754]: started
May 25 14:07:44 localhost mysqld[2757]: 070525 14:07:44 InnoDB: Started; log sequence number 0 43655
May 25 14:07:44 localhost mysqld[2757]: 070525 14:07:44 [Note] /usr/sbin/mysqld: ready for connections.
May 25 14:07:44 localhost mysqld[2757]: Version: ‘5.0.32-Debian_7etch1-log’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 Debian etch distribution
May 25 14:07:45 localhost /etc/mysql/debian-start[2797]: Upgrading MySQL tables if necessary.
May 25 14:07:46 localhost /etc/mysql/debian-start[2803]: Checking for crashed MySQL tables.
May 25 14:09:01 localhost /USR/SBIN/CRON[2820]: (root) CMD ( [ -d /var/lib/php4 ] && find /var/lib/php4/ -type f -cmin +$(/usr/lib/php4/maxlifetime) -print0 | xargs -r -0 rm)
May 25 14:09:01 localhost /USR/SBIN/CRON[2821]: (root) CMD ( [ -d /var/lib/php5 ] && find /var/lib/php5/ -type f -cmin +$(/usr/lib/php5/maxlifetime) -print0 | xargs -r -0 rm)
edit: En fait ce log va avec cette erreur là:
ERROR: Can’t connect to MySql. Please enter a valid login/pass. (host=localhost name=root pass=root)
Mysql error: Access denied for user ‘root’@‘localhost’ (using password: YES)
l’autre a disparue je sais pas pourquoi (l’autre erreur)
