j’ai fait le changement : copie de debian.cnf de la sid vers jessie en gardant toute l’arborescence de la sid (/var/lib/mysql/) mais le
problème est le même qu’avant.
root@vorenus:/etc/mysql# mysqld
150717 18:19:57 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
150717 18:19:57 [Note] mysqld (mysqld 5.5.43-0+deb8u1) starting as process 23445 ...
root@vorenus:/etc/mysql# systemctl status mysql.service
● mysql.service - LSB: Start and stop the mysql database server daemon
Loaded: loaded (/etc/init.d/mysql)
Active: failed (Result: exit-code) since ven. 2015-07-17 18:19:20 CEST; 3min 16s ago
Process: 20123 ExecStop=/etc/init.d/mysql stop (code=exited, status=0/SUCCESS)
Process: 22694 ExecStart=/etc/init.d/mysql start (code=exited, status=1/FAILURE)
juil. 17 18:19:20 vorenus mysql[22694]: Starting MySQL database server: mysq...!
juil. 17 18:19:20 vorenus systemd[1]: mysql.service: control process exited...=1
juil. 17 18:19:20 vorenus systemd[1]: Failed to start LSB: Start and stop t...n.
juil. 17 18:19:20 vorenus systemd[1]: Unit mysql.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
root@vorenus:/etc/mysql# journalctl -xn
-- Logs begin at ven. 2015-07-17 08:47:45 CEST, end at ven. 2015-07-17 18:19:20
juil. 17 18:17:01 vorenus CRON[22635]: pam_unix(cron:session): session closed fo
juil. 17 18:19:20 vorenus /etc/init.d/mysql[23423]: 0 processes alive and '/usr/
juil. 17 18:19:20 vorenus /etc/init.d/mysql[23423]: [61B blob data]
juil. 17 18:19:20 vorenus /etc/init.d/mysql[23423]: error: 'Can't connect to loc
juil. 17 18:19:20 vorenus /etc/init.d/mysql[23423]: Check that mysqld is running
juil. 17 18:19:20 vorenus mysql[22694]: Starting MySQL database server: mysqld .
juil. 17 18:19:20 vorenus systemd[1]: mysql.service: control process exited, cod
juil. 17 18:19:20 vorenus systemd[1]: Failed to start LSB: Start and stop the my
-- Subject: L'unité (unit) mysql.service a échoué
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- L'unité (unit) mysql.service a échoué, avec le résultat failed.
lines 1-16/16 (END)
