Mythtv : video qui sacade [Résolu]
tout est dans le titre, lorsque je regarde un DVD ou la TV(tuner analogique), la vidéo saccade. Quand je fais un top, je vois que mes ressources(Memoires et CPU) sont bien.
C’est une debian Etch avec xserver-xorg nvidia-kernel-common nvidia-kernel-2.6.18-6-i386.
Ma config est :
athlon XP 2500
carte mère ABIT NF7-S
Carte video Nvidia 6200
Merci d’avance.
peut-on avoir le contenu de /etc/X11/xorg.conf ?
voici mon xorg.conf
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Device"
Identifier "Carte vidéo générique"
Driver "vesa"
BusID "PCI:2:0:0"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-64
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte vidéo générique"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1280x800” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
[quote]Section "Device"
Driver "vesa"
BusID "PCI:2:0:0"
EndSection
Le pilote utilisé pour l’affichage est vesa : marche dans tous les cas mais pas d’accélération 3D, et le CPU fait tout le travail.
Il faut installer le pilote nvidia et mettre à jour xorg.conf. En console, pour installer le pilote :
su mot-de-passe-root aptitude install module-assistant nvidia-kernel-source nvidia-glx nvidia-glx-dev m-a prepare m-a a-i -f nvidia-kernel-source on continue pour dire à xorg
dpkg-reconfigure xserver-xorget on choisi, dans un des écrans successifs, vers le début, le pilote nvidia et pas le pilote vesa. Si nvidia n’apparaît pas, le pilote le plus adapté est nv : prévu pour nvidia mais sans accélération 3D.
Reste à redémarrer xorg pour que la modification soit prise en compte : soit un reboot ou plus simplement appuyer simultanément sur les touches Alt Ctrl et Backspace.
La vidéo devrait être plus fluide.
merci ça marche, mais j’ai mon image qui est trop grande par rapport à ma TV, sûrement une résolution non adaptée. je vais essayer de régler ça.
en effet, c’était une résolution trop importante.
Et encore merci.
