hello
Grr depuis la mise a jours, gnome plante quand je veux aceder a mon serveur via nautilus (et samba)
sa lance un truc pour envoiye un rapport d’anomalie.
voici ce qu’il contien:
Distribution: Debian lenny/sid
Gnome Release: 2.22.0 2008-03-14 (Debian)
BugBuddy Version: 2.22.0
System: Linux 2.6.24- #1 SMP PREEMPT Thu Apr 3 15:04:46 CEST 2008 i686
X Vendor: The X.Org Foundation
X Vendor Release: 10400090
Selinux: No
Accessibility: Disabled
GTK+ Theme: Clearlooks
Icon Theme: gnome
Memory status: size: 80228352 vsize: 80228352 resident: 24588288 share: 16789504 rss: 24588288 rss_rlim: 4294967295
CPU usage: start_time: 1207231317 rtime: 266 utime: 246 stime: 20 cutime:0 cstime: 0 timeout: 0 it_real_value: 0 frequency: 100
Backtrace was generated from '/usr/bin/nautilus'
(no debugging symbols found)
Using host libthread_db library "/lib/i686/cmov/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread 0xb6b69720 (LWP 4787)]
0xffffe410 in __kernel_vsyscall ()
#0 0xffffe410 in __kernel_vsyscall ()
#1 0xb75988eb in waitpid () from /lib/i686/cmov/libpthread.so.0
#2 0xb750e6b4 in g_spawn_sync () from /usr/lib/libglib-2.0.so.0
#3 0xb750e9cc in g_spawn_command_line_sync () from /usr/lib/libglib-2.0.so.0
#4 0xb69ca198 in ?? () from /usr/lib/gtk-2.0/modules/libgnomebreakpad.so
#5 <signal handler called>
#6 0x080e73f9 in ?? ()
#7 0x00000000 in ?? ()
Thread 1 (Thread 0xb6b69720 (LWP 4787)):
No symbol table info available.
The program is running. Quit anyway (and detach it)? (y or n) [answered Y; input not from terminal]
----------- .xsession-errors ---------------------
** (nm-applet:4125): WARNING **: <WARN> nma_dbus_init(): could not acquire its service. dbus_bus_acquire_service() says: 'Connection ":1.17" is not allowed to own the service "org.freedesktop.Networ
** (nautilus:4787): WARNING **: Aucune description trouvée pour le type MIME « x-directory/smb-share » (le fichier est « Amule »), veuillez avertir la liste de diffusion de gnome-vfs.
c’est pénible. surtout que :
tout les droit son affecter depui le client. on ne voit plus les vrai droit sure le serveur.
genre si le fichier apartien a bug1:bug2 on vois ce qu l’on a sur sa marchine
par exemple panther:panthere
quand aux chmod on en parle meme pas c’est complètement a coter de la plaque …
Note nautilus 2.20
j’ai pas vu d’autre client samba (sous X) dans synaptique ?
Merci d’avance
