Voilà ce que cela me donne :
flamme:~# net.samba3
[2010/01/19 17:16:11,  0] param/loadparm.c:7373(lp_set_enum_parm)
  WARNING: Ignoring invalid value 'on' for parameter 'ldap ssl'
Invalid command: net
Usage:
net rpc             Run functions using RPC transport
net rap             Run functions using RAP transport
net ads             Run functions using ADS transport
net file            Functions on remote opened files
net share           Functions on shares
net session         Manage sessions
net server          List servers in workgroup
net domain          List domains/workgroups on network
net printq          Modify printer queue
net user            Manage users
net group           Manage groups
net groupmap        Manage group mappings
net sam             Functions on the SAM database
net validate        Validate username and password
net groupmember     Modify group memberships
net admin           Execute remote command on a remote OS/2 server
net service         List/modify running services
net password        Change user password on target server
net changetrustpw   Change the trust password
net changesecretpw  Change the secret password
net time            Show/set time
net lookup          Look up host names/IP addresses
net join            Join a domain/AD
net dom             Join/unjoin (remote) machines to/from a domain/AD
net cache           Operate on the cache tdb file
net getlocalsid     Get the SID for the local domain
net setlocalsid     Set the SID for the local domain
net setdomainsid    Set domain SID on member servers
net getdomainsid    Get domain SID on member servers
net maxrid          Display the maximul RID currently used
net idmap           IDmap functions
net status          Display server status
net usershare       Manage user-modifiable shares
net usersidlist     Display list of all users with SID
net conf            Manage Samba registry based configuration
net registry        Manage the Samba registry
net eventlog        Process Win32 *.evt eventlog files
net help            Print usage information
C’est “net getlocalsid” qui m’interraisse.
Je suppose que cette commande fonctionne :
net.samba3 getlocalsid
oui, c’est bon :
flamme:~# net.samba3 getlocalsid
[2010/01/19 17:17:46,  0] param/loadparm.c:7373(lp_set_enum_parm)
[2010/01/19 17:17:46,  0] lib/smbldap.c:656(smb_ldap_start_tls)
  Failed to issue the StartTLS instruction: Protocol error
SID for domain TESTSMB is: S-1-5-21-2195826471-1329644318-2633504680
Donc, c’est quoi en fait, il faut que je fasse un alias ?
Merci beaucoup pour ton aide fran.b
