Je rencontre un problème avec la version 3.1 de netatalk que je viens d’installer.
Il m’est impossible depuis de mon mac (snow leopard) de me connecter au server netatalk que je viens de créer.
Après avoir regardé les logs de netatalk, je me suis dit qu’il y avait peut-être une erreur au niveau du daemon CNID :
Nov 09 13:16:40.371135 cnid_metad[8959] {usockfd.c:96} (I:CNID): tsockfd_create: socket: Address family not supported by protocol
Nov 09 13:16:40.371310 cnid_metad[8959] {usockfd.c:135} (E:CNID): tsockfd_create: no suitable network config localhost:4700
Nov 09 13:16:40.372553 netatalk[8915] {netatalk.c:195} (I:Default): child[8959]: exited 1
Nov 09 13:16:41.314508 netatalk[8915] {netatalk.c:235} (N:AFPDaemon): Restarting 'cnid_metad' (restarts: 5)
Nov 09 13:16:41.360439 cnid_metad[8970] {usockfd.c:120} (I:CNID): tsockfd_create: bind: Cannot assign requested address
Si je fais :
ps -ef | grep cnid
aucun résultat ne sort (à part le grep)
donc pas de daemon démarré.
La commande :
netstat -uta | grep 4700
ne retourne pas de résultat non plus, donc ce port semble libre.
La commande :
afpd -V
retourne :
afpd 3.1.0 - Apple Filing Protocol (AFP) daemon of Netatalk
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation; either version 2 of the License, or (at your option) any later
version. Please see the file COPYING for further information and details.
afpd has been compiled with support for these features:
AFP versions: 2.2 3.0 3.1 3.2 3.3
CNID backends: dbd last tdb
Zeroconf support: Avahi
TCP wrappers support: Yes
Quota support: Yes
Admin group support: Yes
Valid shell checks: Yes
cracklib support: Yes
EA support: ad | sys
ACL support: Yes
LDAP support: Yes
D-Bus support: Yes
DTrace probes: Yes
afp.conf: /usr/local/etc/afp.conf
extmap.conf: /usr/local/etc/extmap.conf
state directory: /usr/local/var/netatalk/
afp_signature.conf: /usr/local/var/netatalk/afp_signature.conf
afp_voluuid.conf: /usr/local/var/netatalk/afp_voluuid.conf
UAM search path: /usr/local/lib/netatalk//
Server messages path: /usr/local/var/netatalk/msg/
La commande :
cat /usr/local/etc/afp.conf
retourne :
; Netatalk 3.x configuration file
[Global]
; Global server settings
; loglevels: severe, error, warn, note, info, debug, debug6, debug7, debug8, debug9, maxdebug
; logtypes: default, afpdaemon, logger, uamsdaemon
log level = default:info
log file = /var/log/afpd.log
uam list = uams_guest.so uams_dhx.so uams_dhx2.so
guest account = nobody
zeroconf = yes
hosts allow = 192.168.0.0/16
[Homes]
basedir regex = /home
; [My AFP Volume]
; path = /path/to/volume
[Full Access]
path = /hd/fullaccess
mac charset = MAC_CENTRALEUROPE
cnid scheme = last
valid users = nobody
Si vous avez une idée …
