bonjour ,
j’apprends doucement le réseau , pourrait-on me dire a quoi correspond la plupart des connexions ?
et si c’est obligatoire
Connexions Internet actives (sans serveurs)
Proto Recv-Q Send-Q Adresse locale Adresse distante Etat
Sockets du domaine UNIX actives(sans serveurs)
Proto RefCnt Flags Type State I-Node Chemin
unix 14 [ ] DGRAM 8691 /dev/log
unix 3 [ ] STREAM CONNECTE 11223
unix 3 [ ] STREAM CONNECTE 1230872
unix 3 [ ] STREAM CONNECTE 4037 @/tmp/.X11-unix/X0
unix 2 [ ] DGRAM 14382
unix 3 [ ] STREAM CONNECTE 11679 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12450
unix 3 [ ] STREAM CONNECTE 3692 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 20400
unix 3 [ ] STREAM CONNECTE 12035 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 20397
unix 3 [ ] STREAM CONNECTE 4002
unix 3 [ ] STREAM CONNECTE 11681 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 13332 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 1232875 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13591 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12192 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 13529 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 11685 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12562 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 11875 @/tmp/dbus-wCoWRZ7Npg
unix 2 [ ] DGRAM 1230779
unix 3 [ ] STREAM CONNECTE 13478
unix 3 [ ] STREAM CONNECTE 4005
unix 3 [ ] STREAM CONNECTE 49092 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 12101
unix 3 [ ] STREAM CONNECTE 11939 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11930
unix 3 [ ] STREAM CONNECTE 12195 @/tmp/.ICE-unix/2784
unix 2 [ ] DGRAM 11069
unix 3 [ ] STREAM CONNECTE 13506
unix 3 [ ] STREAM CONNECTE 14379
unix 3 [ ] STREAM CONNECTE 12648
unix 3 [ ] STREAM CONNECTE 12102
unix 3 [ ] STREAM CONNECTE 12537
unix 3 [ ] STREAM CONNECTE 11861
unix 3 [ ] STREAM CONNECTE 3006
unix 3 [ ] STREAM CONNECTE 1235023 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12603
unix 3 [ ] STREAM CONNECTE 21139
unix 3 [ ] STREAM CONNECTE 12651
unix 3 [ ] STREAM CONNECTE 13603 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13443
unix 3 [ ] STREAM CONNECTE 4091 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12395 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 13322 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 11219
unix 3 [ ] STREAM CONNECTE 14424
unix 3 [ ] STREAM CONNECTE 11222
unix 3 [ ] STREAM CONNECTE 1268451
unix 3 [ ] STREAM CONNECTE 344527 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 12650
unix 3 [ ] STREAM CONNECTE 1269067
unix 3 [ ] STREAM CONNECTE 12491
unix 3 [ ] STREAM CONNECTE 290691 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 11873 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12037 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12525
unix 3 [ ] STREAM CONNECTE 11548
unix 3 [ ] STREAM CONNECTE 1270810
unix 3 [ ] STREAM CONNECTE 13601 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13444
unix 3 [ ] STREAM CONNECTE 13325
unix 3 [ ] STREAM CONNECTE 8990
unix 3 [ ] STREAM CONNECTE 12643
unix 3 [ ] STREAM CONNECTE 11694
unix 3 [ ] STREAM CONNECTE 4090 /var/run/xdmctl/dmctl-:0/socket
unix 3 [ ] STREAM CONNECTE 4040 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 344526
unix 3 [ ] STREAM CONNECTE 292989
unix 3 [ ] STREAM CONNECTE 12033 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 13440
unix 3 [ ] STREAM CONNECTE 11858
unix 3 [ ] STREAM CONNECTE 19492 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13458 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14633
unix 3 [ ] STREAM CONNECTE 12307 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 7566
unix 3 [ ] STREAM CONNECTE 1232837
unix 3 [ ] STREAM CONNECTE 12038
unix 3 [ ] STREAM CONNECTE 13469 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12196 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 13507
unix 3 [ ] STREAM CONNECTE 1269211
unix 3 [ ] STREAM CONNECTE 21890 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14632
unix 3 [ ] STREAM CONNECTE 7571
unix 3 [ ] STREAM CONNECTE 17032
unix 3 [ ] STREAM CONNECTE 4071 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12587 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 11155 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 3977 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12553 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 14374 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 9137
unix 3 [ ] STREAM CONNECTE 12055
unix 3 [ ] STREAM CONNECTE 12040 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 14364
unix 3 [ ] STREAM CONNECTE 11212 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 11089 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 14408
unix 3 [ ] STREAM CONNECTE 12536
unix 3 [ ] STREAM CONNECTE 14352 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTE 3861 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 12056
unix 3 [ ] STREAM CONNECTE 11650
unix 3 [ ] STREAM CONNECTE 13505 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 4096 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 3980 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 14388
unix 3 [ ] STREAM CONNECTE 11119
unix 3 [ ] STREAM CONNECTE 14624 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12007
unix 3 [ ] STREAM CONNECTE 12504
unix 3 [ ] STREAM CONNECTE 14338
unix 3 [ ] STREAM CONNECTE 1229687
unix 3 [ ] STREAM CONNECTE 21894 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12006
unix 3 [ ] STREAM CONNECTE 14386 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 9139
unix 3 [ ] STREAM CONNECTE 9116 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 291733 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 14629
unix 3 [ ] STREAM CONNECTE 11034 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 12128 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 9188 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 12520 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 4061 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13528 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 12575
unix 3 [ ] STREAM CONNECTE 11057
unix 3 [ ] STREAM CONNECTE 14643
unix 3 [ ] STREAM CONNECTE 11982
unix 3 [ ] STREAM CONNECTE 9117 /var/run/dbus/system_bus_socket
unix 3 [ ] DGRAM 6081
unix 3 [ ] STREAM CONNECTE 13524
unix 3 [ ] STREAM CONNECTE 11255 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13593 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 12580
unix 3 [ ] STREAM CONNECTE 11224 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 3699 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 14521 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 11917
unix 3 [ ] STREAM CONNECTE 287983
unix 3 [ ] STREAM CONNECTE 287984 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTE 12647 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 1228713 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12103 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13452 @/tmp/.ICE-unix/2784
unix 2 [ ] DGRAM 3693
unix 3 [ ] STREAM CONNECTE 12219 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13326 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 9280
unix 3 [ ] STREAM CONNECTE 14522
unix 3 [ ] STREAM CONNECTE 11210
unix 3 [ ] STREAM CONNECTE 11131
unix 3 [ ] STREAM CONNECTE 1233793 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 9143
unix 3 [ ] STREAM CONNECTE 3847
unix 3 [ ] STREAM CONNECTE 1230167 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 11690 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11013 /var/run/acpid.socket
unix 2 [ ] DGRAM 11158
unix 3 [ ] STREAM CONNECTE 9295 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 11718 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 3849
unix 3 [ ] STREAM CONNECTE 9104
unix 2 [ ] DGRAM 9271
unix 3 [ ] STREAM CONNECTE 9182
unix 3 [ ] STREAM CONNECTE 11014 /var/run/dbus/system_bus_socket
unix 2 [ ] DGRAM 7576
unix 3 [ ] STREAM CONNECTE 13598 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 14523
unix 3 [ ] STREAM CONNECTE 11117
unix 3 [ ] STREAM CONNECTE 22739 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 8773
unix 3 [ ] STREAM CONNECTE 11905
unix 3 [ ] STREAM CONNECTE 11867 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11118
unix 3 [ ] STREAM CONNECTE 13477
unix 3 [ ] STREAM CONNECTE 21140 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 3990 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 3846
unix 3 [ ] STREAM CONNECTE 11956
unix 3 [ ] STREAM CONNECTE 12405
unix 3 [ ] STREAM CONNECTE 12392
unix 3 [ ] STREAM CONNECTE 13488
unix 3 [ ] STREAM CONNECTE 14411 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12526 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 13590
unix 3 [ ] STREAM CONNECTE 11981 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTE 14634 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12330 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12191
unix 3 [ ] STREAM CONNECTE 12062
unix 3 [ ] STREAM CONNECTE 12583 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14439 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 13532 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 11994 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 1270809
unix 3 [ ] STREAM CONNECTE 12585 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13599
unix 3 [ ] STREAM CONNECTE 12360
unix 3 [ ] STREAM CONNECTE 13614 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 12447
unix 3 [ ] STREAM CONNECTE 3991
unix 3 [ ] STREAM CONNECTE 3904 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13460
unix 3 [ ] STREAM CONNECTE 11735 /tmp/ksocket-aldarga/kdeinit4__0
unix 3 [ ] STREAM CONNECTE 12551
unix 3 [ ] STREAM CONNECTE 11233
unix 3 [ ] STREAM CONNECTE 3005
unix 3 [ ] STREAM CONNECTE 292997 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13456 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12327 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 3979 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11041
unix 3 [ ] STREAM CONNECTE 13602
unix 3 [ ] STREAM CONNECTE 13403
unix 3 [ ] STREAM CONNECTE 4041
unix 3 [ ] STREAM CONNECTE 3983 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12649 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 13594 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12564 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 12439
unix 3 [ ] STREAM CONNECTE 11698
unix 3 [ ] STREAM CONNECTE 11914
unix 3 [ ] STREAM CONNECTE 12552
unix 3 [ ] STREAM CONNECTE 11965 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12292 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 11015 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 1232874
unix 3 [ ] STREAM CONNECTE 1233788
unix 3 [ ] STREAM CONNECTE 14375 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 1268452
unix 3 [ ] STREAM CONNECTE 11908
unix 3 [ ] STREAM CONNECTE 13600
unix 3 [ ] STREAM CONNECTE 13453 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 4039 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 9185
unix 3 [ ] STREAM CONNECTE 14409 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 290679 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14635
unix 3 [ ] STREAM CONNECTE 13457
unix 2 [ ] STREAM CONNECTE 1268447
unix 3 [ ] STREAM CONNECTE 17793 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 12554 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 7565
unix 3 [ ] STREAM CONNECTE 12104
unix 3 [ ] STREAM CONNECTE 14410 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 1269210
unix 3 [ ] STREAM CONNECTE 12047 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14412
unix 3 [ ] STREAM CONNECTE 17759
unix 3 [ ] STREAM CONNECTE 13596 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 13487
unix 3 [ ] STREAM CONNECTE 11211
unix 3 [ ] STREAM CONNECTE 13406
unix 3 [ ] STREAM CONNECTE 290689
unix 3 [ ] STREAM CONNECTE 1230166 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 14387 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 3874 @/tmp/.X11-unix/X0
unix 2 [ ] DGRAM 1268449
unix 3 [ ] STREAM CONNECTE 13464 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 11997
unix 3 [ ] STREAM CONNECTE 14357 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 14431
unix 3 [ ] STREAM CONNECTE 11644
unix 3 [ ] STREAM CONNECTE 9138 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 3921 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 14453 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 13463 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 12512 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 11862
unix 3 [ ] STREAM CONNECTE 8985
unix 3 [ ] STREAM CONNECTE 11980
unix 3 [ ] STREAM CONNECTE 13450 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 9042
unix 3 [ ] STREAM CONNECTE 1233789
unix 3 [ ] STREAM CONNECTE 11651
unix 3 [ ] STREAM CONNECTE 13597 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 11972 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11864
unix 3 [ ] STREAM CONNECTE 14432
unix 3 [ ] STREAM CONNECTE 50802
unix 3 [ ] STREAM CONNECTE 13451 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 13589
unix 3 [ ] STREAM CONNECTE 1235010 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 12524
unix 3 [ ] STREAM CONNECTE 14520
unix 3 [ ] STREAM CONNECTE 12042 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 11550 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 1268315 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 13396
unix 3 [ ] STREAM CONNECTE 12644
unix 3 [ ] STREAM CONNECTE 12519
unix 3 [ ] STREAM CONNECTE 11903
unix 3 [ ] STREAM CONNECTE 11699
unix 3 [ ] STREAM CONNECTE 14455 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 13592
unix 3 [ ] STREAM CONNECTE 14446 @/tmp/.ICE-unix/2784
unix 3 [ ] STREAM CONNECTE 11555 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 13613 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 14630 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 292335
unix 3 [ ] STREAM CONNECTE 11778
unix 3 [ ] STREAM CONNECTE 288960 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTE 12646
unix 3 [ ] STREAM CONNECTE 12560 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 292336
unix 2 [ ] DGRAM 7563
unix 3 [ ] STREAM CONNECTE 12584
unix 3 [ ] STREAM CONNECTE 288964
unix 3 [ ] STREAM CONNECTE 4044 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 1232842
unix 2 [ ] STREAM CONNECTE 1230777
unix 3 [ ] STREAM CONNECTE 9279
unix 3 [ ] STREAM CONNECTE 12586
unix 3 [ ] STREAM CONNECTE 9302
unix 3 [ ] DGRAM 6082
unix 2 [ ] DGRAM 11916
unix 3 [ ] STREAM CONNECTE 11706 @/tmp/dbus-wCoWRZ7Npg
unix 3 [ ] STREAM CONNECTE 9086
unix 3 [ ] STREAM CONNECTE 9285 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 1235024
unix 3 [ ] STREAM CONNECTE 9133
unix 3 [ ] STREAM CONNECTE 9103
unix 2 [ ] DGRAM 9259
unix 3 [ ] STREAM CONNECTE 20394
unix 3 [ ] STREAM CONNECTE 11738 /var/run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTE 3848
unix 3 [ ] STREAM CONNECTE 12194
unix 3 [ ] STREAM CONNECTE 8988
unix 3 [ ] STREAM CONNECTE 7579
unix 3 [ ] STREAM CONNECTE 13531 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 3 [ ] STREAM CONNECTE 9112
unix 3 [ ] STREAM CONNECTE 13530 /tmp/akonadi-aldarga.Fmj9qF/akonadiserver.socket
unix 2 [ ] DGRAM 8716
unix 3 [ ] STREAM CONNECTE 1229686
unix 3 [ ] STREAM CONNECTE 11148 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTE 9136
