NFSV4 marche pas
Hug,
Je n’arrive pas a faire fonctionne NFS v4 entre 2 bécanes.
1 serveur sous Linux debian 2.6.26-1-686
avec entre autre nfs-kernel-d’installer
le /etc/hosts.allow
ALL:192.168.1.22
dans /etc/hosts.deny
Rien du tout (en faite, pas de politique de securite)
ls -l /sbin/mount.nfs
-rwsr-xr-x 1 root root 68072 oct 20 23:01 /sbin/mount.nfs
ls -l /sbin/mount.nfs4
lrwxrwxrwx 1 root root 9 nov 28 17:52 /sbin/mount.nfs4 -> mount.nfs
mount -V
mount (util-linux-ng 2.13.1.1)
/etc/exports
/LVM *(sync,secure,rw,crossmnt,no_subtree_check,fsid=0)
/LVM/Emulation *(sync,secure,rw,crossmnt,no_subtree_check,fsid=0)
grep Nobody /etc/idmapd.conf
Nobody-User = nobody
Nobody-Group = nogroup
/etc/default/nfs-kernel-server
NEED_SVCGSSD=no
RPCNFSDCOUNT=8
/etc/default/nfs-common
NEED_IDMAPD=yes
NEED_GSSD=no
/etc/init.d/nfs-kernel-server restart
Stopping NFS kernel daemon: mountd nfsd.
Unexporting directories for NFS kernel daemon…
Exporting directories for NFS kernel daemon…
Starting NFS kernel daemon: nfsd mountd.
exportfs -v
/LVM/Emulation (rw,wdelay,crossmnt,root_squash,no_subtree_check,fsid=0)
/LVM (rw,wdelay,crossmnt,root_squash,no_subtree_check,fsid=0)
Seconde machine (un portable) mais lui sous Ubuntu (derniere version) Linux acer 2.6.27-9-server
ls -l /mount.nfs
-rwsr-xr-x 1 root root 72016 2008-12-02 20:31 /sbin/mount.nfs
lrwxrwxrwx 1 root root 9 2009-01-02 21:40 /sbin/mount.nfs4 -> mount.nfs
[b]/sbin/mount.nfs -V[b]
mount.nfs (linux nfs-utils 1.1.2)
[b]/sbin/mount -V[b]
mount from util-linux-ng 2.14 (with libvolume_id and selinux support)
/etc/fstab
192.168.1.25:/LVM /NFS/Emulation nfs4
Les deux bécanes sont relier a ma freebox V5 et le tout dans un sous reseau en 192.168.1.X
On se lance, sur le portable donc le client !
showmount -e 192.168.1.25
Export list for 192.168.1.25:
/LVM *
/LVM/Emulation *
mount /NFS/Emulation/
mount.nfs4: mounting 192.168.1.25:/LVM failed, reason given by server:
No such file or directory
ls -ld /NFS/Emulation/
drwxr-xr-x 2 root root 4096 2009-01-04 19:21 /NFS/Emulation/
Et si je change le nfs4 en nfs dans mon fstab de mon client
le montage fonctionne.
Pourquoi donc je reste pas avec de l’ancien nfs ? vue que ca fonctionne.
En faite ca ne fonctionne qu’a moitier, lors d’un transfert d’un fichier ca fige
tres vite (au bout d’une 20 aine de mega sur un fichier de 200Mega)
Le montage NFS ne reponds plus et il est meme IMPOSSIBLE de le demonter.
J’ai constater ce probleme sur ma debian avec l’ancien noyau 2.17 de mémoire
et meme en ayant upgrader en 2.6.26 j’ai le meme probleme.
Concernant le client, Ubuntu, j’ai essayé aussi avec la derniere fedora
J’ai Exactement le meme probleme (perte de connection en NFS sur le client, demontage NFS Impossible)
Donc je me suis dit, on vas passer en NFS v4 ca ne peux qu’ameliorer la chose
sauf que, ca ne fonctionne pas.
Le comble du comple, (le but etant donc de partager les informations contenue sur mon serveur
dans mon reseau LOCAL ‘et que’), j’ai d’autre becane sous zindows donc j’ai mis samba sur le
serveur debian.
et bé ca fonctionne NICKEL avec samba que ce soit a partir d’un client WIndows OU linux
Je pourrais donc passer par samba… mais bon… entre 2 linux utiliser samba… c’te honte.
Je suis preneur pour de l’aide.
Thks d’avance
Blup,
Problème Réglé au niveau configuration/utilisation du NFS4
par contre, j’ai tjs le meme soucie meme en nfs4,
Bloquage de la copie en NFS au bout d’une centaine de mega, timeoutn bloquage machine.
Ce probleme apparait en wifi, PAS en connexion cuivre.
Merci pour ce développement assez poussé du problème présenté, d’autant que ce problème me concerne aussi… Malgré quelques lacunes d’écriture “rapide” je pense avoir compris la logique.
Mais ce qui me déçoit vraiment c’est le style:
quote/ Problème Réglé au niveau configuration/utilisation du NFS4/unquote
C’est pas très sympa ça pour ceux qui cherche aussi…
