Voici le contenu du fichier:
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:23:54:13:a5:2d", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# Firewire device (nodemgr)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1e:8c:00:01:84:dd:e9", ATTR{type}=="24", KERNEL=="eth*", NAME="eth1"
# PCI device 0x168c:0x002a (ath9k)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:22:43:1c:80:1f", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:e6:1a:1b:96", ATTR{type}=="1", KERNEL=="eth*", NAME="eth2"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:7e:de:02:94", ATTR{type}=="1", KERNEL=="eth*", NAME="eth3"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:7b:f4:7d:a1", ATTR{type}=="1", KERNEL=="eth*", NAME="eth4"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:40:bb:7a:eb", ATTR{type}=="1", KERNEL=="eth*", NAME="eth5"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:1d:b0:a0:e2", ATTR{type}=="1", KERNEL=="eth*", NAME="eth6"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:3b:88:bc:f3", ATTR{type}=="1", KERNEL=="eth*", NAME="eth7"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:4d:ce:bb:e2", ATTR{type}=="1", KERNEL=="eth*", NAME="eth8"
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="04:00:5e:e0:02:e2", ATTR{type}=="1", KERNEL=="eth*", NAME="eth9"
Chose bizarre, l’adresse mac change tout le temps. Y’a-t-il moyen de la rendre fixe (ce qui normalement devrait être le cas) comme avant ou existe-t-il une autre solution (regénération du fichier, écriture en dur de l’adresse…) ?
Merci.
