Lisant ceci https://www.debian.org/releases/stable/amd64/release-notes/ch-whats-new.fr.html#new-interface-names
je vois que je suis dans ce cas puisque j’ai mis à niveau depuis jessie
cat /etc/udev/rules.d/70-persistent-net.rules
# This file was automatically generated by the /lib/udev/write_net_rules
# program, run by the persistent-net-generator.rules rules file.
# You can modify it, as long as you keep each rule on a single
# line, and change only the value of the NAME= key.
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="98:4b:e1:c6:c4:7b", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x14e4:0x4727 (brcmsmac)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="cc:52:af:5a:a2:b5", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
netstat -r
Table de routage IP du noyau
Destination Passerelle Genmask Indic MSS Fenêtre irtt Iface
default gateway 0.0.0.0 UG 0 0 0 wlan0
link-local 0.0.0.0 255.255.0.0 U 0 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
Si je veux être à la mode
, comment faut-il faire ??
Activer systemd-networkd.service ??
