xscan ne détecte aucun scanner !! grrr
Je voudrais modifier mon fichier de configuration epson.conf dans le répertoire /etc/sane.d/.
Voici ce que j’y ai trouvé :
[i]# USB scanner:
There are two different methods of configuring a USB scanner: libusb and the kernel module
For any system with libusb support (which is pretty much any recent Linux distribution) the
following line is sufficient. This however assumes that the connected scanner (or to be more
accurate, it’s device ID) is known to the backend.
usb
For libusb support for unknown scanners use the following command
usb
e.g.:
usb 0x4b8 0x110
And for the scanner module, use the following configuration:
#usb /dev/usbscanner0
#usb /dev/usb/scanner0[/i]
D’autre part, un scan-find-scaner renvoie ceci :
[i] # sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x147a [Formosa21], product=0xe018 [Beanbag Emulation Device]) at libusb:003:007
found USB scanner (vendor=0x04b8, product=0x083a) at libusb:003:005
found USB scanner (vendor=0x15a9 [Ralink], product=0x0004 [802.11 bg WLAN]) at libusb:001:002
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
[/i]
Quelqu’un peut-il me décrypter ces messages (notamment "usb ") sachant que mon imprimante/Fax/scanner est en USB ?
