Noyau 2.6.19 et clé usb
J’ai compilé un noyau 2.6.19 en en regardant toutes les cases et en mettant dur, module ou non et maintenant quand je connecte ma clé, elle ne fonctionne pas.
tail -f /var/log/syslog :
[ul]
Jan 22 20:17:22 6mon kernel: hub 4-0:1.0: state 7 ports 6 chg 0000 evt 0020
Jan 22 20:17:22 6mon kernel: ehci_hcd 0000:00:10.3: GetStatus port 5 status 701803 POWER sig=j CSC CONNECT
Jan 22 20:17:22 6mon kernel: hub 4-0:1.0: port 5, status 0501, change 0001, 480 Mb/s
Jan 22 20:17:22 6mon kernel: hub 4-0:1.0: debounce: port 5: total 100ms stable 100ms status 0x501
Jan 22 20:17:22 6mon kernel: ehci_hcd 0000:00:10.3: port 5 high speed
Jan 22 20:17:22 6mon kernel: ehci_hcd 0000:00:10.3: GetStatus port 5 status 701005 POWER sig=se0 PE CONNECT
Jan 22 20:17:22 6mon kernel: usb 4-5: new high speed USB device using ehci_hcd and address 17
Jan 22 20:17:22 6mon kernel: usb 4-5: default language 0x0409
Jan 22 20:17:22 6mon kernel: usb 4-5: new device strings: Mfr=1, Product=2, SerialNumber=3
Jan 22 20:17:22 6mon kernel: usb 4-5: Product: YP-T7F
Jan 22 20:17:22 6mon kernel: usb 4-5: Manufacturer: SAMSUNG
Jan 22 20:17:22 6mon kernel: usb 4-5: SerialNumber: 965B0A001115
Jan 22 20:17:22 6mon kernel: usb 4-5: uevent
Jan 22 20:17:22 6mon kernel: usb 4-5: usb_probe_device
Jan 22 20:17:22 6mon kernel: usb 4-5: configuration #1 chosen from 1 choice
Jan 22 20:17:22 6mon kernel: usb 4-5: adding 4-5:1.0 (config #1, interface 0)
Jan 22 20:17:22 6mon kernel: usb 4-5:1.0: uevent
Jan 22 20:17:22 6mon kernel: drivers/usb/core/inode.c: creating file ‘017’
etc …
et tout à la fin
Jan 22 20:24:01 6mon kernel: ATM dev 0: usbatm_extract_one_cell: unknown vpi/vci (4/11161)!
Jan 22 20:24:06 6mon kernel: ATM dev 0: usbatm_extract_one_cell: unknown vpi/vci (87/28161)!
Jan 22 20:24:07 6mon kernel: ATM dev 0: usbatm_extract_one_cell: unknown vpi/vci (29/61440)!
Jan 22 20:24:10 6mon kernel: ATM dev 0: usbatm_extract_one_cell: unknown vpi/vci (50/5156)!
[/ul]
Donc voila si quelqu’un peut m’aider !
Sxmon
C’est quoi comme clé usb ??? Une clé pour le stockage de données??? ou une clé pour la connection wifi???
usbatm_extract_one_cell: unknown vpi/vci (4/11161)! Correspond a un probleme de connection au net
C’est une clé usb de donnés (d’ailleurs j’ai testé avec une autre clé usb de donnés et ça marche pas).
Sxmon
Je vais reformuler ma question :
Je branche ma clé USB de donnés quand je suis sur mon noyau 2.6.19 compiler par moi.
Je fais :
ls /dev/sd*
ls: /dev/sd*: Aucun fichier ou répertoire de ce type
et pourquoi ???
J’ai tout coché dans dans :
Device Drivers --> USB support
Device Drivers --> USB support --> USB Network Adapters
Device Drivers --> USB support --> USB Serial Converter support
Device Drivers --> USB support --> USB DSL modem support
Device Drivers --> USB support --> USB Gadget Support
Et voila,
Donc si quelqu’un à une idée …
Sxmon
C’est vrai que c’est bizarre, VPI/VCI correspond à de l’ADSL (d’ailleurs c’est usb_atm qui donne le message…), quels sont les modules installés? Force en faisant
modprobe usb-storage sd_mod
J’ai enfin trouvé : il me manqué les drivers SCSI et maintenant ça marche.
Merci pour tout,
Sxmon
