ubuntu-budgie@ubuntu-budgie:~$ sudo dumpe2fs -h /dev/sda3
dumpe2fs 1.44.1 (24-Mar-2018)
Filesystem volume name: <none>
Last mounted on: <not available>
Filesystem UUID: 1d68a093-7486-416b-b9bc-bba0506ece7b
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: has_journal ext_attr resize_inode dir_index filetype extent flex_bg sparse_super large_file huge_file uninit_bg dir_nlink extra_isize
Filesystem flags: signed_directory_hash
Default mount options: user_xattr acl
Filesystem state: clean
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 3499328
Block count: 13996544
Reserved block count: 699827
Free blocks: 13730881
Free inodes: 3499317
First block: 0
Block size: 4096
Fragment size: 4096
Reserved GDT blocks: 1020
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8176
Inode blocks per group: 511
Flex block group size: 16
Filesystem created: Sun Sep 16 16:48:47 2018
Last mount time: Tue Dec 3 20:24:08 2019
Last write time: Tue Dec 3 20:24:08 2019
Mount count: 4
Maximum mount count: -1
Last checked: Sun Sep 16 16:48:47 2018
Check interval: 0 (<none>)
Lifetime writes: 988 MB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 28
Desired extra isize: 28
Journal inode: 8
Default directory hash: half_md4
Directory Hash Seed: bf425cb4-2eaf-4932-9815-d05b1d48f2cc
Journal backup: inode blocks
Journal features: (none)
Journal size: 128M
Journal length: 32768
Journal sequence: 0x0000008a
Journal start: 0
Du coup, j’me suis trompé de partition ??? J’ai du entamer une install sur le sda3 actif… la honte !
Je reprends les manips d’hier soir.
ubuntu-budgie@ubuntu-budgie:~$ e2fsck /dev/sda3
e2fsck 1.44.1 (24-Mar-2018)
/dev/sda3 est monté.
ATTENTION !!! Le système de fichiers est monté. Si vous continuez
vous ***CAUSEREZ*** des dommages ***SÉVÈRES*** au système de fichiers.
Souhaitez-vous réellement continuer<n>?
Bah umount avant, quand même.
ubuntu-budgie@ubuntu-budgie:~$ sudo umount -r /dev/sda3 /mnt
umount: /mnt : non monté.
ubuntu-budgie@ubuntu-budgie:~$ sudo e2fsck /dev/sda3
/dev/sda3 : propre, 11/3499328 fichiers, 265663/13996544 blocs
