Nvidia, acceleration 2D, mtrr et pilote nouveau ds un panier
j’ai debian sid installé depuis deux semaines sur une nouvelle machine avec une carte nvidia GT 210.
J’ai installé le paquet nvidia-kernel-dkms.
L’accélération 3D est prise en charge mais :
lecture de films saccadée, ralentissements réguliers voire blocage de la souris et des déplacements de fenêtres, bref lenteur accablante de l’accéleration 2D
[code]27-11-2010 debian sid driave nvidia-kernel-dkms 195.36.31-6
$ glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
11967 frames in 5.0 seconds = 2393.340 FPS
9765 frames in 5.0 seconds = 1952.884 FPS
1215 frames in 5.0 seconds = 242.853 FPS
482 frames in 5.0 seconds = 96.382 FPS
492 frames in 5.0 seconds = 98.396 FPS
481 frames in 5.0 seconds = 96.172 FPS
491 frames in 5.0 seconds = 98.126 FPS
489 frames in 5.0 seconds = 97.664 FPS
494 frames in 5.0 seconds = 98.789 FPS
486 frames in 5.0 seconds = 97.083 FPS
492 frames in 5.0 seconds = 98.352 FPS
489 frames in 5.0 seconds = 97.630 FPS
490 frames in 5.0 seconds = 97.925 FPS
484 frames in 5.0 seconds = 96.700 FPS
488 frames in 5.0 seconds = 97.592 FPS
486 frames in 5.0 seconds = 97.055 FPS
490 frames in 5.0 seconds = 97.980 FPS
490 frames in 5.0 seconds = 97.904 FPS
487 frames in 5.0 seconds = 97.240 FPS
488 frames in 5.0 seconds = 97.445 FPS
488 frames in 5.0 seconds = 97.411 FPS
501 frames in 5.0 seconds = 100.157 FPS
522 frames in 5.0 seconds = 104.343 FPS
524 frames in 5.0 seconds = 104.677 FPS
520 frames in 5.0 seconds = 103.822 FPS
521 frames in 5.0 seconds = 104.152 FPS
531 frames in 5.0 seconds = 106.055 FPS
529 frames in 5.0 seconds = 105.677 FPS
506 frames in 5.0 seconds = 101.180[/code]
Plus je laisse l’interface allumée longtemps plus les FPS diminuent jusqu’à tomber en deçà de 90 FPS
J’ai fait un essai avec le dernier .run nvidia j’ai l’impression (visuelle uniquement : glxgears presque identhique) que c’est pire donc je tourne avec le nvidia-kernel-dkms actuellement.
Je tombe sur ça dans la doc française gentoo :
http://www.gentoo.org/doc/fr/nvidia-guide.xml#doc_chap4
Je précise que j’ai 4Go de ram
# nano /proc/mtrr
reg00: base=0x0e0000000 ( 3584MB), size=  512MB, count=1: uncachable
reg01: base=0x000000000 (    0MB), size= 4096MB, count=1: write-back
Donc d’après la doc gentoo je devrais mettre les réglages mtrr à “discret” dans cpu settings de mon bios mais je n’arrive pas à trouver l’option : j’ai une carte mère asus maximus 3 gene…
Sinon j’ai fait un essai avec un live-cd ubuntu et j’ai installé opensuze sur une partition qui trainait : le pilote nouveau des 2 distribution fonctionne à merveille en 2D (j’arrive à lire des films en 1080p sans problèmes) mais je ne sais pas comment l’installer sur ma debian et je perds la 3D…
Si quelqu’un sait où trouver les réglages mtrr dans les bios asus récents ou comment installer les pilotes nouveau de expérimental… sachant que je souhaite tout de même garder un système suffisamment stable pour une machine de bureau.
Merci à vous !
Impossible de trouver un quelconque réglage de mtrr, sur mon portable (qui a le même problème mais en moins gênant de même)
Je voudrais tenter d’installer le pilote nouveau :
# apt-cache policy xserver-xorg-video-nouveau xserver-xorg-video-nouveau: Installé : 1:0.0.15+git20100329+7858345-5 Candidat : 1:0.0.15+git20100329+7858345-5 Table de version : 1:0.0.16+git20100825+390f1c8-1 0 98 http://ftp.fr.debian.org/debian/ experimental/main amd64 Packages *** 1:0.0.15+git20100329+7858345-5 0 980 http://ftp.fr.debian.org/debian/ squeeze/main amd64 Packages 987 http://ftp.fr.debian.org/debian/ sid/main amd64 Packages 100 /var/lib/dpkg/status
C’est la version 1:0.0.16 qui est ds ubuntu et opensuze et qui fonctionne bien.
dans le wiki debian je trouve :
http://wiki.debian.org/NvidiaGraphicsDrivers#Nouveau
[code]# apt-get install xserver-xorg-video-nouveau
printf “nouveau\ndrm\n” >> /etc/modules[/code]
Est ce que je dois faire d’autres commandes avant étant donné que j’ai nvidia-kernel-dkms et quelques autres paquets d’installés ?
