Hello,
J’ai trouvé la solution nullepart à mon problème, je suis sure que mon xorg.conf est mauvais, le voici :
[code]# xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/psaux"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section “Extensions”
#Ces options servent pour la vraie transparence
Option “Composite” "Enable"
Option “RENDER” "Enable"
Option “DAMAGE” "true"
EndSection
Section "Device"
Identifier "7900 GTO"
Driver "nvidia"
BusID "PCI:4:0:0"
Option “RenderAccel” "true"
Option “AllowGLXWithComposite” "true"
Option “backingstore” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-64
VertRefresh 43-60
EndSection
Section "Screen"
Identifier "Default Screen"
Device "7900 GTO"
Monitor "Écran générique"
DefaultDepth 24
Option “AddARGBGLXVisuals” "True"
SubSection "Display"
Modes "1280x1024"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
Donc en temps normale l’accélération 3D fonctionne très bien, avec beryl également sauf que rien de beryl ne fonctionne, je m’explique : lorsque je l’active, il se lance (pas de logo) mais ne change rien à l’écran si ce n’est que les barres de titres disparaissent toutes. Pas de plantage hormis ça.
Voilà, donc pouvez me dire ce qui cloche ?
Merci.
