Bonjours
Ou puis-je réglé la luminosité & couleur ???
$ uname -a
Linux Rox 4.9.0-2-amd64 #1 SMP Debian 4.9.13-1 (2017-02-27) x86_64 GNU/Linux
$ lspci |grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 980] (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 980] (rev a1)
source.list
deb http://security.debian.org/debian-security stretch/updates main contrib
deb-src http://security.debian.org/debian-security stretch/updates main contrib
#deb http://ftp.de.debian.org/debian stretch main
deb http://ftp.de.debian.org/debian stretch main non-free contrib
#deb http://httpredir.debian.org/debian jessie-backports main contrib non-free
#deb http://ftp.de.debian.org/debian stretch main contrib
$ dpkg -l |grep nvidia
ii glx-alternative-nvidia 0.7.4 amd64 allows the selection of NVIDIA as GLX provider
ii libegl-nvidia0:amd64 375.39-1 amd64 NVIDIA binary EGL library
ii libegl1-glvnd-nvidia:amd64 375.39-1 amd64 Vendor neutral GL dispatch library -- libEGL
ii libgl1-nvidia-glx:amd64 375.39-1 amd64 NVIDIA binary OpenGL/GLX library (non-GLVND variant)
ii libgl1-nvidia-glx:i386 375.39-1 i386 NVIDIA binary OpenGL/GLX library (non-GLVND variant)
ii libgldispatch0-nvidia:amd64 375.39-1 amd64 Vendor neutral GL dispatch library -- libGLdispatch
ii libgles-nvidia1:amd64 375.39-1 amd64 NVIDIA binary OpenGL|ES 1.x library
ii libgles-nvidia2:amd64 375.39-1 amd64 NVIDIA binary OpenGL|ES 2.x library
ii libgles1-glvnd-nvidia:amd64 375.39-1 amd64 NVIDIA binary OpenGL|ES 1.x GLVND stub library
ii libgles2-glvnd-nvidia:amd64 375.39-1 amd64 NVIDIA binary OpenGL|ES 2.x GLVND stub library
ii libglx-nvidia0:amd64 375.39-1 amd64 NVIDIA binary GLX library
ii libglx0-glvnd-nvidia:amd64 375.39-1 amd64 Vendor neutral GL dispatch library -- libGLX
ii libnvidia-cfg1:amd64 375.39-1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-eglcore:amd64 375.39-1 amd64 NVIDIA binary EGL core libraries
ii libnvidia-glcore:amd64 375.39-1 amd64 NVIDIA binary OpenGL/GLX core libraries
ii libnvidia-glcore:i386 375.39-1 i386 NVIDIA binary OpenGL/GLX core libraries
ii libnvidia-ml1:amd64 375.39-1 amd64 NVIDIA Management Library (NVML) runtime library
ii libopengl0-glvnd-nvidia:amd64 375.39-1 amd64 Vendor neutral GL dispatch library -- libOpenGL
ii nvidia-alternative 375.39-1 amd64 allows the selection of NVIDIA as GLX provider
ii nvidia-detect 375.39-1 amd64 NVIDIA GPU detection utility
ii nvidia-driver 375.39-1 amd64 NVIDIA metapackage
ii nvidia-driver-bin 375.39-1 amd64 NVIDIA driver support binaries
ii nvidia-driver-libs:amd64 375.39-1 amd64 NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii nvidia-egl-common 375.39-1 amd64 NVIDIA binary EGL driver - common files
ii nvidia-egl-icd:amd64 375.39-1 amd64 NVIDIA EGL installable client driver (ICD)
ii nvidia-installer-cleanup 20151021+4 amd64 cleanup after driver installation with the nvidia-installer
ii nvidia-kernel-common 20151021+4 amd64 NVIDIA binary kernel module support files
ii nvidia-kernel-dkms 375.39-1 amd64 NVIDIA binary kernel module DKMS source
ii nvidia-kernel-support 375.39-1 amd64 NVIDIA binary kernel module support files
ii nvidia-legacy-check 375.39-1 amd64 check for NVIDIA GPUs requiring a legacy driver
ii nvidia-modprobe 375.26-1 amd64 utility to load NVIDIA kernel modules and create device nodes
ii nvidia-persistenced 375.26-2 amd64 daemon to maintain persistent software state in the NVIDIA driver
ii nvidia-settings 375.26-3 amd64 tool for configuring the NVIDIA graphics driver
ii nvidia-support 20151021+4 amd64 NVIDIA binary graphics driver support files
ii nvidia-vdpau-driver:amd64 375.39-1 amd64 Video Decode and Presentation API for Unix - NVIDIA driver
ii nvidia-vulkan-common 375.39-1 amd64 NVIDIA Vulkan driver - common files
ii nvidia-vulkan-icd:amd64 375.39-1 amd64 NVIDIA Vulkan installable client driver (ICD)
ii xserver-xorg-video-nvidia 375.39-1 amd64 NVIDIA binary Xorg driver
Desoler pour la mise en forme le forum interprète les « # »
Dans ce contexte je préfère montrer les lignes.
Merci d’avance ![]()
