Nvidia && gcc ? [résolut]
hello.
Je ne parvien pas a instaler les driver 3d nvidia.
sh Nvidia.xxxx.run
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Oct  1 15:08:57 2007
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  precompiled interfaces  : true
  no ncurses color        : false
  query latest version    : false
  OpenGL header files     : true
  no questions            : false
  silent                  : false
  no recursion            : false
  no backup               : false
  kernel module only      : false
  sanity                  : false
  add this kernel         : false
  no runlevel check       : false
  no network              : false
  no ABI note             : false
  no RPMs                 : false
  no kernel module        : false
  force SELinux           : default
  no X server check       : false
  force tls               : (not specified)
  X install prefix        : (not specified)
  X library install path  : (not specified)
  X module install path   : (not specified)
  OpenGL install prefix   : (not specified)
  OpenGL install libdir   : (not specified)
  utility install prefix  : (not specified)
  utility install libdir  : (not specified)
  doc install prefix      : (not specified)
  kernel name             : (not specified)
  kernel include path     : (not specified)
  kernel source path      : (not specified)
  kernel output path      : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp mirror              : ftp://download.nvidia.com
  RPM file list           : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
   that the installer will need to compile a new kernel interface.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> The CC version check failed:
   The compiler used to compile the kernel (gcc 4.1) does not exactly match the
   current compiler (gcc 4.2).  The Linux 2.6 kernel module loader rejects kern
   el modules built with a version of gcc that does not exactly match that of t
   he compiler used to build the running kernel.
   If you know what you are doing and want to ignore the gcc version check, sel
   ect "No" to continue installation.  Otherwise, select "Yes" to abort install
   ation, set the CC environment variable to the name of the compiler used to c
   ompile your kernel, and restart installation.  Abort now? (Answer: Yes)
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com
gcc 4.2.x.x est installer de meme que la vertion 4.1
apt-get install modul-assisrant apt-get install module-assistant apt-get install linux-headers-$(uname -r)
riien a signialer les source on aussi été installer
donc la je ne voit pas, ou sa couine vu que gcc est installer
Merci d’avance
Tu as tort de t’obstiner à mettre les .run de Nvidia.
Sinon, essayes en faisant
export GCC=/usr/bin/gcc-4.1
export CC=/usr/bin/gcc-4.1
sh horreur.run
Ceci n’est pas un problême debian.
Si tu as un pb avec l’installer proprio nvidia, va voir chez nvidia.
Si tu veux une aide debian, utilises les paquets nvidia debian existants.
fran, tu ne devrais pas aider à l’utilisation de ces trucs opaques, il y a déjà saturation de pb avec tous les gens qui n’arrivent pas à se servir du module-assistant.
M’étant batu avec ma carte nvidia hier, j’ai résolu tous mes pb en installant le noyau 2.6.22, avec le 2.6.21, ca ne passait pas…
oups c’est aussi que j’avais aussi tester avec la vertion libre.
résulta sa plante, en suivant le tuto dans truc et astuce
:blush:
mattotop a rouspéter :laughing:
Grrr :smt011.
La principal caliter que j’apprécie sous linux c’est justement l’aide fournie sou linux et de la communauté. Le libre ne permet pas de tout faire, notamment la “simpliciter”, il n’y a qu’a voire le nombre de problème concernant la configuration de presque chaque logiciel. De plus je trouve plutôt sympa que nvidia fournisse aux moins 1 option simple d’utilisation d’ou le .run.
il serait donc temps que Debian propose quelque chose de semblable dans le gestionnaire de paquet , qui est prévu dans ce but et sans a avoir a ce taper 36 commande.
Je reconnaît que le fait que cela ne soie pas libre cela soie le coter obscure de la force. Mai je persiste dans le faite que. Pour que debian soie attractif, plus c’est simple et plus sa va plaire. le .run va dans ce sens.
On pourrai donc faire de même.:smt024
il serai possible de faire un script pour les driver qui son proposer dans le forum truc et astuce, et surtout maintenu a jours ? Cela me semble être une bonne solution, ainsi le .run serai moins attractif.:smt111
Le roseaux doit plier plutôt que de casser 8)
bon : la suite 8)
le problème est résolut en ce qui concerne le kamikaze.run :laughing:
Merci a fran.b pour la commande export j’ai aux moin apris quelque chose qui va certainement me re-servire et pas forcément rien que pour les driver nvidia.
donc pour montrer la manière de faire pour les driver libre, puis que d’après ce que j’ai compris les legacy son proprio, ce qui reviens aux même que le kamikaze.run
j’utilise un fichier log. grâce a la commande script ‘‘mon_fichier’’
donc pour ne pas polluer le topic avec mes commande dison de débutant :laughing:
je les ait placer ici.
panthere-noire.com/linux/log … lation.tar
P.s
noter que les commande pour les driver libre nvidia on été faites après la suppression de la paravirtuatruc :laughing:
