J’ajoute le dmesg que j’obtiens en mode dépannage.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-45) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Sun May 6 04:00:17 UTC 2012
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=152557ae-f68b-4cfe-8806-efbb8710370d ro single
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
[ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d2000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bfed0000 (usable)
[ 0.000000] BIOS-e820: 00000000bfed0000 - 00000000bfedc000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bfedc000 - 00000000bfede000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bfede000 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xbfed0 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-E3FFF uncachable
[ 0.000000] E4000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 base 0080000000 mask FFC0000000 write-back
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000bfed0000
[ 0.000000] 0000000000 - 00bfe00000 page 2M
[ 0.000000] 00bfe00000 - 00bfed0000 page 4k
[ 0.000000] kernel direct mapping tables up to bfed0000 @ 10000-15000
[ 0.000000] RAMDISK: 37710000 - 37fef54f
[ 0.000000] ACPI: RSDP 00000000000f81c0 00024 (v02 PacBel)
[ 0.000000] ACPI: XSDT 00000000bfed2c23 0005C (v01 PacBel PBNB0020 00319000 LTP 00000000)
[ 0.000000] ACPI: FACP 00000000bfedb898 000F4 (v03 PacBel PBNB0020 00319000 ATI 000F4240)
[ 0.000000] ACPI: DSDT 00000000bfed2c7f 08C19 (v01 PacBel PBNB0020 00319000 MSFT 03000001)
[ 0.000000] ACPI: FACS 00000000bfeddfc0 00040
[ 0.000000] ACPI: TCPA 00000000bfedba00 00032 (v02 PacBel PBNB0020 00319000 PTEC 00000000)
[ 0.000000] ACPI: SLIC 00000000bfedba32 00176 (v00 PacBel PBNB0020 00319000 00000000)
[ 0.000000] ACPI: SSDT 00000000bfedbba8 00386 (v01 PacBel PBNB0020 00319000 LTP 00000001)
[ 0.000000] ACPI: APIC 00000000bfedbf2e 0005E (v01 PacBel PBNB0020 00319000 LTP 00000000)
[ 0.000000] ACPI: MCFG 00000000bfedbf8c 0003C (v01 PacBel PBNB0020 00319000 LTP 00000000)
[ 0.000000] ACPI: HPET 00000000bfedbfc8 00038 (v01 PacBel PBNB0020 00319000 LTP 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Scanning NUMA topology in Northbridge 24
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at 0000000000000000-00000000bfed0000
[ 0.000000] Bootmem setup node 0 0000000000000000-00000000bfed0000
[ 0.000000] NODE_DATA [0000000000013000 - 000000000001afff]
[ 0.000000] bootmap [000000000001b000 - 0000000000032fdf] pages 18
[ 0.000000] (7 early reservations) ==> bootmem [0000000000 - 00bfed0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
[ 0.000000] #2 [0001000000 - 00016d95c4] TEXT DATA BSS ==> [0001000000 - 00016d95c4]
[ 0.000000] #3 [0037710000 - 0037fef54f] RAMDISK ==> [0037710000 - 0037fef54f]
[ 0.000000] #4 [000009dc00 - 0000100000] BIOS reserved ==> [000009dc00 - 0000100000]
[ 0.000000] #5 [00016da000 - 00016da125] BRK ==> [00016da000 - 00016da125]
[ 0.000000] #6 [0000010000 - 0000013000] PGTABLE ==> [0000010000 - 0000013000]
[ 0.000000] found SMP MP-table at [ffff8800000f8280] f8280
[ 0.000000] [ffffea0000000000-ffffea00029fffff] PMD -> [ffff880001c00000-ffff8800045fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00100000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000bfed0
[ 0.000000] On node 0 totalpages: 786013
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 104 pages reserved
[ 0.000000] DMA zone: 3821 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 10692 pages used for memmap
[ 0.000000] DMA32 zone: 771340 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x8008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x43538301 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000d2000
[ 0.000000] PM: Registered nosave memory: 00000000000d2000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:20000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff880001800000 s90328 r8192 d24360 u1048576
[ 0.000000] pcpu-alloc: s90328 r8192 d24360 u1048576 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 775161
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=152557ae-f68b-4cfe-8806-efbb8710370d ro single
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Checking aperture...
[ 0.000000] No AGP bridge found
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 3084376k/3144512k available (3083k kernel code, 460k absent, 59676k reserved, 2048k data, 592k init)
[ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:4352 nr_irqs:424
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1999.906 MHz processor.
[ 0.008005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3999.80 BogoMIPS (lpj=7999612)
[ 0.008132] Security Framework initialized
[ 0.008188] SELinux: Disabled at boot.
[ 0.008695] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.013598] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.014898] Mount-cache hash table entries: 256
[ 0.015138] Initializing cgroup subsys ns
[ 0.015194] Initializing cgroup subsys cpuacct
[ 0.015249] Initializing cgroup subsys devices
[ 0.015303] Initializing cgroup subsys freezer
[ 0.015357] Initializing cgroup subsys net_cls
[ 0.015441] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.015497] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.015551] CPU 0/0x0 -> Node 0
[ 0.015604] tseg: 00bff00000
[ 0.015606] CPU: Physical Processor ID: 0
[ 0.015658] CPU: Processor Core ID: 0
[ 0.015712] mce: CPU supports 5 MCE banks
[ 0.015777] Performance Events: AMD PMU driver.
[ 0.015879] ... version: 0
[ 0.015932] ... bit width: 48
[ 0.016009] ... generic registers: 4
[ 0.016061] ... value mask: 0000ffffffffffff
[ 0.016114] ... max period: 00007fffffffffff
[ 0.016168] ... fixed-purpose events: 0
[ 0.016220] ... event mask: 000000000000000f
[ 0.017387] ACPI: Core revision 20090903
[ 0.028108] Setting APIC routing to flat
[ 0.028466] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.070147] CPU0: AMD Turion(tm) X2 Dual-Core Mobile RM-70 stepping 01
[ 0.072001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.012000] Initializing CPU#1
[ 0.012000] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.012000] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.012000] CPU 1/0x1 -> Node 0
[ 0.012000] CPU: Physical Processor ID: 0
[ 0.012000] CPU: Processor Core ID: 1
[ 0.156070] CPU1: AMD Turion(tm) X2 Dual-Core Mobile RM-70 stepping 01
[ 0.156554] checking TSC synchronization [CPU#0 -> CPU#1]:
[ 0.160001] Measured 107939373 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.160001] Marking TSC unstable due to check_tsc_sync_source failed
[ 0.160017] Brought up 2 CPUs
[ 0.160069] Total of 2 processors activated (7990.00 BogoMIPS).
[ 0.160506] CPU0 attaching sched-domain:
[ 0.160511] domain 0: span 0-1 level MC
[ 0.160514] groups: group ffff88000180fbf0 cpus 0 group ffff88000190fbf0 cpus 1
[ 0.160523] CPU1 attaching sched-domain:
[ 0.160525] domain 0: span 0-1 level MC
[ 0.160528] groups: group ffff88000190fbf0 cpus 1 group ffff88000180fbf0 cpus 0
[ 0.160608] devtmpfs: initialized
[ 0.165548] regulator: core version 0.5
[ 0.165548] NET: Registered protocol family 16
[ 0.165548] TOM: 00000000c0000000 aka 3072M
[ 0.165548] Fam 10h mmconf [e0000000, efffffff]
[ 0.165548] ACPI: bus type pci registered
[ 0.165548] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 15
[ 0.165548] PCI: MCFG area at e0000000 reserved in E820
[ 0.165548] PCI: Using MMCONFIG at e0000000 - e0ffffff
[ 0.165548] PCI: Using configuration type 1 for base access
[ 0.168051] bio: create slab <bio-0> at 0
[ 0.168639] ACPI: EC: Look up EC in DSDT
[ 0.173260] ACPI: BIOS _OSI(Linux) query ignored
[ 0.174217] ACPI: Interpreter enabled
[ 0.174305] ACPI: (supports S0 S3 S4 S5)
[ 0.174555] ACPI: Using IOAPIC for interrupt routing
[ 0.175160] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 0.180886] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 0.184348] ACPI: EC: GPE = 0x3, I/O: command/status = 0x66, data = 0x62
[ 0.184500] ACPI: Power Resource [QFAN] (off)
[ 0.184749] ACPI: No dock devices found.
[ 0.185917] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.186229] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.186320] pci 0000:00:02.0: PME# disabled
[ 0.186441] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.186530] pci 0000:00:04.0: PME# disabled
[ 0.186652] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.186741] pci 0000:00:06.0: PME# disabled
[ 0.186860] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.186949] pci 0000:00:07.0: PME# disabled
[ 0.187070] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 0.187159] pci 0000:00:09.0: PME# disabled
[ 0.187275] pci 0000:00:11.0: reg 10 io port: [0x8430-0x8437]
[ 0.187284] pci 0000:00:11.0: reg 14 io port: [0x8424-0x8427]
[ 0.187293] pci 0000:00:11.0: reg 18 io port: [0x8428-0x842f]
[ 0.187301] pci 0000:00:11.0: reg 1c io port: [0x8420-0x8423]
[ 0.187309] pci 0000:00:11.0: reg 20 io port: [0x8400-0x840f]
[ 0.187318] pci 0000:00:11.0: reg 24 32bit mmio: [0xf8608000-0xf86083ff]
[ 0.187341] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.187465] pci 0000:00:12.0: reg 10 32bit mmio: [0xf8604000-0xf8604fff]
[ 0.187540] pci 0000:00:12.1: reg 10 32bit mmio: [0xf8605000-0xf8605fff]
[ 0.187633] pci 0000:00:12.2: reg 10 32bit mmio: [0xf8608400-0xf86084ff]
[ 0.187712] pci 0000:00:12.2: supports D1 D2
[ 0.187715] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.187772] pci 0000:00:12.2: PME# disabled
[ 0.188042] pci 0000:00:13.0: reg 10 32bit mmio: [0xf8606000-0xf8606fff]
[ 0.188117] pci 0000:00:13.1: reg 10 32bit mmio: [0xf8607000-0xf8607fff]
[ 0.188211] pci 0000:00:13.2: reg 10 32bit mmio: [0xf8608800-0xf86088ff]
[ 0.188290] pci 0000:00:13.2: supports D1 D2
[ 0.188293] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.188349] pci 0000:00:13.2: PME# disabled
[ 0.188556] pci 0000:00:14.1: reg 10 io port: [0x1f0-0x1f7]
[ 0.188565] pci 0000:00:14.1: reg 14 io port: [0x3f4-0x3f7]
[ 0.188573] pci 0000:00:14.1: reg 18 io port: [0x170-0x177]
[ 0.188582] pci 0000:00:14.1: reg 1c io port: [0x374-0x377]
[ 0.188591] pci 0000:00:14.1: reg 20 io port: [0x8410-0x841f]
[ 0.188685] pci 0000:00:14.2: reg 10 64bit mmio: [0xf8600000-0xf8603fff]
[ 0.188747] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.188804] pci 0000:00:14.2: PME# disabled
[ 0.192298] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.192306] pci 0000:01:00.0: reg 14 io port: [0x9000-0x90ff]
[ 0.192313] pci 0000:01:00.0: reg 18 32bit mmio: [0xf8100000-0xf810ffff]
[ 0.192333] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.192377] pci 0000:01:00.0: supports D1 D2
[ 0.192419] pci 0000:01:00.1: reg 10 32bit mmio: [0xf8110000-0xf8113fff]
[ 0.192484] pci 0000:01:00.1: supports D1 D2
[ 0.200096] pci 0000:00:02.0: bridge io port: [0x9000-0x9fff]
[ 0.200101] pci 0000:00:02.0: bridge 32bit mmio: [0xf8100000-0xf81fffff]
[ 0.200107] pci 0000:00:02.0: bridge 64bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.200153] pci 0000:02:00.0: reg 10 32bit mmio: [0xf8200000-0xf820ffff]
[ 0.200234] pci 0000:02:00.0: PME# supported from D0 D3hot
[ 0.200324] pci 0000:02:00.0: PME# disabled
[ 0.208100] pci 0000:00:04.0: bridge 32bit mmio: [0xf8200000-0xf82fffff]
[ 0.208150] pci 0000:03:00.0: reg 10 io port: [0xa000-0xa0ff]
[ 0.208169] pci 0000:03:00.0: reg 18 64bit mmio pref: [0xf8010000-0xf8010fff]
[ 0.208183] pci 0000:03:00.0: reg 20 64bit mmio pref: [0xf8000000-0xf800ffff]
[ 0.208191] pci 0000:03:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.208250] pci 0000:03:00.0: supports D1 D2
[ 0.208252] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.208343] pci 0000:03:00.0: PME# disabled
[ 0.216099] pci 0000:00:06.0: bridge io port: [0xa000-0xafff]
[ 0.216107] pci 0000:00:06.0: bridge 64bit mmio pref: [0xf8000000-0xf80fffff]
[ 0.216163] pci 0000:00:07.0: bridge io port: [0x00-0xfff]
[ 0.216167] pci 0000:00:07.0: bridge 32bit mmio: [0x000000-0x0fffff]
[ 0.216173] pci 0000:00:07.0: bridge 64bit mmio pref: [0x000000-0x0fffff]
[ 0.216228] pci 0000:0a:00.0: reg 10 32bit mmio: [0xf8300800-0xf8300fff]
[ 0.216240] pci 0000:0a:00.0: reg 14 32bit mmio: [0xf8301000-0xf830107f]
[ 0.216266] pci 0000:0a:00.0: reg 20 32bit mmio: [0xf8300400-0xf830047f]
[ 0.216277] pci 0000:0a:00.0: reg 24 32bit mmio: [0xf8300000-0xf830007f]
[ 0.216405] pci 0000:0a:00.1: reg 10 32bit mmio: [0xf8301400-0xf83014ff]
[ 0.216550] pci 0000:0a:00.2: reg 10 32bit mmio: [0xf8301800-0xf83018ff]
[ 0.216695] pci 0000:0a:00.3: reg 10 32bit mmio: [0xf8301c00-0xf8301cff]
[ 0.224128] pci 0000:00:09.0: bridge 32bit mmio: [0xf8300000-0xf83fffff]
[ 0.224199] pci 0000:00:14.4: transparent bridge
[ 0.224285] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.224538] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PB2_._PRT]
[ 0.224625] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PB4_._PRT]
[ 0.224707] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PB6_._PRT]
[ 0.224782] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PB7_._PRT]
[ 0.224861] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PB9_._PRT]
[ 0.225008] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT]
[ 0.231300] ACPI: PCI Interrupt Link [LNKA] (IRQs 10 11) *0, disabled.
[ 0.231778] ACPI: PCI Interrupt Link [LNKB] (IRQs 10 11) *0, disabled.
[ 0.232248] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 11) *0, disabled.
[ 0.232718] ACPI: PCI Interrupt Link [LNKD] (IRQs 10 11) *0, disabled.
[ 0.233190] ACPI: PCI Interrupt Link [LNKE] (IRQs 10 11) *0, disabled.
[ 0.233663] ACPI: PCI Interrupt Link [LNKF] (IRQs 10 11) *0, disabled.
[ 0.234133] ACPI: PCI Interrupt Link [LNKG] (IRQs 10 11) *0, disabled.
[ 0.234606] ACPI: PCI Interrupt Link [LNKH] (IRQs 10 11) *0, disabled.
[ 0.235083] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.235181] vgaarb: loaded
[ 0.236058] PCI: Using ACPI for IRQ routing
[ 0.236151] pci 0000:00:07.0: BAR 13: can't allocate resource
[ 0.236205] pci 0000:00:07.0: BAR 14: can't allocate resource
[ 0.236260] pci 0000:00:07.0: BAR 15: can't allocate resource
[ 0.236645] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.236924] hpet0: 4 comparators, 32-bit 14.318180 MHz counter
[ 0.239005] Switching to clocksource hpet
[ 0.239065] pnp: PnP ACPI init
[ 0.239065] ACPI: bus type pnp registered
[ 0.243189] pnp: PnP ACPI: found 12 devices
[ 0.243277] ACPI: ACPI bus type pnp unregistered
[ 0.243347] system 00:01: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.243406] system 00:01: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.243472] system 00:08: ioport range 0x220-0x22f has been reserved
[ 0.243558] system 00:08: ioport range 0x40b-0x40b has been reserved
[ 0.243618] system 00:08: ioport range 0x4d0-0x4d1 has been reserved
[ 0.243673] system 00:08: ioport range 0x4d6-0x4d6 has been reserved
[ 0.243746] system 00:08: ioport range 0x530-0x537 has been reserved
[ 0.243802] system 00:08: ioport range 0xc00-0xc01 has been reserved
[ 0.243885] system 00:08: ioport range 0xc14-0xc14 has been reserved
[ 0.243945] system 00:08: ioport range 0xc50-0xc52 has been reserved
[ 0.244001] system 00:08: ioport range 0xc6c-0xc6c has been reserved
[ 0.244079] system 00:08: ioport range 0xc6f-0xc6f has been reserved
[ 0.244152] system 00:08: ioport range 0xcd0-0xcd1 has been reserved
[ 0.244208] system 00:08: ioport range 0xcd2-0xcd3 has been reserved
[ 0.244289] system 00:08: ioport range 0xcd4-0xcd5 has been reserved
[ 0.244344] system 00:08: ioport range 0xcd6-0xcd7 has been reserved
[ 0.244400] system 00:08: ioport range 0xcd8-0xcdf has been reserved
[ 0.244455] system 00:08: ioport range 0x8000-0x805f has been reserved
[ 0.244510] system 00:08: ioport range 0xf40-0xf47 has been reserved
[ 0.244565] system 00:08: ioport range 0x87f-0x87f has been reserved
[ 0.244627] system 00:09: iomem range 0xe0000-0xfffff could not be reserved
[ 0.244684] system 00:09: iomem range 0xfff00000-0xffffffff has been reserved
[ 0.250066] pci 0000:00:02.0: PCI bridge, secondary bus 0000:01
[ 0.250123] pci 0000:00:02.0: IO window: 0x9000-0x9fff
[ 0.250180] pci 0000:00:02.0: MEM window: 0xf8100000-0xf81fffff
[ 0.250236] pci 0000:00:02.0: PREFETCH window: 0x000000f0000000-0x000000f7ffffff
[ 0.250299] pci 0000:00:04.0: PCI bridge, secondary bus 0000:02
[ 0.250353] pci 0000:00:04.0: IO window: 0x1000-0x1fff
[ 0.250409] pci 0000:00:04.0: MEM window: 0xf8200000-0xf82fffff
[ 0.250465] pci 0000:00:04.0: PREFETCH window: 0x000000c0000000-0x000000c01fffff
[ 0.250527] pci 0000:00:06.0: PCI bridge, secondary bus 0000:03
[ 0.250582] pci 0000:00:06.0: IO window: 0xa000-0xafff
[ 0.250637] pci 0000:00:06.0: MEM window: 0xc0200000-0xc02fffff
[ 0.250692] pci 0000:00:06.0: PREFETCH window: 0x000000f8000000-0x000000f80fffff
[ 0.250753] pci 0000:00:07.0: PCI bridge, secondary bus 0000:04
[ 0.250808] pci 0000:00:07.0: IO window: 0x2000-0x2fff
[ 0.250863] pci 0000:00:07.0: MEM window: 0xc0300000-0xc04fffff
[ 0.250919] pci 0000:00:07.0: PREFETCH window: 0x000000c0500000-0x000000c06fffff
[ 0.250981] pci 0000:00:09.0: PCI bridge, secondary bus 0000:0a
[ 0.251035] pci 0000:00:09.0: IO window: disabled
[ 0.251089] pci 0000:00:09.0: MEM window: 0xf8300000-0xf83fffff
[ 0.251144] pci 0000:00:09.0: PREFETCH window: disabled
[ 0.251201] pci 0000:00:14.4: PCI bridge, secondary bus 0000:0b
[ 0.251254] pci 0000:00:14.4: IO window: disabled
[ 0.251311] pci 0000:00:14.4: MEM window: disabled
[ 0.251366] pci 0000:00:14.4: PREFETCH window: disabled
[ 0.251436] alloc irq_desc for 18 on node -1
[ 0.251439] alloc kstat_irqs on node -1
[ 0.251448] pci 0000:00:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.251506] pci 0000:00:02.0: setting latency timer to 64
[ 0.251515] alloc irq_desc for 16 on node -1
[ 0.251517] alloc kstat_irqs on node -1
[ 0.251522] pci 0000:00:04.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.251578] pci 0000:00:04.0: setting latency timer to 64
[ 0.251587] pci 0000:00:06.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.251642] pci 0000:00:06.0: setting latency timer to 64
[ 0.251650] pci 0000:00:07.0: enabling device (0000 -> 0003)
[ 0.251705] alloc irq_desc for 19 on node -1
[ 0.251708] alloc kstat_irqs on node -1
[ 0.251712] pci 0000:00:07.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.251769] pci 0000:00:07.0: setting latency timer to 64
[ 0.251777] alloc irq_desc for 17 on node -1
[ 0.251779] alloc kstat_irqs on node -1
[ 0.251784] pci 0000:00:09.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.251840] pci 0000:00:09.0: setting latency timer to 64
[ 0.251851] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.251854] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
[ 0.251857] pci_bus 0000:01: resource 0 io: [0x9000-0x9fff]
[ 0.251860] pci_bus 0000:01: resource 1 mem: [0xf8100000-0xf81fffff]
[ 0.251863] pci_bus 0000:01: resource 2 pref mem [0xf0000000-0xf7ffffff]
[ 0.251867] pci_bus 0000:02: resource 0 io: [0x1000-0x1fff]
[ 0.251870] pci_bus 0000:02: resource 1 mem: [0xf8200000-0xf82fffff]
[ 0.251873] pci_bus 0000:02: resource 2 pref mem [0xc0000000-0xc01fffff]
[ 0.251877] pci_bus 0000:03: resource 0 io: [0xa000-0xafff]
[ 0.251879] pci_bus 0000:03: resource 1 mem: [0xc0200000-0xc02fffff]
[ 0.251882] pci_bus 0000:03: resource 2 pref mem [0xf8000000-0xf80fffff]
[ 0.251885] pci_bus 0000:04: resource 0 io: [0x2000-0x2fff]
[ 0.251889] pci_bus 0000:04: resource 1 mem: [0xc0300000-0xc04fffff]
[ 0.251892] pci_bus 0000:04: resource 2 pref mem [0xc0500000-0xc06fffff]
[ 0.251895] pci_bus 0000:0a: resource 1 mem: [0xf8300000-0xf83fffff]
[ 0.251898] pci_bus 0000:0b: resource 3 io: [0x00-0xffff]
[ 0.251901] pci_bus 0000:0b: resource 4 mem: [0x000000-0xffffffffffffffff]
[ 0.251946] NET: Registered protocol family 2
[ 0.252225] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.254398] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.259561] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.260275] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.260368] TCP reno registered
[ 0.260550] NET: Registered protocol family 1
[ 0.260678] pci 0000:00:12.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.260766] pci 0000:00:12.0: PCI INT A disabled
[ 0.260825] pci 0000:00:12.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.260893] pci 0000:00:12.1: PCI INT A disabled
[ 0.260958] pci 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.261057] pci 0000:00:12.2: PCI INT B disabled
[ 0.261118] pci 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.261185] pci 0000:00:13.0: PCI INT A disabled
[ 0.261244] pci 0000:00:13.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.261310] pci 0000:00:13.1: PCI INT A disabled
[ 0.261374] pci 0000:00:13.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.261443] pci 0000:00:13.2: PCI INT B disabled
[ 0.261515] pci 0000:01:00.0: Boot video device
[ 0.261597] Unpacking initramfs...
[ 0.517670] Freeing initrd memory: 9085k freed
[ 0.524362] audit: initializing netlink socket (disabled)
[ 0.524469] type=2000 audit(1343848730.524:1): initialized
[ 0.528426] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.530533] VFS: Disk quotas dquot_6.5.2
[ 0.530660] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.530844] msgmni has been set to 6041
[ 0.531742] alg: No test for stdrng (krng)
[ 0.531887] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.531981] io scheduler noop registered
[ 0.532038] io scheduler anticipatory registered
[ 0.532091] io scheduler deadline registered
[ 0.532219] io scheduler cfq registered (default)
[ 0.532474] alloc irq_desc for 24 on node -1
[ 0.532477] alloc kstat_irqs on node -1
[ 0.532491] pcieport 0000:00:02.0: irq 24 for MSI/MSI-X
[ 0.532500] pcieport 0000:00:02.0: setting latency timer to 64
[ 0.532616] alloc irq_desc for 25 on node -1
[ 0.532618] alloc kstat_irqs on node -1
[ 0.532625] pcieport 0000:00:04.0: irq 25 for MSI/MSI-X
[ 0.532631] pcieport 0000:00:04.0: setting latency timer to 64
[ 0.532762] alloc irq_desc for 26 on node -1
[ 0.532764] alloc kstat_irqs on node -1
[ 0.532771] pcieport 0000:00:06.0: irq 26 for MSI/MSI-X
[ 0.532778] pcieport 0000:00:06.0: setting latency timer to 64
[ 0.532883] alloc irq_desc for 27 on node -1
[ 0.532886] alloc kstat_irqs on node -1
[ 0.532892] pcieport 0000:00:07.0: irq 27 for MSI/MSI-X
[ 0.532898] pcieport 0000:00:07.0: setting latency timer to 64
[ 0.533338] alloc irq_desc for 28 on node -1
[ 0.533340] alloc kstat_irqs on node -1
[ 0.533348] pcieport 0000:00:09.0: irq 28 for MSI/MSI-X
[ 0.533354] pcieport 0000:00:09.0: setting latency timer to 64
[ 0.535613] Linux agpgart interface v0.103
[ 0.535773] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.536327] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 0.536486] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
[ 0.541304] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 0.543917] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.543977] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.544042] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.544095] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.544153] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.544305] mice: PS/2 mouse device common for all mice
[ 0.544436] rtc_cmos 00:04: RTC can wake from S4
[ 0.544533] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.544649] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.544716] cpuidle: using governor ladder
[ 0.544770] cpuidle: using governor menu
[ 0.544826] No iBFT detected.
[ 0.545309] TCP cubic registered
[ 0.545579] NET: Registered protocol family 10
[ 0.546540] Mobile IPv6
[ 0.546626] NET: Registered protocol family 17
[ 0.546786] PM: Resume from disk failed.
[ 0.546806] registered taskstats version 1
[ 0.547623] rtc_cmos 00:04: setting system clock to 2012-08-01 19:18:51 UTC (1343848731)
[ 0.547748] Initalizing network drop monitor service
[ 0.547875] Freeing unused kernel memory: 592k freed
[ 0.548268] Write protecting the kernel read-only data: 4240k
[ 0.573931] udev[56]: starting version 164
[ 0.583539] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.695678] thermal LNXTHERM:01: registered as thermal_zone0
[ 0.695783] ACPI: Thermal Zone [THRM] (73 C)
[ 0.750122] usbcore: registered new interface driver usbfs
[ 0.750246] usbcore: registered new interface driver hub
[ 0.750478] sdhci: Secure Digital Host Controller Interface driver
[ 0.750538] sdhci: Copyright(c) Pierre Ossman
[ 0.751029] usbcore: registered new device driver usb
[ 0.761120] firewire_ohci 0000:0a:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.761222] firewire_ohci 0000:0a:00.0: setting latency timer to 64
[ 0.775791] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.775928] ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 0.776056] ehci_hcd 0000:00:12.2: EHCI Host Controller
[ 0.776141] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 0.776231] ehci_hcd 0000:00:12.2: applying AMD SB600/SB700 USB freeze workaround
[ 0.776304] ehci_hcd 0000:00:12.2: debug port 1
[ 0.776403] ehci_hcd 0000:00:12.2: irq 17, io mem 0xf8608400
[ 0.777277] SCSI subsystem initialized
[ 0.788049] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 0.788129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.788185] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.791507] usb usb1: Product: EHCI Host Controller
[ 0.791560] usb usb1: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 0.791614] usb usb1: SerialNumber: 0000:00:12.2
[ 0.791804] usb usb1: configuration #1 chosen from 1 choice
[ 0.791958] hub 1-0:1.0: USB hub found
[ 0.792075] hub 1-0:1.0: 6 ports detected
[ 0.792239] ehci_hcd 0000:00:13.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.792324] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 0.792387] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 0.792477] ehci_hcd 0000:00:13.2: applying AMD SB600/SB700 USB freeze workaround
[ 0.792549] ehci_hcd 0000:00:13.2: debug port 1
[ 0.792631] ehci_hcd 0000:00:13.2: irq 19, io mem 0xf8608800
[ 0.795410] libata version 3.00 loaded.
[ 0.802297] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.802421] r8169 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.802526] r8169 0000:03:00.0: setting latency timer to 64
[ 0.802567] alloc irq_desc for 29 on node -1
[ 0.802569] alloc kstat_irqs on node -1
[ 0.802586] r8169 0000:03:00.0: irq 29 for MSI/MSI-X
[ 0.803347] r8169 0000:03:00.0: eth0: RTL8102e at 0xffffc90002252000, 00:1e:68:f5:bb:da, XID 04a00000 IRQ 29
[ 0.804660] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.805653] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 0.805741] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.805797] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.805856] usb usb2: Product: EHCI Host Controller
[ 0.805909] usb usb2: Manufacturer: Linux 2.6.32-5-amd64 ehci_hcd
[ 0.805963] usb usb2: SerialNumber: 0000:00:13.2
[ 0.806126] usb usb2: configuration #1 chosen from 1 choice
[ 0.806237] hub 2-0:1.0: USB hub found
[ 0.806340] hub 2-0:1.0: 6 ports detected
[ 0.807129] pata_atiixp 0000:00:14.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.807343] fan PNP0C0B:00: registered as cooling_device0
[ 0.807442] ACPI: Fan [FAN] (off)
[ 0.811002] scsi0 : pata_atiixp
[ 0.811341] scsi1 : pata_atiixp
[ 0.813177] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x8410 irq 14
[ 0.813268] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x8418 irq 15
[ 0.813443] ohci_hcd 0000:00:12.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.813537] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 0.813607] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 3
[ 0.813714] ohci_hcd 0000:00:12.0: irq 16, io mem 0xf8604000
[ 0.841066] firewire_ohci: Added fw-ohci device 0000:0a:00.0, OHCI version 1.10
[ 0.841189] sdhci-pci 0000:0a:00.1: SDHCI controller found [197b:2382] (rev 0)
[ 0.841267] sdhci-pci 0000:0a:00.1: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.841362] sdhci-pci 0000:0a:00.1: setting latency timer to 64
[ 0.841415] Registered led device: mmc0::
[ 0.841531] mmc0: SDHCI controller on PCI [0000:0a:00.1] using DMA
[ 0.841640] sdhci-pci 0000:0a:00.2: SDHCI controller found [197b:2381] (rev 0)
[ 0.841712] sdhci-pci 0000:0a:00.2: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 0.841781] sdhci-pci 0000:0a:00.2: Refusing to bind to secondary interface.
[ 0.841842] sdhci-pci 0000:0a:00.2: PCI INT A disabled
[ 0.872071] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.872127] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.872185] usb usb3: Product: OHCI Host Controller
[ 0.872238] usb usb3: Manufacturer: Linux 2.6.32-5-amd64 ohci_hcd
[ 0.872292] usb usb3: SerialNumber: 0000:00:12.0
[ 0.872509] usb usb3: configuration #1 chosen from 1 choice
[ 0.872664] hub 3-0:1.0: USB hub found
[ 0.872761] hub 3-0:1.0: 3 ports detected
[ 0.872929] ahci 0000:00:11.0: version 3.0
[ 0.872947] alloc irq_desc for 22 on node -1
[ 0.872950] alloc kstat_irqs on node -1
[ 0.872959] ahci 0000:00:11.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 0.873197] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 0.873258] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 0.873958] scsi2 : ahci
[ 0.874264] scsi3 : ahci
[ 0.874465] scsi4 : ahci
[ 0.874661] scsi5 : ahci
[ 0.874881] ata3: SATA max UDMA/133 abar m1024@0xf8608000 port 0xf8608100 irq 22
[ 0.874942] ata4: SATA max UDMA/133 abar m1024@0xf8608000 port 0xf8608180 irq 22
[ 0.875002] ata5: SATA max UDMA/133 abar m1024@0xf8608000 port 0xf8608200 irq 22
[ 0.875072] ata6: SATA max UDMA/133 abar m1024@0xf8608000 port 0xf8608280 irq 22
[ 0.875274] ohci_hcd 0000:00:12.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.875373] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 0.875449] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 4
[ 0.875533] ohci_hcd 0000:00:12.1: irq 16, io mem 0xf8605000
[ 0.933093] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.933157] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.933217] usb usb4: Product: OHCI Host Controller
[ 0.933270] usb usb4: Manufacturer: Linux 2.6.32-5-amd64 ohci_hcd
[ 0.933323] usb usb4: SerialNumber: 0000:00:12.1
[ 0.933498] usb usb4: configuration #1 chosen from 1 choice
[ 0.933615] hub 4-0:1.0: USB hub found
[ 0.933678] hub 4-0:1.0: 3 ports detected
[ 0.933857] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.933948] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 0.934011] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 0.934109] ohci_hcd 0000:00:13.0: irq 18, io mem 0xf8606000
[ 0.992068] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.992124] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.992182] usb usb5: Product: OHCI Host Controller
[ 0.992236] usb usb5: Manufacturer: Linux 2.6.32-5-amd64 ohci_hcd
[ 0.992290] usb usb5: SerialNumber: 0000:00:13.0
[ 0.992418] usb usb5: configuration #1 chosen from 1 choice
[ 0.992533] hub 5-0:1.0: USB hub found
[ 0.992594] hub 5-0:1.0: 3 ports detected
[ 0.992710] ohci_hcd 0000:00:13.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.992781] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 0.992840] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 6
[ 0.992920] ohci_hcd 0000:00:13.1: irq 18, io mem 0xf8607000
[ 1.044108] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.044166] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.044224] usb usb6: Product: OHCI Host Controller
[ 1.044277] usb usb6: Manufacturer: Linux 2.6.32-5-amd64 ohci_hcd
[ 1.044331] usb usb6: SerialNumber: 0000:00:13.1
[ 1.044465] usb usb6: configuration #1 chosen from 1 choice
[ 1.044585] hub 6-0:1.0: USB hub found
[ 1.044647] hub 6-0:1.0: 3 ports detected
[ 1.105118] usb 1-3: new high speed USB device using ehci_hcd and address 2
[ 1.192091] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.192207] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.265541] usb 1-3: New USB device found, idVendor=05c8, idProduct=0116
[ 1.265605] usb 1-3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.265661] usb 1-3: Product: FE03FF-99-1
[ 1.265713] usb 1-3: Manufacturer: Foxlink
[ 1.265881] usb 1-3: configuration #1 chosen from 1 choice
[ 1.340169] firewire_core: created device fw0: GUID f9eb1be117ffffb2, S400
[ 1.356080] ata6: softreset failed (device not ready)
[ 1.356085] ata3: softreset failed (device not ready)
[ 1.356090] ata3: applying SB600 PMP SRST workaround and retrying
[ 1.356255] ata6: applying SB600 PMP SRST workaround and retrying
[ 1.520088] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.520092] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.520826] ata3.00: ATA-8: ST9250827AS, 3.AAA, max UDMA/133
[ 1.520886] ata3.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.521844] ata3.00: configured for UDMA/133
[ 1.523872] ata6.00: ATAPI: HL-DT-ST DVDRAM GSA-T50N, RP05, max UDMA/133
[ 1.528669] ata6.00: configured for UDMA/133
[ 1.537326] scsi 2:0:0:0: Direct-Access ATA ST9250827AS 3.AA PQ: 0 ANSI: 5
[ 1.588070] usb 5-2: new low speed USB device using ohci_hcd and address 2
[ 1.651209] scsi 5:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-T50N RP05 PQ: 0 ANSI: 5
[ 1.667881] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.668417] sd 2:0:0:0: [sda] Write Protect is off
[ 1.668479] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.668527] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.669063] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 1.711490] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.759111] usb 5-2: New USB device found, idVendor=045e, idProduct=0083
[ 1.759171] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.759227] usb 5-2: Product: Basic Optical Mouse
[ 1.759280] usb 5-2: Manufacturer: Microsoft
[ 1.759433] usb 5-2: configuration #1 chosen from 1 choice
[ 1.774671] usbcore: registered new interface driver hiddev
[ 1.780429] input: Microsoft Basic Optical Mouse as /devices/pci0000:00/0000:00:13.0/usb5/5-2/5-2:1.0/input/input2
[ 1.780625] generic-usb 0003:045E:0083.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-0000:00:13.0-2/input0
[ 1.780722] usbcore: registered new interface driver usbhid
[ 1.780779] usbhid: v2.6:USB HID core driver
[ 1.997953] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.998022] Uniform CD-ROM driver Revision: 3.20
[ 1.998204] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 2.006093] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.006587] sr 5:0:0:0: Attached scsi generic sg1 type 5
[ 2.755271] PM: Starting manual resume from disk
[ 2.755372] PM: Resume from partition 8:5
[ 2.755375] PM: Checking hibernation image.
[ 2.763120] PM: Error -22 checking image file
[ 2.763122] PM: Resume from disk failed.
[ 2.780903] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 2.784244] EXT3-fs: write access will be enabled during recovery.
[ 2.815592] kjournald starting. Commit interval 5 seconds
[ 2.815619] EXT3-fs: recovery complete.
[ 2.816051] EXT3-fs: mounted filesystem with ordered data mode.
[ 4.365689] udev[430]: starting version 164
[ 4.842136] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 4.842648] ACPI: Power Button [PWRB]
[ 4.842814] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 4.842909] ACPI: Sleep Button [SLPB]
[ 4.843061] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input5
[ 4.843292] processor LNXCPU:00: registered as cooling_device1
[ 4.843454] processor LNXCPU:01: registered as cooling_device2
[ 4.844408] ACPI: Lid Switch [LID0]
[ 4.844580] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 4.844679] ACPI: Power Button [PWRF]
[ 4.850442] ACPI: Battery Slot [BAT1] (battery absent)
[ 4.850650] ACPI: AC Adapter [ACAD] (off-line)
[ 4.916941] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 4.935795] [Firmware Bug]: ACPI: ACPI brightness control misses _BQC function
[ 4.963423] acpi device:01: registered as cooling_device3
[ 4.963976] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input8
[ 4.964083] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 5.538888] [drm] Initialized drm 1.1.0 20060810
[ 5.668108] Synaptics Touchpad, model: 1, fw: 7.0, id: 0x1e0b2, caps: 0xd04711/0xa00000/0x20000
[ 5.710921] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input9
[ 6.081431] rt2860sta: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.089094] rt2860 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 6.089216] rt2860 0000:02:00.0: setting latency timer to 64
[ 6.089533] === pAd = ffffc900025f2000, size = 525944 ===
[ 6.089623] <-- RTMPAllocAdapterBlock, Status=0
[ 6.089676] pAd->CSRBaseAddress =0xffffc900025e0000, csr_addr=0xffffc900025e0000!
[ 6.092414] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0x8040, revision 0
[ 6.135774] jmb38x_ms 0000:0a:00.3: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.135877] jmb38x_ms 0000:0a:00.3: setting latency timer to 64
[ 6.155365] EDAC MC: Ver: 2.1.0 May 6 2012
[ 6.168922] Linux video capture interface: v2.00
[ 6.186878] uvcvideo: Found UVC 1.00 device FE03FF-99-1 (05c8:0116)
[ 6.203670] input: FE03FF-99-1 as /devices/pci0000:00/0000:00:12.2/usb1/1-3/1-3:1.0/input/input10
[ 6.203810] usbcore: registered new interface driver uvcvideo
[ 6.203866] USB Video Class driver (v0.1.0)
[ 6.273251] EDAC amd64_edac: Ver: 3.2.0 May 6 2012
[ 6.273381] EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
[ 6.273484] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 6.273486] Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
[ 6.273488] (Note that use of the override may cause unknown side effects.)
[ 6.273665] amd64_edac: probe of 0000:00:18.2 failed with error -22
[ 6.416729] [drm] radeon kernel modesetting enabled.
[ 6.416921] radeon 0000:01:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 6.416980] radeon 0000:01:00.0: setting latency timer to 64
[ 6.420054] [drm] radeon: Initializing kernel modesetting.
[ 6.420496] [drm] register mmio base: 0xF8100000
[ 6.420583] [drm] register mmio size: 65536
[ 6.420783] ATOM BIOS: Packard
[ 6.420892] [drm] Clocks initialized !
[ 6.421225] [drm] Detected VRAM RAM=128M, BAR=128M
[ 6.421284] [drm] RAM width 128bits DDR
[ 6.421506] [TTM] Zone kernel: Available graphics memory: 1547028 kiB.
[ 6.421591] [drm] radeon: 128M of VRAM memory ready
[ 6.421646] [drm] radeon: 512M of GTT memory ready.
[ 6.421765] alloc irq_desc for 30 on node -1
[ 6.421768] alloc kstat_irqs on node -1
[ 6.421784] radeon 0000:01:00.0: irq 30 for MSI/MSI-X
[ 6.421791] radeon 0000:01:00.0: radeon: using MSI.
[ 6.421913] [drm] radeon: irq initialized.
[ 6.421967] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 6.423196] [drm] Loading RV635 Microcode
[ 6.423938] platform radeon_cp.0: firmware: requesting radeon/RV635_pfp.bin
[ 6.827910] r600_cp: Failed to load firmware "radeon/RV635_pfp.bin"
[ 6.828036] [drm:r600_startup] *ERROR* Failed to load firmware!
[ 6.828092] radeon 0000:01:00.0: disabling GPU acceleration
[ 6.828179] radeon 0000:01:00.0: ffff88003784e200 unpin not necessary
[ 6.828234] radeon 0000:01:00.0: ffff88003784e200 unpin not necessary
[ 6.828309] [drm] Enabling audio support
[ 6.828584] [drm] Radeon Display Connectors
[ 6.828718] [drm] Connector 0:
[ 6.828769] [drm] LVDS
[ 6.828821] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 6.828879] [drm] Encoders:
[ 6.828930] [drm] LCD1: INTERNAL_KLDSCP_LVTMA
[ 6.828983] [drm] Connector 1:
[ 6.829037] [drm] HDMI-A
[ 6.829087] [drm] HPD2
[ 6.829139] [drm] DDC: 0x7e60 0x7e60 0x7e64 0x7e64 0x7e68 0x7e68 0x7e6c 0x7e6c
[ 6.829196] [drm] Encoders:
[ 6.829248] [drm] DFP1: INTERNAL_UNIPHY
[ 6.829300] [drm] Connector 2:
[ 6.829351] [drm] DVI-I
[ 6.829402] [drm] HPD1
[ 6.829453] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 6.829512] [drm] Encoders:
[ 6.829563] [drm] DFP2: INTERNAL_UNIPHY
[ 6.829615] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 6.968176] [drm] fb mappable at 0xF0040000
[ 6.968267] [drm] vram apper at 0xF0000000
[ 6.968320] [drm] size 5299200
[ 6.968371] [drm] fb depth is 24
[ 6.968423] [drm] pitch is 5888
[ 7.070770] HDA Intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 7.166457] hda_codec: ALC272: BIOS auto-probing.
[ 7.167724] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/input/input11
[ 7.911456] Console: switching to colour frame buffer device 180x56
[ 7.917983] fb0: radeondrmfb frame buffer device
[ 7.917985] registered panic notifier
[ 7.918067] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 7.918227] HDA Intel 0000:01:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 7.918348] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 8.722010] Adding 4787328k swap on /dev/sda5. Priority:-1 extents:1 across:4787328k
[ 9.014368] EXT3 FS on sda3, internal journal
[ 9.168892] loop: module loaded
[ 9.813418] kjournald starting. Commit interval 5 seconds
[ 9.813701] EXT3 FS on sda6, internal journal
[ 9.813745] EXT3-fs: mounted filesystem with ordered data mode.
[ 10.493587] fuse init (API version 7.13)
[ 15.598294] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input12
[ 16.377872] rt2860 0000:02:00.0: firmware: requesting rt2860.bin
[ 16.519140] RX DESC ffff8800bdc5d000 size = 2048
[ 16.521821] <-- RTMPAllocTxRxRingMemory, Status=0
[ 16.526097] 1. Phy Mode = 0
[ 16.528130] 2. Phy Mode = 0
[ 16.545620] RTMPSetPhyMode: channel is out of range, use first channel=1
[ 16.551502] CfgSetCountryRegion():CountryRegion in eeprom was programmed
[ 16.553593] CfgSetCountryRegion():CountryRegion in eeprom was programmed
[ 16.555643] 3. Phy Mode = 0
[ 16.557656] ERROR! ****** BBP_Write_Latch Buffer exceeds max boundry ******
[ 16.559649] ERROR! ****** BBP_Write_Latch Buffer exceeds max boundry ******
[ 16.561677] ERROR! ****** BBP_Write_Latch Buffer exceeds max boundry ******
[ 16.586820] MCS Set = 00 00 00 00 00
[ 16.590321] <==== rt28xx_init, Status=0
[ 16.592245] 0x1300 = 00073200
[ 16.601035] r8169 0000:03:00.0: eth0: link down
[ 16.602931] r8169 0000:03:00.0: eth0: link down
[ 16.605650] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.210160] r8169 0000:03:00.0: eth0: link up
[ 18.212771] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.015172] Bluetooth: Core ver 2.15
[ 20.015274] NET: Registered protocol family 31
[ 20.015274] Bluetooth: HCI device and connection manager initialized
[ 20.015277] Bluetooth: HCI socket layer initialized
[ 20.064705] Bluetooth: L2CAP ver 2.14
[ 20.064709] Bluetooth: L2CAP socket layer initialized
[ 20.101698] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.101702] Bluetooth: BNEP filters: protocol multicast
[ 20.106619] Bluetooth: RFCOMM TTY layer initialized
[ 20.106626] Bluetooth: RFCOMM socket layer initialized
[ 20.106629] Bluetooth: RFCOMM ver 1.11
[ 20.133036] Bridge firewalling registered
[ 20.175594] Bluetooth: SCO (Voice Link) ver 0.6
[ 20.175599] Bluetooth: SCO socket layer initialized
[ 20.742777] lp: driver loaded but no devices found
[ 20.862038] ppdev: user-space parallel port driver
[ 22.291788] powernow-k8: Found 1 AMD Turion(tm) X2 Dual-Core Mobile RM-70 processors (2 cpu cores) (version 2.20.00)
[ 22.291848] powernow-k8: 0 : pstate 0 (2000 MHz)
[ 22.291850] powernow-k8: 1 : pstate 1 (1000 MHz)
[ 22.291853] powernow-k8: 2 : pstate 2 (500 MHz)
[ 22.364255] ===>rt_ioctl_giwscan. 1(1) BSS returned, data->length = 160
[ 27.192076] wlan0: no IPv6 routers present
[ 28.761063] eth0: no IPv6 routers present
[ 43.053964] ===>rt_ioctl_giwscan. 2(2) BSS returned, data->length = 348
[ 73.054195] ===>rt_ioctl_giwscan. 1(1) BSS returned, data->length = 160
M’étonnerait pas que ça vienne de la carte ATI Radeon…
