Oh no something has gone wrong. après l'installation de nvidia-driver
Bonjour/Bonsoir,
j’ai suivi ce tutoriel pour installer les drivers nvidia Version 367.44 (à partir du dépôt jessie-backports)
et quant j’ai restart via “reboot” j’ai plus d’affichage depuis
Log : /var/log/Xorg.0.log Pastebin
“uname -a” = “Linux asus 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux”
pas assez d’informations sur votre materiel. Que disent les commandes:
$lspci | egrep ‘VGA|3D|Display’
ainsi que
$ lspci
C’est un portable que vous avez?
Merci de votre réponse
lspci | egrep ‘VGA|3D|Display’ =
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce 610M] (rev a1)
Screen: http://prntscr.com/dvui83
lspci =
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5)
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
04:00.0 Ethernet controller: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet (rev c0)
Screen: http://prntscr.com/dvuiu1
Modèle du PC: Asus X73S
Screen: Asus X73S
vous avez optimus et dans ce cas il ne faut surtout PAS installer le pilote nvidia proprio, il faut passer par bumblebee; que je ne connais pas n’ayant jamais eu à l’utiliser. Mais il y a de la doc:
https://wiki.debian-fr.xyz/NVidia_Optimus_Bumblebee
https://debian-facile.org/doc:materiel:cartes-graphique:nvidia:optimus?s[]=optimus
je vien de voir effectiment bon je regarde et je tien au courant
j’ai plus d’interface graphique…
j’ai suivi ce tutoriel https://wiki.debian-fr.xyz/NVidia_Optimus_Bumblebee
et a l’étape:
Configurez !
Avec les droits administrateur, il vous faut ensuite ajouter votre utilisateur au groupe bumblebee :
# adduser ID_USER bumblebee
 NOTE : Redémarrer votre ordinateur ;-)
quant je reboot bah je me retrouve en mode terminal.
je me connect avec mon user non-root et la commande startx n’est plus reconnu (je sais plus si c’est sa pour demarrer gnome mais je m’en servais avant de commencer a installer les drivers nvidia)
comme je vous l’ai dit plus haut je n’ai moi même aucune expérience concernant optimus/bumblebee; il va falloir attendre qu’une personne expérimentée dans cette question passe par là; pour augmenter vos chances et gagner du temps posez aussi la question sur les deux autres forums que je vous ai indiqués.
je vais voir si je reinstalle et que je refait le tuto je pense avoir niqué mon gnome…
Je te redirige vers le Sujet que j’ai créé sur ce sujet: Oh no ! Something has gone wrong
J’ai du re-installer mon systeme parce que j’avais pas d’autres moyens. J’ai meme essayé d’installer KDE et Supprimer GNOME en ligne de commande, mais cela n’a rien donné.
Je pense que si Mescal81 ( Installer nvidia 375.26 ) installe le pilote, il sera dans le meme cas que toi. Voici ce je lui ai répondu sur son sujet
j’ai commandé une batterie 7200mAh j’ai réinstallé debian 8 (jessie) je regarde sa je te tien au courant
