Oh no! Something has gone wrong
Je viens de mettre à jour un PC de wheezy (gnome 3) en jessie.
gnome ne démarre plus (sauf en mode failsafe), j’ai un
écran qui affiche :
“Oh no! Something has gone wrong.
A problem has occurred and the system can’t recover.
Please log out and try again”
Le “log out and try again” n’améliore rien.
J’ai créé un nouvel utilisateur de test (sans profil) et le
problème est toujours le même.
Voici quelques lignes de journalctl qui me semble les plus utiles
pour ce bug :
juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3169): GLib-CRITICAL **: g_strsplit: assertion 'string != NULL' failed juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3169): Clutter-CRITICAL **: Unable to initialize Clutter: The OpenGL version could not be determined juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3169): mutter-ERROR **: Unable to initialize Clutter. [b]juin 15 13:34:43 openelec kernel: traps: gnome-shell[3169] trap int3 ip:7faa96b6fd30 sp:7fffae68fe10 error:0[/b] juin 15 13:34:43 openelec gnome-session[2957]: gnome-session[2957]: WARNING: Application 'gnome-shell.desktop' killed by signal 5 juin 15 13:34:43 openelec gnome-session[2957]: WARNING: Application 'gnome-shell.desktop' killed by signal 5 juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3250): GLib-CRITICAL **: g_strsplit: assertion 'string != NULL' failed juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3250): Clutter-CRITICAL **: Unable to initialize Clutter: The OpenGL version could not be determined juin 15 13:34:43 openelec gnome-session[2957]: (gnome-shell:3250): mutter-ERROR **: Unable to initialize Clutter. [b]juin 15 13:34:43 openelec kernel: traps: gnome-shell[3250] trap int3 ip:7fa12c191d30 sp:7ffe9e6a26c0 error:0[/b] juin 15 13:34:43 openelec gnome-session[2957]: gnome-session[2957]: WARNING: Application 'gnome-shell.desktop' killed by signal 5 juin 15 13:34:43 openelec gnome-session[2957]: WARNING: Application 'gnome-shell.desktop' killed by signal 5 juin 15 13:34:43 openelec gnome-session[2957]: WARNING: App 'gnome-shell.desktop' respawning too quickly juin 15 13:34:43 openelec gnome-session[2957]: gnome-session[2957]: WARNING: App 'gnome-shell.desktop' respawning too quickly juin 15 13:34:43 openelec gnome-session[2957]: Unrecoverable failure in required component gnome-shell.desktop juin 15 13:34:43 openelec gnome-session[2957]: Entering running state juin 15 13:34:43 openelec gnome-session[2957]: (uint32 1,)
Ayant eu par le passé (squeeze) des difficultés avec la carte vidéo,
j’ai essayé d’upgrader le driver fglrx avec celui de sid mais ça ne change rien.
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler [Radeon HD 6310] (prog-if 00 [VGA controller]) Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7698 Flags: bus master, fast devsel, latency 0, IRQ 45 Memory at c0000000 (32-bit, prefetchable) [size=256M] I/O ports at f000 [size=256] Memory at feb00000 (32-bit, non-prefetchable) [size=256K] Expansion ROM at <unassigned> [disabled] Capabilities: [50] Power Management version 3 Capabilities: [58] Express Root Complex Integrated Endpoint, MSI 00 Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?> Kernel driver in use: fglrx_pci
Une piste ou une indication pour savoir sur quel paquet je dois faire
un rapport de bug ?
Guy.
c’est connu et indiqué dans les releases notes de jessie
debian.org/releases/stable/ … nome-fglrx
Merci beaucoup, c’était bien ça.
Désinstallation de fglrx et ça marche …
Guy
