Voici le contenu de /etc/battery.d[code]#! /bin/sh
This script adjusts hard drive APM settings using hdparm. The hardware
defaults (usually hdparm -B 128) cause excessive head load/unload cycles
on many modern hard drives. We therefore set hdparm -B 254 while on AC
power. On battery we set hdparm -B 128, because the head parking is
very useful for shock protection.
DO_HDPARM=y
if [ -e /usr/sbin/laptop_mode ] ; then
LMT_CONTROL_HD_POWERMGMT=$(. /etc/laptop-mode/laptop-mode.conf && echo “$CONTROL_HD_POWERMGMT”)
if [ “$LMT_CONTROL_HD_POWERMGMT” != 0 ] ; then
# Laptop mode controls hdparm -B settings, we don’t.
DO_HDPARM=n
fi
fi
if [ $DO_HDPARM = y ] ; then
AC_POWER=$( /usr/bin/on_ac_power; echo $? )
for dev in /dev/sd? /dev/hd? ; do
if [ -b $dev ] ; then
if [ $AC_POWER -eq 1 ] ; then
hdparm -B 128 $dev
else
hdparm -B 254 $dev
fi
fi
done
fi[/code]Peux-tu me confirmer que ce fichier activé bien hdparm 128 sur batterie et 254 sur secteur? Comment voir quelle valeur est activé?
