Je croyais que poue lancer une application, il fallais être root
Voilà pour la commande openarena :
4722 files in pk3 files
execing default.cfg
couldn’t exec q3config.cfg
couldn’t exec autoexec.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
Couldn’t read q3history.
Your network rate is too slow for VoIP.
Set ‘Data Rate’ to ‘LAN/Cable/xDSL’ in ‘Setup/System/Network’ and restart.
Until then, VoIP is disabled.
----- Initializing Renderer ----
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
SDL using driver "x11"
Initializing OpenGL display
Estimated display aspect: 1.250
…setting mode 3: 640 480
Using 8/8/8 Color bits, 24 depth, 8 stencil display.
Available modes: '1280x1024 640x480 800x600 832x624 1024x768 1152x864 720x400’
GL_RENDERER: Gallium 0.4 on ATI RV570
Initializing OpenGL extensions
…GL_EXT_texture_compression_s3tc not found
…GL_S3_s3tc not found
…using GL_EXT_texture_env_add
…using GL_ARB_multitexture
…using GL_EXT_compiled_vertex_array
…ignoring GL_EXT_texture_filter_anisotropic
GL_VENDOR: X.Org R300 Project
GL_VERSION: 2.1 Mesa 7.10.3
GL_EXTENSIONS: GL_ARB_copy_buffer GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_half_float_vertex GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture3D GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_EXT_vertex_array GL_OES_EGL_image GL_OES_read_format GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_window_pos GL_MESA_ycbcr_texture GL_NV_blend_square GL_NV_conditional_render GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_TEXTURE_UNITS_ARB: 8
PIXELFORMAT: color(24-bits) Z(24-bit) stencil(8-bits)
MODE: 3, 640 x 480 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: disabled
Initializing Shaders
----- finished R_Init -----
------ Initializing Sound ------
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Erreur de segmentation
Et pour locate -i “arena” J’ai fait un updatedb avant…
/home/libre/.openarena
/home/libre/.openarena/qkey
/home/libre/Download/Browser/openarena-data_0.8.5-3_all.deb
/home/libre/Download/Browser/openarena-server_0.8.5-5+squeeze3_i386.deb
/home/libre/Download/Browser/openarena_0.8.5-5+squeeze3_i386.deb
/usr/games/openarena
/usr/games/openarena-server
/usr/lib/games/openarena
/usr/lib/games/openarena/baseoa
/usr/lib/games/openarena/missionpack
/usr/lib/games/openarena/baseoa/cgamei386.so
/usr/lib/games/openarena/baseoa/pak0
/usr/lib/games/openarena/baseoa/pak0.pk3
/usr/lib/games/openarena/baseoa/pak1-maps.pk3
/usr/lib/games/openarena/baseoa/pak2-players-mature.pk3
/usr/lib/games/openarena/baseoa/pak2-players.pk3
/usr/lib/games/openarena/baseoa/pak4-textures.pk3
/usr/lib/games/openarena/baseoa/pak5-TA.pk3
/usr/lib/games/openarena/baseoa/pak6-misc.pk3
/usr/lib/games/openarena/baseoa/pak6-patch085.pk3
/usr/lib/games/openarena/baseoa/qagamei386.so
/usr/lib/games/openarena/baseoa/uii386.so
/usr/lib/games/openarena/baseoa/pak0/cgamei386.so
/usr/lib/games/openarena/baseoa/pak0/qagamei386.so
/usr/lib/games/openarena/baseoa/pak0/uii386.so
/usr/lib/games/openarena/missionpack/cgamei386.so
/usr/lib/games/openarena/missionpack/mp-pak0.pk3
/usr/lib/games/openarena/missionpack/qagamei386.so
/usr/lib/games/openarena/missionpack/uii386.so
/usr/share/app-install/desktop/openarena.desktop
/usr/share/app-install/icons/openarena128.png
/usr/share/applications/openarena.desktop
/usr/share/doc/openarena
/usr/share/doc/openarena-data
/usr/share/doc/openarena-server
/usr/share/doc/openarena/CREDITS
/usr/share/doc/openarena/LINUXNOTES
/usr/share/doc/openarena/README
/usr/share/doc/openarena/README.Debian
/usr/share/doc/openarena/changelog.Debian.gz
/usr/share/doc/openarena/changelog.gz
/usr/share/doc/openarena/copyright
/usr/share/doc/openarena/md4-readme.txt
/usr/share/doc/openarena/voip-readme.txt.gz
/usr/share/doc/openarena-data/CREDITS
/usr/share/doc/openarena-data/LINUXNOTES
/usr/share/doc/openarena-data/README
/usr/share/doc/openarena-data/README.Debian
/usr/share/doc/openarena-data/changelog.Debian.gz
/usr/share/doc/openarena-data/changelog.gz
/usr/share/doc/openarena-data/copyright
/usr/share/doc/openarena-server/CREDITS
/usr/share/doc/openarena-server/LINUXNOTES
/usr/share/doc/openarena-server/README
/usr/share/doc/openarena-server/changelog.Debian.gz
/usr/share/doc/openarena-server/changelog.gz
/usr/share/doc/openarena-server/copyright
/usr/share/games/openarena
/usr/share/games/openarena/baseoa
/usr/share/games/openarena/missionpack
/usr/share/games/openarena/baseoa/pak0.pk3
/usr/share/games/openarena/baseoa/pak1-maps.pk3
/usr/share/games/openarena/baseoa/pak2-players-mature.pk3
/usr/share/games/openarena/baseoa/pak2-players.pk3
/usr/share/games/openarena/baseoa/pak4-textures.pk3
/usr/share/games/openarena/baseoa/pak5-TA.pk3
/usr/share/games/openarena/baseoa/pak6-misc.pk3
/usr/share/games/openarena/baseoa/pak6-patch085.pk3
/usr/share/games/openarena/missionpack/mp-pak0.pk3
/usr/share/icons/hicolor/128x128/apps/openarena128.png
/usr/share/man/man6/openarena-server.6.gz
/usr/share/man/man6/openarena.6.gz
/usr/share/menu/openarena
/usr/share/pixmaps/openarena32.xpm
/var/cache/apt/archives/openarena-data_0.8.5-3_all.deb
/var/cache/apt/archives/openarena-server_0.8.5-5+squeeze3_i386.deb
/var/cache/apt/archives/openarena_0.8.5-5+squeeze3_i386.deb
/var/lib/dpkg/info/openarena-data.list
/var/lib/dpkg/info/openarena-data.md5sums
/var/lib/dpkg/info/openarena-server.list
/var/lib/dpkg/info/openarena-server.md5sums
/var/lib/dpkg/info/openarena.list
/var/lib/dpkg/info/openarena.md5sums
/var/lib/dpkg/info/openarena.postinst
/var/lib/dpkg/info/openarena.postrm
/var/lib/menu-xdg/applications/menu-xdg/X-Debian-Games-Action-openarena.desktop
root@debian:~# exit
logout
libre@debian:~$ openarena
ioq3+oa 1.36 linux-i386 Mar 29 2012
----- FS_Startup -----
Current search path:
/home/libre/.openarena/baseoa
/usr/lib/games/openarena/baseoa/pak6-patch085.pk3 (559 files)
/usr/lib/games/openarena/baseoa/pak6-misc.pk3 (229 files)
/usr/lib/games/openarena/baseoa/pak5-TA.pk3 (139 files)
/usr/lib/games/openarena/baseoa/pak4-textures.pk3 (1753 files)
/usr/lib/games/openarena/baseoa/pak2-players.pk3 (669 files)
/usr/lib/games/openarena/baseoa/pak2-players-mature.pk3 (231 files)
/usr/lib/games/openarena/baseoa/pak1-maps.pk3 (100 files)
/usr/lib/games/openarena/baseoa/pak0.pk3 (1042 files)
Alors, c’est une erreur pour se connecter au server, mais même le singleplayer ne marche pas…
Openarena se lance, mais n’aboutie pas au menu du jeux, en fait à aucune interface…
Louis
