Voilà les logs de xorg (visiblement aucune erreur)
[code]
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current Operating System: Linux debian 2.6.32-5-amd64 #1 SMP Sun May 6 04:00:17 UTC 2012 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=fee38c1f-eac3-4da9-bae6-43a63d78de8f ro quiet nomodeset radeon.modeset=0
Build Date: 29 October 2011 06:58:14PM
xorg-server 2:1.7.7-14 (Julien Cristau jcristau@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Sep 7 22:04:59 2012
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) ServerLayout “X.org Configured”
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
() | |–>Device “Card0”
() |–>Screen “Screen1” (1)
() | |–>Monitor “Monitor1”
() | |–>Device “Card1”
() |–>Input Device “Mouse0”
() |–>Input Device “Keyboard0”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
() FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins,
built-ins
(**) ModulePath set to “/usr/lib/xorg/modules”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(–) PCI:*(0:0:2:0) 8086:0046:103c:144a Intel Corporation Core Processor Integrated Graphics Controller rev 2, Mem @ 0xc0000000/4194304, 0xb0000000/268435456, I/O @ 0x00005050/8
(–) PCI: (0:1:0:0) 1002:68e0:103c:144a ATI Technologies Inc Manhattan [Mobility Radeon HD 5000 Series] rev 0, Mem @ 0xa0000000/268435456, 0xc4400000/131072, I/O @ 0x00004000/256, BIOS @ 0x???/131072
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) “extmod” will be loaded. This was enabled by default and also specified in the config file.
(II) “dbe” will be loaded. This was enabled by default and also specified in the config file.
(II) “glx” will be loaded. This was enabled by default and also specified in the config file.
(II) “record” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri” will be loaded. This was enabled by default and also specified in the config file.
(II) “dri2” will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="Advanced Micro Devices, Inc."
compiled for 6.9.0, module version = 1.0.0
(II) Loading extension GLX
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “fglrx”
(II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - AMD Technologies Inc."
compiled for 1.4.99.906, module version = 8.98.2
Module class: X.Org Video Driver
(II) Loading sub module “fglrxdrm”
(II) LoadModule: “fglrxdrm”
(II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
(II) Reloading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) LoadModule: “intel”
(II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.13.0
ABI class: X.Org Video Driver, version 6.0
(II) AMD Proprietary Linux Driver Version Identifier:8.98.2
(II) AMD Proprietary Linux Driver Release Identifier: 8.982
(II) AMD Proprietary Linux Driver Build Date: Jul 27 2012 20:37:56
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge, Sandybridge, Sandybridge, Sandybridge, Sandybridge,
(II) Primary Device is: PCI 00@00:02:0
(WW) Falling back to old probe method for fglrx
(II) Loading PCS database from /etc/ati/amdpcsdb
(–) Chipset Supported AMD Graphics Processor (0x68E0) found
(WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
(II) fglrx: intel VGA device detected, load intel driver.
(II) Reloading /usr/lib/xorg/modules/drivers/intel_drv.so
(II) UnloadModule: “intel”
(II) Failed to load module “intel” (already loaded, 8218272)
(WW) fglrx: Fail to load intel driver!
(II) AMD Video driver is running on a device belonging to a group targeted for this release
(II) AMD Video driver is signed
(II) fglrx(0): pEnt->device->identifier=0x1b0f580
(II) fglrx(0): === [xdl_x750_atiddxPreInit] === begin
(==) fglrx(0): Depth 24, (==) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB
(==) fglrx(0): Buffer Tiling is ON
(II) Reloading /usr/lib/xorg/modules/linux/libfglrxdrm.so
ukiDynamicMajor: found major device number 251
ukiOpenByBusid: Searching for BusID PCI:1:0:0
ukiOpenDevice: node name is /dev/ati/card0
ukiOpenDevice: open result is 9, (OK)
ukiOpenByBusid: ukiOpenMinor returns 9
ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
() fglrx(0): NoAccel = NO
() fglrx(0): AMD 2D Acceleration Architecture enabled
(–) fglrx(0): Chipset: "ATI Mobility Radeon HD 5400 Series " (Chipset = 0x68e0)
(–) fglrx(0): (PciSubVendor = 0x103c, PciSubDevice = 0x144a)
(==) fglrx(0): board vendor info: third party graphics adapter - NOT original AMD
(–) fglrx(0): Linear framebuffer (phys) at 0xa0000000
(–) fglrx(0): MMIO registers at 0xc4400000
(–) fglrx(0): I/O port at 0x00004000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): ATIF platform detected
(II) fglrx(0): Battery is used
(II) fglrx(0): Invalid ATI BIOS from int10, the adapter is not VGA-enabled
(EE) fglrx(0): Invalid video BIOS signature!
(EE) fglrx(0): GetBIOSParameter failed
(EE) fglrx(0): PreInitAdapter failed
(EE) fglrx(0): PreInit failed
(II) fglrx(0): === [xdl_x750_atiddxPreInit] === end
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 10, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 10
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(==) intel(1): Depth 24, (–) framebuffer bpp 32
(==) intel(1): RGB weight 888
(==) intel(1): Default visual is TrueColor
(II) intel(1): Integrated Graphics Chipset: Intel® Arrandale
(–) intel(1): Chipset: “Arrandale”
() intel(1): Tiling enabled
() intel(1): SwapBuffers wait enabled
(==) intel(1): video overlay key set to 0x101fe
(II) intel(1): Output VGA1 using monitor section Monitor1
(II) intel(1): Output LVDS1 has no monitor section
(II) intel(1): found backlight control interface /sys/class/backlight/acpi_video1
(II) intel(1): EDID for output VGA1
(II) intel(1): EDID for output LVDS1
(II) intel(1): Manufacturer: SEC Model: 3651 Serial#: 0
(II) intel(1): Year: 2008 Week: 0
(II) intel(1): EDID Version: 1.3
(II) intel(1): Digital Display Input
(II) intel(1): Max Image Size [cm]: horiz.: 34 vert.: 19
(II) intel(1): Gamma: 2.20
(II) intel(1): No DPMS capabilities specified
(II) intel(1): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) intel(1): First detailed timing is preferred mode
(II) intel(1): redX: 0.580 redY: 0.340 greenX: 0.310 greenY: 0.550
(II) intel(1): blueX: 0.155 blueY: 0.155 whiteX: 0.313 whiteY: 0.329
(II) intel(1): Manufacturer’s mask: 0
(II) intel(1): Supported detailed timing:
(II) intel(1): clock: 69.3 MHz Image Size: 344 x 194 mm
(II) intel(1): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1480 h_border: 0
(II) intel(1): v_active: 768 v_sync: 770 v_sync_end 775 v_blanking: 780 v_border: 0
(II) intel(1): Unknown vendor-specific block f
(II) intel(1): SAMSUNG
(II) intel(1): 156AT05-H01
(II) intel(1): EDID (in hex):
(II) intel(1): 00ffffffffffff004ca3513600000000
(II) intel(1): 00120103802213780a87f594574f8c27
(II) intel(1): 27505400000001010101010101010101
(II) intel(1): 010101010101121b567250000c303020
(II) intel(1): 250058c2100000190000000f00000000
(II) intel(1): 00000000001eb4027400000000fe0053
(II) intel(1): 414d53554e470a2020202020000000fe
(II) intel(1): 00313536415430352d4830310a200015
(II) intel(1): Not using default mode “320x240” (doublescan mode not supported)
(II) intel(1): Not using default mode “400x300” (doublescan mode not supported)
(II) intel(1): Not using default mode “512x384” (doublescan mode not supported)
(II) intel(1): Not using default mode “640x480” (doublescan mode not supported)
(II) intel(1): Not using default mode “640x512” (doublescan mode not supported)
(II) intel(1): Not using default mode “800x600” (doublescan mode not supported)
(II) intel(1): Not using default mode “896x672” (doublescan mode not supported)
(II) intel(1): Not using default mode “928x696” (doublescan mode not supported)
(II) intel(1): Not using default mode “960x720” (doublescan mode not supported)
(II) intel(1): Not using default mode “576x432” (doublescan mode not supported)
(II) intel(1): Not using default mode “680x384” (doublescan mode not supported)
(II) intel(1): Not using default mode “700x525” (doublescan mode not supported)
(II) intel(1): Not using default mode “720x450” (doublescan mode not supported)
(II) intel(1): Not using default mode “800x512” (doublescan mode not supported)
(II) intel(1): Not using default mode “840x525” (doublescan mode not supported)
(II) intel(1): Not using default mode “960x540” (doublescan mode not supported)
(II) intel(1): Not using default mode “960x600” (doublescan mode not supported)
(II) intel(1): Not using default mode “1024x768” (doublescan mode not supported)
(II) intel(1): Printing probed modes for output LVDS1
(II) intel(1): Modeline "1366x768"x60.0 69.30 1366 1414 1446 1480 768 770 775 780 -hsync -vsync (46.8 kHz)
(II) intel(1): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz)
(II) intel(1): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz)
(II) intel(1): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) intel(1): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) intel(1): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) intel(1): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) intel(1): Output VGA1 disconnected
(II) intel(1): Output LVDS1 connected
(II) intel(1): Using exact sizes for initial modes
(II) intel(1): Output LVDS1 using initial mode 1366x768
(II) intel(1): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
(II) intel(1): Kernel page flipping support detected, enabling
(==) intel(1): DPI set to (96, 96)
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) fglrx(0): Interrupt handler Shutdown.
(II) UnloadModule: “fglrx”
(II) UnloadModule: “fglrxdrm”
(==) Depth 24 pixmap format is 32 bpp
(==) intel(0): VideoRam: 262144 KB
(II) intel(0): [DRI2] Setup complete
(II) intel(0): Allocated new frame buffer 1408x768 stride 5632, tiled
(II) UXA(0): Driver registered support for the following operations:
(II) solid
(II) copy
(II) composite (RENDER acceleration)
(II) put_image
(II) get_image
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(==) intel(0): DPMS enabled
(==) intel(0): Intel XvMC decoder enabled
(II) intel(0): Set up textured video
(II) intel(0): [XvMC] xvmc_vld driver initialized.
(II) intel(0): direct rendering: DRI2 Enabled
(–) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(EE) GLX error: Can not get required symbols.
(II) intel(0): Setting screen physical size to 361 x 203
(II) config/udev: Adding input device Power Button (/dev/input/event6)
() Power Button: Applying InputClass “evdev keyboard catchall”
(II) LoadModule: “evdev”
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
() Power Button: always reports core events
() Power Button: Device: “/dev/input/event6”
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
() Option “xkb_rules” “evdev”
() Option “xkb_model” “pc105”
() Option “xkb_layout” “fr”
() Option “xkb_variant” “latin9”
(II) config/udev: Adding input device Video Bus (/dev/input/event11)
() Video Bus: Applying InputClass “evdev keyboard catchall”
() Video Bus: always reports core events
() Video Bus: Device: “/dev/input/event11”
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD)
(II) config/udev: Adding input device Video Bus (/dev/input/event12)
() Video Bus: Device: “/dev/input/event12”
(II) config/udev: Adding input device Power Button (/dev/input/event4)
() Power Button: Device: “/dev/input/event4”
(II) config/udev: Adding input device Lid Switch (/dev/input/event5)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event2)
() Logitech USB Receiver: Applying InputClass “evdev keyboard catchall”
() Logitech USB Receiver: always reports core events
() Logitech USB Receiver: Device: “/dev/input/event2”
(II) Logitech USB Receiver: Found keys
(II) Logitech USB Receiver: Configuring as keyboard
(II) XINPUT: Adding extended input device “Logitech USB Receiver” (type: KEYBOARD)
(II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3)
() Logitech USB Receiver: Applying InputClass “evdev pointer catchall”
() Logitech USB Receiver: Device: “/dev/input/event3”
(II) Logitech USB Receiver: Found 20 mouse buttons
(II) Logitech USB Receiver: Found scroll wheel(s)
(II) Logitech USB Receiver: Found relative axes
(II) Logitech USB Receiver: Found x and y relative axes
(II) Logitech USB Receiver: Found absolute axes
(II) Logitech USB Receiver: Configuring as mouse
() Logitech USB Receiver: YAxisMapping: buttons 4 and 5
() Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) Logitech USB Receiver: initialized for relative axes.
(WW) Logitech USB Receiver: ignoring absolute axes.
(II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse1)
(II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event13)
(II) config/udev: Adding input device HDA Intel Mic at Ext Front Jack (/dev/input/event14)
(II) config/udev: Adding input device HDA Intel HP Out at Ext Front Jack (/dev/input/event15)
(II) config/udev: Adding input device HP Webcam (/dev/input/event8)
() HP Webcam: Applying InputClass “evdev keyboard catchall”
() HP Webcam: always reports core events
() HP Webcam: Device: “/dev/input/event8”
(II) HP Webcam: Found keys
(II) HP Webcam: Configuring as keyboard
(II) XINPUT: Adding extended input device “HP Webcam” (type: KEYBOARD)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
() AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
() AT Translated Set 2 keyboard: always reports core events
() AT Translated Set 2 keyboard: Device: “/dev/input/event1”
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD)
(II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event10)
() SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchpad catchall”
() SynPS/2 Synaptics TouchPad: Applying InputClass “touchpad catchall”
(II) LoadModule: “synaptics”
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 1.2.2
(II) Synaptics touchpad driver version 1.2.2
() Option “Device” “/dev/input/event10”
(II) SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
(II) SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
(II) SynPS/2 Synaptics TouchPad: pressure range 0 - 255
(II) SynPS/2 Synaptics TouchPad: finger width range 0 - 0
(II) SynPS/2 Synaptics TouchPad: buttons: left
(–) SynPS/2 Synaptics TouchPad: touchpad found
() SynPS/2 Synaptics TouchPad: always reports core events
(II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD)
() SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
() SynPS/2 Synaptics TouchPad: (accel) acceleration profile 0
() SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
() SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
(II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse2)
SynPS/2 Synaptics TouchPad no synaptics event device found
() Option “Device” "/dev/input/mouse2"
Query no Synaptics: 6003C8
(–) SynPS/2 Synaptics TouchPad: no supported touchpad found
(EE) SynPS/2 Synaptics TouchPad Unable to query/initialize Synaptics hardware.
(EE) PreInit failed for input device “SynPS/2 Synaptics TouchPad”
(II) UnloadModule: “synaptics”
(II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event9)
(II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
(II) config/udev: Adding input device PC Speaker (/dev/input/event7)
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/event0)
() Macintosh mouse button emulation: Applying InputClass “evdev pointer catchall”
() Macintosh mouse button emulation: always reports core events
() Macintosh mouse button emulation: Device: “/dev/input/event0”
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found relative axes
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
() Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
() Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Macintosh mouse button emulation” (type: MOUSE)
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/mouse0)
(II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event16)
() ACPI Virtual Keyboard Device: Applying InputClass “evdev keyboard catchall”
() ACPI Virtual Keyboard Device: always reports core events
() ACPI Virtual Keyboard Device: Device: “/dev/input/event16”
(II) ACPI Virtual Keyboard Device: Found keys
(II) ACPI Virtual Keyboard Device: Configuring as keyboard
(II) XINPUT: Adding extended input device “ACPI Virtual Keyboard Device” (type: KEYBOARD)
(**) Option “xkb_variant” “latin9”
(II) intel(0): EDID vendor “SEC”, prod id 13905
(II) intel(0): Printing DDC gathered Modelines:
(II) intel(0): Modeline "1366x768"x0.0 69.30 1366 1414 1446 1480 768 770 775 780 -hsync -vsync (46.8 kHz)
(II) intel(0): Modeline "1366x768"x0.0 69.30 1366 1414 1446 1480 768 770 775 780 -hsync -vsync (46.8 kHz)[/code]
Par contre, je ne trouve pas le xsession-errors
