j’ai besoin de faire un vpn entre le boulot et mon portable (qui se ballade donc). Dans un premier temps, je veux faire fonctionner ce vpn en local.
j’ai donc suivi le tuto de coagul et le serveur est normalement OK (je peux le pinger), les clefs sont faites et tout et tout.
Je configure le client et là c’est le drame, voici le message d’erreur obtenu :
Thu Mar 12 09:54:07 2009 OpenVPN 2.1_rc11 i486-pc-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] built on Sep 18 2008
Thu Mar 12 09:54:07 2009 WARNING: file ‘regis.key’ is group or others accessible
Thu Mar 12 09:54:07 2009 /usr/bin/openssl-vulnkey -q -b 1024 -m
Thu Mar 12 09:54:07 2009 LZO compression initialized
Thu Mar 12 09:54:07 2009 Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Thu Mar 12 09:54:07 2009 Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:135 ET:0 EL:0 AF:3/1 ]
Thu Mar 12 09:54:07 2009 Local Options hash (VER=V4): '69109d17’
Thu Mar 12 09:54:07 2009 Expected Remote Options hash (VER=V4): 'c0103fa8’
Thu Mar 12 09:54:07 2009 Attempting to establish TCP connection with 192.168.1.200:443 [nonblock]
Thu Mar 12 09:54:08 2009 TCP connection established with 192.168.1.200:443
Thu Mar 12 09:54:08 2009 Socket Buffers: R=[87380->131072] S=[16384->131072]
Thu Mar 12 09:54:08 2009 TCPv4_CLIENT link local: [undef]
Thu Mar 12 09:54:08 2009 TCPv4_CLIENT link remote: 192.168.1.200:443
Thu Mar 12 09:54:08 2009 TLS: Initial packet from 192.168.1.200:443, sid=08bb22b7 d19b8623
Thu Mar 12 09:54:08 2009 VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: /C=FR/ST=NA/L=BLC/O=SARL_ROBIN_MATHIEU/CN=SARL_ROBIN_MATHIEU_CA/emailAddress=xxx.xxx@xxx.com
Thu Mar 12 09:54:08 2009 TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
Thu Mar 12 09:54:08 2009 TLS Error: TLS object -> incoming plaintext read error
Thu Mar 12 09:54:08 2009 TLS Error: TLS handshake failed
Thu Mar 12 09:54:08 2009 Fatal TLS error (check_tls_errors_co), restarting
Thu Mar 12 09:54:08 2009 TCP/UDP: Closing socket
Thu Mar 12 09:54:08 2009 SIGUSR1[soft,tls-error] received, process restarting
Thu Mar 12 09:54:08 2009 Restart pause, 5 second(s)
Pourquoi ne puis je pas serrer la main avec TLS ? :smt003 "TLS handshake failed"
J’ai fait des recherches sur le net mais je ne comprends pas trop les reponses.
Avez vous une idée du probleme ?
Merci de votre aide
Regis
PS : désolé pour la longueur de la conf serveur, il y a surmement une foule de trucs à supprimer mais pour l’instant je ne maitrise pas …
config du client :
client
remote-cert-tls server
dev tun0
proto tcp
remote 192.168.1.200 443
resolv-retry infinite
nobind
persist-key
persist-tun
ca VPNROMA.crt
cert regis.crt
key regis.key
comp-lzo
verb 3
conf du serveur
Sample OpenVPN 2.0 config file for
multi-client server.
This file is for the server side
of a many-clients <-> one-server
OpenVPN configuration.
OpenVPN also supports
single-machine <-> single-machine
configurations (See the Examples page
on the web site for more info).
This config should work on Windows
or Linux/BSD systems. Remember on
Windows to quote pathnames and use
double backslashes, e.g.:
“C:\Program Files\OpenVPN\config\foo.key”
Comments are preceded with ‘#’ or ‘;’
Which local IP address should OpenVPN
listen on? (optional)
;local a.b.c.d
Which TCP/UDP port should OpenVPN listen on?
If you want to run multiple OpenVPN instances
on the same machine, use a different port
number for each one. You will need to
open up this port on your firewall.
port 443
TCP or UDP server?
proto tcp
;proto udp
“dev tun” will create a routed IP tunnel,
“dev tap” will create an ethernet tunnel.
Use “dev tap0” if you are ethernet bridging
and have precreated a tap0 virtual interface
and bridged it with your ethernet interface.
If you want to control access policies
over the VPN, you must create firewall
rules for the the TUN/TAP interface.
On non-Windows systems, you can give
an explicit unit number, such as tun0.
On Windows, use “dev-node” for this.
On most systems, the VPN will not function
unless you partially or fully disable
the firewall for the TUN/TAP interface.
;dev tap
dev tun
Windows needs the TAP-Win32 adapter name
from the Network Connections panel if you
have more than one. On XP SP2 or higher,
you may need to selectively disable the
Windows firewall for the TAP adapter.
Non-Windows systems usually don’t need this.
;dev-node MyTap
SSL/TLS root certificate (ca), certificate
(cert), and private key (key). Each client
and the server must have their own cert and
key file. The server and all clients will
use the same ca file.
See the “easy-rsa” directory for a series
of scripts for generating RSA certificates
and private keys. Remember to use
a unique Common Name for the server
and each of the client certificates.
Any X509 key management system can be used.
OpenVPN can also use a PKCS #12 formatted key file
(see “pkcs12” directive in man page).
ca ca.crt
cert VPNROMA.crt
key VPNROMA.key # This file should be kept secret
Diffie hellman parameters.
Generate your own with:
openssl dhparam -out dh1024.pem 1024
Substitute 2048 for 1024 if you are using
2048 bit keys.
dh dh1024.pem
Configure server mode and supply a VPN subnet
for OpenVPN to draw client addresses from.
The server will take 10.8.0.1 for itself,
the rest will be made available to clients.
Each client will be able to reach the server
on 10.8.0.1. Comment this line out if you are
ethernet bridging. See the man page for more info.
server 10.8.0.0 255.255.255.0
Maintain a record of client <-> virtual IP address
associations in this file. If OpenVPN goes down or
is restarted, reconnecting clients can be assigned
the same virtual IP address from the pool that was
previously assigned.
ifconfig-pool-persist ipp.txt
Configure server mode for ethernet bridging.
You must first use your OS’s bridging capability
to bridge the TAP interface with the ethernet
NIC interface. Then you must manually set the
IP/netmask on the bridge interface, here we
assume 10.8.0.4/255.255.255.0. Finally we
must set aside an IP range in this subnet
(start=10.8.0.50 end=10.8.0.100) to allocate
to connecting clients. Leave this line commented
out unless you are ethernet bridging.
;server-bridge 10.8.0.4 255.255.255.0 10.8.0.50 10.8.0.100
using a DHCP-proxy, where clients talk
to the OpenVPN server-side DHCP server
to receive their IP address allocation
and DNS server addresses. You must first use
your OS’s bridging capability to bridge the TAP
interface with the ethernet NIC interface.
Note: this mode only works on clients (such as
Windows), where the client-side TAP adapter is
bound to a DHCP client.
;server-bridge
Push routes to the client to allow it
to reach other private subnets behind
the server. Remember that these
private subnets will also need
to know to route the OpenVPN client
address pool (10.8.0.0/255.255.255.0)
back to the OpenVPN server.
;push “route 192.168.10.0 255.255.255.0”
;push “route 192.168.20.0 255.255.255.0”
To assign specific IP addresses to specific
clients or if a connecting client has a private
subnet behind it that should also have VPN access,
use the subdirectory “ccd” for client-specific
configuration files (see man page for more info).
EXAMPLE: Suppose the client
having the certificate common name “Thelonious”
also has a small subnet behind his connecting
machine, such as 192.168.40.128/255.255.255.248.
First, uncomment out these lines:
;client-config-dir ccd
;route 192.168.40.128 255.255.255.248
Then create a file ccd/Thelonious with this line:
iroute 192.168.40.128 255.255.255.248
This will allow Thelonious’ private subnet to
access the VPN. This example will only work
if you are routing, not bridging, i.e. you are
using “dev tun” and “server” directives.
EXAMPLE: Suppose you want to give
Thelonious a fixed VPN IP address of 10.9.0.1.
First uncomment out these lines:
;route 10.9.0.0 255.255.255.252
Then add this line to ccd/Thelonious:
ifconfig-push 10.9.0.1 10.9.0.2
Suppose that you want to enable different
firewall access policies for different groups
of clients. There are two methods:
(1) Run multiple OpenVPN daemons, one for each
group, and firewall the TUN/TAP interface
for each group/daemon appropriately.
(2) (Advanced) Create a script to dynamically
modify the firewall in response to access
from different clients. See man
page for more info on learn-address script.
;learn-address ./script
If enabled, this directive will configure
all clients to redirect their default
network gateway through the VPN, causing
all IP traffic such as web browsing and
and DNS lookups to go through the VPN
(The OpenVPN server machine may need to NAT
or bridge the TUN/TAP interface to the internet
in order for this to work properly).
;push “redirect-gateway def1 bypass-dhcp”
Certain Windows-specific network settings
can be pushed to clients, such as DNS
or WINS server addresses. CAVEAT:
openvpn.net/faq.html#dhcpcaveats
The addresses below refer to the public
DNS servers provided by opendns.com.
;push “dhcp-option DNS 208.67.222.222”
;push “dhcp-option DNS 208.67.220.220”
Uncomment this directive to allow different
clients to be able to “see” each other.
By default, clients will only see the server.
To force clients to only see the server, you
will also need to appropriately firewall the
server’s TUN/TAP interface.
;client-to-client
Uncomment this directive if multiple clients
might connect with the same certificate/key
files or common names. This is recommended
only for testing purposes. For production use,
each client should have its own certificate/key
pair.
IF YOU HAVE NOT GENERATED INDIVIDUAL
CERTIFICATE/KEY PAIRS FOR EACH CLIENT,
EACH HAVING ITS OWN UNIQUE “COMMON NAME”,
UNCOMMENT THIS LINE OUT.
;duplicate-cn
The keepalive directive causes ping-like
messages to be sent back and forth over
the link so that each side knows when
the other side has gone down.
Ping every 10 seconds, assume that remote
peer is down if no ping received during
a 120 second time period.
keepalive 10 120
For extra security beyond that provided
by SSL/TLS, create an “HMAC firewall”
to help block DoS attacks and UDP port flooding.
Generate with:
openvpn --genkey --secret ta.key
The server and each client must have
a copy of this key.
The second parameter should be ‘0’
on the server and ‘1’ on the clients.
;tls-auth ta.key 0 # This file is secret
Select a cryptographic cipher.
This config item must be copied to
the client config file as well.
;cipher BF-CBC # Blowfish (default)
;cipher AES-128-CBC # AES
;cipher DES-EDE3-CBC # Triple-DES
Enable compression on the VPN link.
If you enable it here, you must also
enable it in the client config file.
comp-lzo
The maximum number of concurrently connected
clients we want to allow.
;max-clients 100
It’s a good idea to reduce the OpenVPN
daemon’s privileges after initialization.
You can uncomment this out on
non-Windows systems.
user openvpn
group openvpn
The persist options will try to avoid
accessing certain resources on restart
that may no longer be accessible because
of the privilege downgrade.
persist-key
persist-tun
Output a short status file showing
current connections, truncated
and rewritten every minute.
status openvpn-status.log
By default, log messages will go to the syslog (or
on Windows, if running as a service, they will go to
the “\Program Files\OpenVPN\log” directory).
Use log or log-append to override this default.
“log” will truncate the log file on OpenVPN startup,
while “log-append” will append to it. Use one
or the other (but not both).
;log openvpn.log
;log-append openvpn.log
Set the appropriate level of log
file verbosity.
0 is silent, except for fatal errors
4 is reasonable for general usage
5 and 6 can help to debug connection problems
9 is extremely verbose
verb 5
Silence repeating messages. At most 20
sequential messages of the same message
category will be output to the log.
;mute 20
?!) j’ai alors tous les certificats et clefs necessaires pour un serveur et un client.
) coté client et serveur (/etc/openvpn) et finalement créé mes fichiers de conf joints plus haut.
pas facile de poster ! Aufwiedersehen les debiannistes et openvpnistes!
) donc foncez si vous avez besoin d’un vpn et suivez bien ce qu’ils disent … ne faites pas comme moi !!
