Merci pour ta réponse !
Heu oui exact, un peu confus…
voila donc, en IPv6 activé d’abord:
ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 00:19:e3:62:c1:75 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:19:e3:08:e0:ee brd ff:ff:ff:ff:ff:ff
inet 192.168.0.14/24 brd 192.168.0.255 scope global dynamic wlan0
valid_lft 862468sec preferred_lft 862468sec
inet6 2a01:e35:2f4f:bc40:9f4:790b:8ec5:fe68/64 scope global temporary dynamic
valid_lft 86386sec preferred_lft 84263sec
inet6 2a01:e35:2f4f:bc40:219:e3ff:fe08:e0ee/64 scope global mngtmpaddr noprefixroute dynamic
valid_lft 86386sec preferred_lft 86386sec
inet6 fe80::219:e3ff:fe08:e0ee/64 scope link
ip -4 route
default via 192.168.0.254 dev wlan0 proto static metric 1024
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.14
ip -6 route
2a01:e35:2f4f:bc40::/64 dev wlan0 proto kernel metric 256 expires 86122sec
fe80::/64 dev wlan0 proto kernel metric 256 mtu 1480
default via fe80::207:cbff:fe36:2697 dev wlan0 proto static metric 1024
Puis en IPv6 désactivé:
ip addr
inet 192.168.0.13/24 brd 192.168.0.255 scope global dynamic wlan0
valid_lft 863844sec preferred_lft 863844sec
ip -4 route
169.254.0.0/16 dev wlan0 scope link metric 1000
192.168.0.0/24 dev wlan0 proto kernel scope link src 192.168.0.13
ip -6 route
Le contenu de /etv/resolv.conf:
# Generated by NetworkManager
nameserver 212.27.40.240
nameserver 212.27.40.241
(A priori on est bien chez Free… Ici j’avais essayé de rajouter ceux de google, les fameux 8.8.8.8, mais sans succès pour mon affaire)
Et puis je lance openvpn de cette manière:
openvpn --config ipvanish-FR-Paris-par-a01.ovpn
Mon Nov 9 22:55:02 2015 DEPRECATED OPTION: --tls-remote, please update your configuration
Mon Nov 9 22:55:02 2015 OpenVPN 2.3.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Dec 1 2014
Mon Nov 9 22:55:02 2015 library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
Mon Nov 9 22:55:02 2015 WARNING: file 'auth.txt' is group or others accessible
Mon Nov 9 22:55:02 2015 Deprecated TLS cipher name 'DHE-RSA-AES256-SHA', please use IANA name 'TLS-DHE-RSA-WITH-AES-256-CBC-SHA'
Mon Nov 9 22:55:02 2015 Deprecated TLS cipher name 'DHE-DSS-AES256-SHA', please use IANA name 'TLS-DHE-DSS-WITH-AES-256-CBC-SHA'
Mon Nov 9 22:55:02 2015 Deprecated TLS cipher name 'AES256-SHA', please use IANA name 'TLS-RSA-WITH-AES-256-CBC-SHA'
Mon Nov 9 22:55:02 2015 Socket Buffers: R=[212992->131072] S=[212992->131072]
Mon Nov 9 22:55:02 2015 UDPv4 link local: [undef]
Mon Nov 9 22:55:02 2015 UDPv4 link remote: [AF_INET]81.171.107.2:443
Mon Nov 9 22:55:02 2015 TLS: Initial packet from [AF_INET]81.171.107.2:443, sid=e168bf7e d4b6ce09
Mon Nov 9 22:55:02 2015 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mon Nov 9 22:55:03 2015 VERIFY OK: depth=1, /C=US/ST=FL/L=Winter_Park/O=IPVanish/OU=IPVanish_VPN/CN=IPVanish_CA/emailAddress=support@ipvanish.com
Mon Nov 9 22:55:03 2015 VERIFY X509NAME OK: /C=US/ST=FL/L=Winter_Park/O=IPVanish/OU=IPVanish_VPN/CN=par-a01.ipvanish.com/emailAddress=support@ipvanish.com
Mon Nov 9 22:55:03 2015 VERIFY OK: depth=0, /C=US/ST=FL/L=Winter_Park/O=IPVanish/OU=IPVanish_VPN/CN=par-a01.ipvanish.com/emailAddress=support@ipvanish.com
Mon Nov 9 22:55:03 2015 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov 9 22:55:03 2015 Data Channel Encrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mon Nov 9 22:55:03 2015 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov 9 22:55:03 2015 Data Channel Decrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mon Nov 9 22:55:03 2015 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Nov 9 22:55:03 2015 [par-a01.ipvanish.com] Peer Connection Initiated with [AF_INET]81.171.107.2:443
Mon Nov 9 22:55:05 2015 SENT CONTROL [par-a01.ipvanish.com]: 'PUSH_REQUEST' (status=1)
Mon Nov 9 22:55:05 2015 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 198.18.0.1,dhcp-option DNS 198.18.0.2,rcvbuf 262144,explicit-exit-notify 5,route-gateway 172.20.32.1,topology subnet,ping 20,ping-restart 40,ifconfig 172.20.32.182 255.255.252.0'
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: timers and/or timeouts modified
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: explicit notify parm(s) modified
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Mon Nov 9 22:55:05 2015 Socket Buffers: R=[131072->425984] S=[131072->131072]
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: --ifconfig/up options modified
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: route options modified
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: route-related options modified
Mon Nov 9 22:55:05 2015 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Nov 9 22:55:05 2015 ROUTE_GATEWAY 192.168.0.254/255.255.255.0 IFACE=wlan0 HWADDR=00:19:e3:08:e0:ee
Mon Nov 9 22:55:05 2015 TUN/TAP device tun0 opened
Mon Nov 9 22:55:05 2015 TUN/TAP TX queue length set to 100
Mon Nov 9 22:55:05 2015 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Nov 9 22:55:05 2015 /sbin/ip link set dev tun0 up mtu 1500
Mon Nov 9 22:55:05 2015 /sbin/ip addr add dev tun0 172.20.32.182/22 broadcast 172.20.35.255
Mon Nov 9 22:55:05 2015 /sbin/ip route add 81.171.107.2/32 via 192.168.0.254
Mon Nov 9 22:55:05 2015 /sbin/ip route add 0.0.0.0/1 via 172.20.32.1
Mon Nov 9 22:55:05 2015 /sbin/ip route add 128.0.0.0/1 via 172.20.32.1
Mon Nov 9 22:55:05 2015 Initialization Sequence Completed
Mais en ipV6 désactivé ça me donne ça par exemple:
ping google.fr
ping: unknown host google.fr
Voilà ça fait beaucoup de copier/coller, j’espère ne pas m’être trompé. N’hésitez pas à me demander si besoin…
Merci beaucoup d’avance !
