Je viens d’installer un server vpn sur ma debian, tout fonctionne bien, je peux m’y connecter et même avoir accès à mon partage samba.
Le seule problème c’est que je n’arrive pas à me connecter à internet par le vpn. J’ai suivis ce tuto: https://debian-facile.org/doc:reseau:openvpn
voici mon server.conf:
Serveur TCP/443
mode server
proto tcp
port 443
dev tun
Cléet certificats
ca ca.crt
cert server.crt
key server.key
dh dh2048.pem
tls-auth ta.key 0
cipher AES-256-CBC
Réau
server 10.8.0.0 255.255.255.0
push "redirect-gateway def1 bypass-dhcp"
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 8.8.4.4"
keepalive 10 120
Sérite
user nobody
group nogroup
chroot /etc/openvpn/jail
persist-key
persist-tun
comp-lzo
Log
verb 3
mute 20
status openvpn-status.log
log-append /var/log/openvpn.log
Mon iptables-save:
Generated by iptables-save v1.4.21 on Sun Dec 4 20:04:10 2016
*filter
:INPUT DROP [164:15154]
:FORWARD DROP [122:10135]
:OUTPUT DROP [1:73]
:fail2ban-apache - [0:0]
:fail2ban-apache-modsecurity - [0:0]
:fail2ban-apache-multiport - [0:0]
:fail2ban-apache-nohome - [0:0]
:fail2ban-apache-noscript - [0:0]
:fail2ban-apache-overflows - [0:0]
:fail2ban-dovecot - [0:0]
:fail2ban-mysqld-auth - [0:0]
:fail2ban-php-url-fopen - [0:0]
:fail2ban-postfix - [0:0]
:fail2ban-recidive - [0:0]
:fail2ban-sasl - [0:0]
:fail2ban-ssh - [0:0]
-A INPUT -p tcp -j fail2ban-recidive
-A INPUT -p tcp -m multiport --dports 3306 -j fail2ban-mysqld-auth
-A INPUT -p tcp -m multiport --dports 25,465,587,143,220,993,110,995 -j fail2ban-dovecot
-A INPUT -p tcp -m multiport --dports 25,465,587,143,220,993,110,995 -j fail2ban-sasl
-A INPUT -p tcp -m multiport --dports 25,465,587 -j fail2ban-postfix
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-php-url-fopen
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-apache-nohome
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-apache-modsecurity
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-apache-overflows
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-apache-noscript
-A INPUT -p tcp -m multiport --dports 80,443 -j fail2ban-apache-multiport
-A INPUT -p tcp -m multiport --dports 61000 -j fail2ban-ssh
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -p tcp -m tcp --dport 61000 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 53 -j ACCEPT
-A INPUT -p udp -m udp --dport 53 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 80 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 8008 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 443 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 8443 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 20:21 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 25 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 587 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 465 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 110 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 995 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 993 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 143 -j ACCEPT
-A INPUT -p udp -m udp --dport 137 -j ACCEPT
-A INPUT -p udp -m udp --dport 138 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 139 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 445 -j ACCEPT
-A INPUT -p udp -m udp --dport 445 -j ACCEPT
-A INPUT -i eth0 -p tcp -m tcp --dport 443 -j ACCEPT
-A FORWARD -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j ACCEPT
-A FORWARD -p udp -m limit --limit 1/sec -j ACCEPT
-A FORWARD -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j ACCEPT
-A FORWARD -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j ACCEPT
-A FORWARD -i tun0 -o eth0 -j ACCEPT
-A OUTPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A OUTPUT -o lo -j ACCEPT
-A OUTPUT -p icmp -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 61000 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 53 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 53 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 123 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 80 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 8008 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 443 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 20:21 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 25 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 587 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 465 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 110 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 995 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 993 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 143 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 137 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 138 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 139 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 445 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 445 -j ACCEPT
-A fail2ban-apache -j RETURN
-A fail2ban-apache-modsecurity -j RETURN
-A fail2ban-apache-multiport -j RETURN
-A fail2ban-apache-nohome -j RETURN
-A fail2ban-apache-noscript -j RETURN
-A fail2ban-apache-overflows -j RETURN
-A fail2ban-dovecot -j RETURN
-A fail2ban-mysqld-auth -j RETURN
-A fail2ban-php-url-fopen -j RETURN
-A fail2ban-postfix -j RETURN
-A fail2ban-recidive -j RETURN
-A fail2ban-sasl -j RETURN
-A fail2ban-ssh -j RETURN
COMMITCompleted on Sun Dec 4 20:04:10 2016
Auriez vous une idée?
Merci pour votre temps!
