OPENVPN route vers le lan
J’ai un serveur openvpn.
Le client se connecte sans problème, mais impossible d’accéder au réseau local. seulement a la machine serveur.
Config serveur :
dev-node "VPN"
port 9921
proto tcp
dev tun
ca ca.crt
cert server.crt
key server.key
dh dh2048.pem
server 10.32.0.0 255.255.255.0
ifconfig-pool-persist ipp.txt
 push   "route 192.168.0.0 255.255.255.0"
 route 192.168.1.0 255.255.255.0
client-to-client
cipher AES-256-CBC
persist-tun
status openvpn-status.log
verb 3
Config client :
client
dev tun
proto tcp
remote xxxxxxxxx xxx
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client1.crt
key client1.key
remote-cert-tls server
tls-auth ta.key 1
cipher AES-256-CBC
verb 3
Log lors de la connexion du client :
Fri Jan 22 20:06:16 2021 OpenVPN 2.4.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
Fri Jan 22 20:06:16 2021 Windows version 6.2 (Windows 8 or greater) 64bit
Fri Jan 22 20:06:16 2021 library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
Enter Management Password:
Fri Jan 22 20:06:16 2021 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Fri Jan 22 20:06:16 2021 Need hold release from management interface, waiting...
Fri Jan 22 20:06:17 2021 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'state on'
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'log all on'
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'echo all on'
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'bytecount 5'
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'hold off'
Fri Jan 22 20:06:17 2021 MANAGEMENT: CMD 'hold release'
Fri Jan 22 20:06:17 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]xxxxxxxxxx
Fri Jan 22 20:06:17 2021 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri Jan 22 20:06:17 2021 Attempting to establish TCP connection with [AF_INET]xxxxxxxxxx [nonblock]
Fri Jan 22 20:06:17 2021 MANAGEMENT: >STATE:1611342377,TCP_CONNECT,,,,,,
Fri Jan 22 20:06:18 2021 TCP connection established with [AF_INET]xxxxxxxxxx
Fri Jan 22 20:06:18 2021 TCP_CLIENT link local: (not bound)
Fri Jan 22 20:06:18 2021 TCP_CLIENT link remote: [AF_INET]xxxxxxxxxx
Fri Jan 22 20:06:18 2021 MANAGEMENT: >STATE:1611342378,WAIT,,,,,,
Fri Jan 22 20:06:18 2021 MANAGEMENT: >STATE:1611342378,AUTH,,,,,,
Fri Jan 22 20:06:18 2021 TLS: Initial packet from [AF_INET]xxxxxxxxxx, sid=682c5531 66523b61
Fri Jan 22 20:06:18 2021 VERIFY OK: depth=1, C=FR, ST=FR, L=TOULOUSE, O=OpenVPN, OU=changeme, CN=DTEL, name=changeme, emailAddress=root@dtel.pro
Fri Jan 22 20:06:18 2021 VERIFY KU OK
Fri Jan 22 20:06:18 2021 Validating certificate extended key usage
Fri Jan 22 20:06:18 2021 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Jan 22 20:06:18 2021 VERIFY EKU OK
Fri Jan 22 20:06:18 2021 VERIFY OK: depth=0, C=FR, ST=FR, L=TOULOUSE, O=OpenVPN, OU=changeme, CN=server, name=changeme, emailAddress=root@dtel.pro
Fri Jan 22 20:06:19 2021 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Fri Jan 22 20:06:19 2021 [server] Peer Connection Initiated with [AF_INET]xxxxxxxxxx
Fri Jan 22 20:06:20 2021 MANAGEMENT: >STATE:1611342380,GET_CONFIG,,,,,,
Fri Jan 22 20:06:20 2021 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Jan 22 20:06:20 2021 PUSH: Received control message: 'PUSH_REPLY,route 192.168.0.0 255.255.255.0,route 10.32.0.0 255.255.255.0,topology net30,ping 10,ping-restart 120,ifconfig 10.32.0.6 10.32.0.5,peer-id 0,cipher AES-256-GCM'
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: timers and/or timeouts modified
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: --ifconfig/up options modified
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: route options modified
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: peer-id set
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: adjusting link_mtu to 1626
Fri Jan 22 20:06:20 2021 OPTIONS IMPORT: data channel crypto options modified
Fri Jan 22 20:06:20 2021 Data Channel: using negotiated cipher 'AES-256-GCM'
Fri Jan 22 20:06:20 2021 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Fri Jan 22 20:06:20 2021 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Fri Jan 22 20:06:20 2021 interactive service msg_channel=0
Fri Jan 22 20:06:20 2021 ROUTE_GATEWAY 172.20.10.1/255.255.255.240 I=9 HWADDR=00:1c:42:cb:a1:fb
Fri Jan 22 20:06:20 2021 open_tun
Fri Jan 22 20:06:20 2021 TAP-WIN32 device [Connexion au réseau local] opened: \\.\Global\{F669C791-933C-46FE-A477-AE3665F0159D}.tap
Fri Jan 22 20:06:20 2021 TAP-Windows Driver Version 9.24
Fri Jan 22 20:06:20 2021 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.32.0.6/255.255.255.252 on interface {F669C791-933C-46FE-A477-AE3665F0159D} [DHCP-serv: 10.32.0.5, lease-time: 31536000]
Fri Jan 22 20:06:20 2021 Successful ARP Flush on interface [3] {F669C791-933C-46FE-A477-AE3665F0159D}
Fri Jan 22 20:06:20 2021 MANAGEMENT: >STATE:1611342380,ASSIGN_IP,,10.32.0.6,,,,
Fri Jan 22 20:06:26 2021 TEST ROUTES: 2/2 succeeded len=2 ret=1 a=0 u/d=up
Fri Jan 22 20:06:26 2021 MANAGEMENT: >STATE:1611342386,ADD_ROUTES,,,,,,
Fri Jan 22 20:06:26 2021 C:\Windows\system32\route.exe ADD 192.168.0.0 MASK 255.255.255.0 10.32.0.5
Fri Jan 22 20:06:26 2021 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
Fri Jan 22 20:06:26 2021 Route addition via IPAPI succeeded [adaptive]
Fri Jan 22 20:06:26 2021 C:\Windows\system32\route.exe ADD 10.32.0.0 MASK 255.255.255.0 10.32.0.5
Fri Jan 22 20:06:26 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Jan 22 20:06:26 2021 Initialization Sequence Completed
Fri Jan 22 20:06:26 2021 MANAGEMENT: >STATE:1611342386,CONNECTED,SUCCESS,10.32.0.6,xxxxxxxxxx,9921,172.20.10.3,61250
Il fais bien la root, mais impossible de faire même un ping vers une machine sur mon réseau local en 192.168.1.0…
Par contre j’ai bien accès a mon serveur VPN. Seulement lui.
Une idée ?
Est ce que tu as activé le forwarding sur ton serveur?
Comment fait ton sur windows ?
Ton serveur VPN est un windows?
Oui, mais j’ai essyer sous debian, j’ai exactement le meme pb.
j’ai trouver pour l’activer sur windows :
Mais toujours le meme pb :confused:
Le forwarding seul ne suffit pas. Il faut que :
1 - le client VPN ait une route vers le réseau distant via la passerelle VPN (à vérifier avec ip route)
2 - les machines du réseau distant aient une route vers le client VPN via la passerelle VPN
2’ - ou la passerelle VPN masque l’adresse IP du client (iptables SNAT ou MASQUERADE) (mais c’est sale)
Si le serveur agit comme un routeur et que celui ci est la passerelle par défaut du client VPN, il n’y a pas besoin de route à ajouter pour le client.
la passerelle par défaut des machines du réseau seule a besoin d’avoir cette route. ça évite de la mettre partout. Normalement seules les passerelles/routeurs ont besoin d’avoir les routes de ce type, ça évite d’éparpiller partout des routes.
dans ce type de besoin oui, c est pas très propre.
Du coup avez vous une solution ? je pense que ma config est bonne, ou il manque peu etre quelque chose, sa fais plusieurs semaine que ne trouve pas la solution
Il ne suffit pas de penser, il faut vérifier la table de routage de toutes les machines impliquées.
Sur le seveur :
client :
La route en surbrillance me semble incorrecte.
Où est Debian là-dedans ? Et les autres machines ?
C’est sur windows pas sur debian.
c’est de windows a windows
Regarde plus haut la config du serveur et client
Alors c’est hors sujet ici dans Support Debian.
J’ai le meme pb sur debian, je refais la config je reviens vers toi
N’oublie pas les autres machines.
L’autre machine sa sera : serveur debian et client windows, mais la config reste la meme sur le client
Je parle des machines du réseau avec lesquelles tu veux communiquer depuis le client, et de leurs routeurs.
Il est tard, je dois partir et ne pourrai probablement pas revenir avant demain midi. Je te laisse entre les mains expertes de @Zargos.
j’ai peur d’un humour possible :wink:
mais vu le sujet, j’y reviendrais demain vu l’heure.
Au regard des machines peux tu nous dire quelles sont les routes que tu as ajouté à la main? (qui ne sont donc pas générées automatiquement ni par la configuration réseau de base, ni par celle de openvpn).
On en va considéré que le cas où le serveur VPN est debian.
Il nous faudrait aussi la configuration réseau du serveur, celle du client, celle de la machine destination du client (configuration hors configuration openvpn).
C’est à dire:
ip a et ip r sur le serveur debian
ipconfig /all sur le client et la machine destination du client.
et à demain :slight_smile:
Sans vouloir faire ma mouche du coche mais je trouve dommage que l’utilisation de wireguard ne soit pas encore répandue chez les utilisateurs de debian. Il est plus simple à configurer
