J’ai essayer d’optimiser ma carte graphique RADEON HD 5870.
Et pour bien faire je me suis rendu sur le WIKI,puis dans mon Terminal:j’ai ecris la ligne suivante:
root@karukera01:/home/claude# lspci -v | grep VGA
Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon HD 5870 (Cypress) (prog-if 00 [VGA controller])
La question suivante m’a laisse tres perplexe ainsi que la reponse:
[code]root@karukera01:/home/claude# grep DRM_RADEON /boot/config-$(uname -r)
CONFIG_DRM_RADEON=m
CONFIG_DRM_RADEON_KMS is not set
root@karukera01:/home/claude# [/code]
Dans mon fichier /etc/x11 pas de fichier xorg.conf mais dans /etc/ modeprobe.d/radeon-kms.conf.
OPEN GL est non actif.
j’ai ensuite verifié la prise en charge d’AGP:
root@karukera01:/home/claude# grep AGP /boot/config-$(uname -r)
CONFIG_AGP=y
CONFIG_AGP_AMD64=y
CONFIG_AGP_INTEL=y
CONFIG_AGP_SIS=y
CONFIG_AGP_VIA=y
Ci joint un log épuré de Xorg.0
[code]X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-4-amd64 x86_64 Debian
Current Operating System: Linux karukera01 2.6.32-5-amd64 #1 SMP Fri May 10 08:43:19 UTC 2013 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=069df019-44f0-4f66-8fdd-56a08df0afdf ro quiet
Build Date: 12 April 2013 01:49:00PM
xorg-server 2:1.7.7-16 (Julien Cristau jcristau@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jun 23 11:07:11 2013
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
() |–>Screen “Default Screen Section” (0)
(**) | |–>Monitor “”
(==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(–) PCI:*(0:1:0:0) 1002:6898:174b:e140 ATI Technologies Inc Radeon HD 5870 (Cypress) rev 0, Mem @ 0xd0000000/268435456, 0xfdac0000/131072, I/O @ 0x0000de00/256, BIOS @ 0x???/131072
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.5.0, module version = 1.0.0
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(==) Matched ati as autoconfigured driver 0
(==) Matched vesa as autoconfigured driver 1
(==) Matched fbdev as autoconfigured driver 2
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: “ati”
(II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
(II) Module ati: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 6.13.1
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: “radeon”
(II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
(II) Module radeon: vendor="X.Org Foundation"
(II) LoadModule: “vesa”
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 2.3.0
(II) LoadModule: “fbdev”
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 0.4.2
(II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI FireMV 2400 3155 (PCI),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon 8500 AIW BC (AGP),
ATI Radeon IGP320M (U1) 4336, ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Mobility RADEON HD 4870, ATI Radeon 4800 Series,
ATI Radeon 4800 Series, ATI FirePro M7750, ATI M98, ATI M98, ATI M98,
ATI Mobility Radeon HD 4650, ATI Radeon RV730 (AGP),
ATI Mobility Radeon HD 4670, ATI FirePro M5750,
ATI Mobility Radeon HD 4670, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon RV710,
ATI Radeon HD 4350, ATI Mobility Radeon 4300 Series,
ATI Mobility Radeon 4500 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3450, ATI Radeon HD 3430,
ATI Radeon HD 3450, ATI FirePro V3700, ATI FireMV 2450,
ATI FireMV 2260, ATI FireMV 2260, ATI Radeon HD 3600 Series,
ATI Radeon HD 3650 AGP, ATI Radeon HD 3600 PRO,
ATI Radeon HD 3600 XT, ATI Radeon HD 3600 PRO,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3000 Graphics, ATI Radeon HD 4200, ATI Radeon 4100,
ATI Mobility Radeon HD 4200, ATI Mobility Radeon 4100,
ATI Radeon HD 4290, ATI Radeon HD 4290, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Radeon HD 5900 Series,
ATI Mobility Radeon HD 5800 Series,
ATI Mobility Radeon HD 5800 Series, ATI Radeon HD 5700 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 5700 Series,
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, CEDAR, CEDAR, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, CEDAR, ATI Radeon HD 5450,
CEDAR
(II) RADEON(0): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(II) RADEON(0): ATOM BIOS detected
(II) RADEON(0): ATOM BIOS Rom:
SubsystemVendorID: 0x174b SubsystemID: 0xe140
IOBaseAddress: 0xde00
Filename: 140X0300.V4T
BIOS Bootup Message:
CYPRESS XT GDDR5 32Mx32 C00801 BIOS UCODEv:126
(I"
(II) LoadModule: “shadow”
(II) Loading /usr/lib/xorg/modules/libshadow.so
(II) Module shadow: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) RADEON(0): Detected total video RAM=1048576K, accessible=262144K (PCI BAR=262144K)
(–) RADEON(0): Mapped VideoRAM: 262144 kByte (128 bit DDR SDRAM)
(II) RADEON(0): Color tiling disabled
(II) Loading sub module “ddc”
(II) LoadModule: “ddc”
(II) Module “ddc” already built-in
(II) Loading sub module “i2c”
(II) LoadModule: “i2c”
(II) Module “i2c” already built-in
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=64800 max=120000; xclk=40000
(II) RADEON(0): Output DisplayPort-0 has no monitor section
(II) RADEON(0): I2C bus “DisplayPort-0-DP” initialized.
RADEONDPEncoderService: 19
(II) RADEON(0): I2C bus “DisplayPort-0” initialized.
(II) RADEON(0): Output HDMI-0 has no monitor section
(II) RADEON(0): I2C bus “HDMI-0” initialized.
(II) RADEON(0): Output DVI-1 has no monitor section
(II) RADEON(0): I2C bus “DVI-1” initialized.
(II) RADEON(0): Output DVI-0 has no monitor section
(II) RADEON(0): I2C bus “DVI-0” initialized.
(II) RADEON(0): Port0:
XRANDR name: DisplayPort-0
Connector: DisplayPort
DFP1: INTERNAL_UNIPHY2
DDC reg: 0x6430
(II) RADEON(0): Port1:
XRANDR name: HDMI-0
Connector: HDMI-A
DFP2: INTERNAL_UNIPHY2
DDC reg: 0x6460
(II) RADEON(0): Port2:
XRANDR name: DVI-1
Connector: DVI-I
CRT2: INTERNAL_KLDSCP_DAC2
DFP3: INTERNAL_UNIPHY1
DDC reg: 0x6450
(II) RADEON(0): Port3:
XRANDR name: DVI-0
Connector: DVI-I
CRT1: INTERNAL_KLDSCP_DAC1
DFP4: INTERNAL_UNIPHY
DDC reg: 0x6470
(II) RADEON(0): I2C device “DisplayPort-0-DP:ddc2” registered at address 0xA0.
failed to get auxch 0030 40 30 02
failed to get auxch 0050 40 30 02
(II) RADEON(0): I2C device “DisplayPort-0:ddc2” registered at address 0xA0.
(II) RADEON(0): Output: DisplayPort-0, Detected Monitor Type: 0
finished output detect: 0
(II) RADEON(0): I2C device “HDMI-0:ddc2” registered at address 0xA0.
(II) RADEON(0): Output: HDMI-0, Detected Monitor Type: 0
finished output detect: 1
(II) RADEON(0): I2C device “DVI-1:ddc2” registered at address 0xA0.
Dac detection success
(II) RADEON(0): Output: DVI-1, Detected Monitor Type: 0
Unhandled monitor type 0
finished output detect: 2
(II) RADEON(0): I2C device “DVI-0:ddc2” registered at address 0xA0.
(II) RADEON(0): EDID for output DVI-0
(II) RADEON(0): Manufacturer: IVM Model: 560d Serial#: 16843009
(II) RADEON(0): Year: 2012 Week: 18
(II) RADEON(0): EDID Version: 1.3
(II) RADEON(0): Digital Display Input
(II) RADEON(0): DFP 1.x compatible TMDS
(II) RADEON(0): Max Image Size [cm]: horiz.: 52 vert.: 30
(II) RADEON(0): Gamma: 2.20
(II) RADEON(0): DPMS capabilities: Off
(II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
(II) RADEON(0): First detailed timing is preferred mode
(II) RADEON(0): redX: 0.647 redY: 0.334 greenX: 0.284 greenY: 0.607
(II) RADEON(0): blueX: 0.151 blueY: 0.071 whiteX: 0.313 whiteY: 0.329
(II) RADEON(0): Supported established timings:
(II) RADEON(0): 720x400@70Hz
(II) RADEON(0): 640x480@60Hz
(II) RADEON(0): 640x480@67Hz
(II) RADEON(0): 640x480@72Hz
(II) RADEON(0): 640x480@75Hz
(II) RADEON(0): 800x600@56Hz
(II) RADEON(0): 800x600@60Hz
(II) RADEON(0): 800x600@72Hz
(II) RADEON(0): 800x600@75Hz
(II) RADEON(0): 832x624@75Hz
(II) RADEON(0): 1024x768@60Hz
(II) RADEON(0): 1024x768@70Hz
(II) RADEON(0): 1024x768@75Hz
(II) RADEON(0): 1280x1024@75Hz
(II) RADEON(0): 1152x864@75Hz
(II) RADEON(0): Manufacturer’s mask: 0
(II) RADEON(0): Supported standard timings:
(I
finished all detect
(II) RADEON(0): EDID for output DisplayPort-0
(II) RADEON(0): EDID for output HDMI-0
(II) RADEON(0): EDID for output DVI-1
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Module “ramdac” already built-in
(!!) RADEON(0): MergedFB support has been removed and replaced with xrandr 1.2 support
(II) UnloadModule: “vesa”
(II) Unloading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) UnloadModule: “fbdev”
(II) Unloading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) UnloadModule: “fbdevhw”
(II) Unloading /usr/lib/xorg/modules/linux/libfbdevhw.so
(–) Depth 24 pixmap format is 32 bpp
(II) RADEON(0): RADEONScreenInit d0000000 0 0
Output UNIPHY0 transmitter setup success
Blank CRTC 0 success
Disable CRTC memreq 0 success
Disable CRTC 0 success
Blank CRTC 1 success
(II) RADEON(0): RADEONRestoreMemMapRegisters() :
(II) RADEON(0): MC_FB_LOCATION : 0x00df00d0 0x00df00d0
(II) RADEON(0): MC_AGP_LOCATION : 0x003f0000
Set DCPLL success
Picked PLL 0
before 14850 0x20
Disable CRTC 1 success
Blank CRTC 2 success
Disable CRTC memreq 2 success
Disable CRTC 2 success
Blank CRTC 3 success
Disable CRTC memreq 3 success
Disable CRTC 3 success
Blank CRTC 4 success
Disable CRTC memreq 4 success
Disable CRTC 4 success
Blank CRTC 5 success
Disable CRTC memreq 5 success
Disable CRTC 5 success
(II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
Mode 1920x1080 - 2200 1125 5
Set DCPLL success
Picked PLL 0
before 14850 0x20
after 14850 0 0
best_freq: 148500
best_feedback_div: 88
best_frac_feedback_div: 0
best_ref_div: 2
best_post_div: 8
(II) RADEON(0): crtc(0) Clock: mode 148500, PLL 1485000
(II) RADEON(0): crtc(0) PLL : refdiv 2, fbdiv 0x58(88), fracfbdiv 0, pdiv 8
Set CRTC 0 PLL success
Set DTD CRTC Timing success
Set CRTC 0 Overscan success
Not using RMX
scaler 0 setup success
Set CRTC 0 Source success
crtc 0 YUV disable setup success
Output DIG0 encoder setup success
Enable CRTC 0 success
Enable CRTC memreq 0 success
Unblank CRTC 0 success
(–) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(EE) GLX error: Can not get required symbols.
(II) RADEON(0): Setting screen physical size to 508 x 285
(II) config/udev: Adding input device Power Button (/dev/input/event5)
() Power Button: Applying InputClass “evdev keyboard catchall”
(II) LoadModule: “evdev”
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
() Power Button: always reports core events
() Power Button: Device: “/dev/input/event5”
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD)
() Option “xkb_rules” “evdev”
() Option “xkb_model” “pc105”
() Option “xkb_layout” “fr”
() Option “xkb_variant” “latin9”
(II) config/udev: Adding input device Power Button (/dev/input/event4)
() Power Button: Device: “/dev/input/event4”
(IIcified (ignoring)
(II) config/udev: Adding input device Logitech Logitech Illuminated Keyboard (/dev/input/event2)
() Logitech Logitech Illuminated Keyboard: Applying InputClass “evdev keyboard catchall”
() Logitech Logitech Illuminated Keyboard: always reports core events
() Logitech Logitech Illuminated Keyboard: Device: “/dev/input/event2”
(II) Logitech Logitech Illuminated Keyboard: Found keys
(II) Logitech Logitech Illuminated Keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device “Logitech Logitech Illuminated Keyboard” (type: KEYBOARD)
(**) Option “xkb_variant” "latin9"
ing InputClass “evdev pointer catchall”
(*g)
(II) RADEON(0): EDID vendor “IVM”, prod id 22029
(II) RADEON(0): Using EDID range info for horizontal sync
(II) RADEON(0): Using EDID range info for vertical refresh
(II) RADEON(0): Printing DDC gathered Modelines:
(II) RADEON(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(II) RADEON(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz)
(II) RADEON(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
(II) RADEON(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz)
(II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(II) RADEON(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz)
(II) RADEON(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz)
(II) RADEON(0): Output: DVI-0, Detected Monitor Type: 3
(II) RADEON(0): EDID data from the display on output: DVI-0 ----------------------
(II) RADEON(0): #0: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) RADEON(0): #1: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
(II) RADEON(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
(II) RADEON(0): #3: hsize: 1280 vsize 1024 refresh: 75 vid: 36737
(II) RADEON(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) RADEON(0): #5: hsize: 1440 vsize 900 refresh: 75 vid: 3989
(II) RADEON(0): #6: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) RADEON(0): #7: hsize: 1280 vsize 720 refresh: 60 vid: 49281
(II) RADEON(0): Supported detailed timing:
(II) RADEON(0): clock: 148.5 MHz Image Size: 521 x 293 mm
(II) RADEON(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
(II) RADEON(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
(II) RADEON(0): Serial No: 1100121800218
(II) RADEON(0): Ranges: V min: 55 V max: 76 Hz, H min: 29 H max: 81 kHz, PixClock max 175 MHz
(II) RADEON(0): Monitor name: PLE2407HDS
(II) RADEON(0): EDID (in hex):
(0036
(II) RADEON(0): Using hsync ranges from config file
(II) RADEON(0): Using vrefresh ranges from config file
(II “IVM”, prod id 22029
(IHz
(resh: 75 vid: 36737
(I
(29
(I
D
(I
(II
(II) RADEON(0): EDID vendor “IVM”, prod id 22029[/code]
Comment savoir si ma carte est bien prise en charge par mon systeme?
l’acceleration materielle aussi?
Distrib. : Debian Sqeeze 6.0.7
Noyau : 2.6.32-5-amd64
(G)UI : Gnome2.30.2
