bah la j’voue que le problème me depasse et je ne sais trop quoi chercher…
voici ce que me sort la commande dmesg
Linux version 2.6.15-1-686 (Debian 2.6.15-8) (waldi@debian.org) (gcc version 4.0 .3 20060212 (prerelease) (Debian 4.0.2-9)) #2 Mon Mar 6 15:27:08 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff8000 (ACPI data)
BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
255MB LOWMEM available.
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:0
DMA32 zone: 0 pages, LIFO batch:0
Normal zone: 61424 pages, LIFO batch:15
HighMem zone: 0 pages, LIFO batch:0
DMI not present.
ACPI: RSDP (v000 IBM ) @ 0x000fe030
ACPI: RSDT (v001 IBM NAGANO 0x00000001 IBM 0x00000000) @ 0x0fff0000
ACPI: FADT (v001 IBM NAGANO 0x00000001 IBM 0x00000000) @ 0x0fff0054
ACPI: BOOT (v001 IBM NAGANO 0x00000001 IBM 0x00000000) @ 0x0fff002c
ACPI: DSDT (v001 IBM ThinkPad 0x00001000 MSFT 0x0100000c) @ 0x00000000
ACPI: PM-Timer IO Port: 0xf008
Allocating PCI resources starting at 20000000 (gap: 10000000:efff0000)
Built 1 zonelists
Kernel command line: root=/dev/hda1 ro
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (01201000)
Initializing CPU#0
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 499.210 MHz processor.
Using pmtmr for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 252212k/262080k available (1425k kernel code, 9276k reserved, 530k data, 144k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 998.48 BogoMIPS (lpj=499242)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 0 0000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 128K
CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 0000000 0 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
mtrr: v2.0 (20020519)
CPU: Intel Celeron (Coppermine) stepping 01
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: setting ELCR to 0200 (from 0820)
checking if image is initramfs... it is
Freeing initrd memory: 4434k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0200, last bus=1
PCI: Using configuration type 1
ACPI: Subsystem revision 20050902
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [PILA] (IRQs *5)
ACPI: PCI Interrupt Link [PILB] (IRQs *11)
ACPI: PCI Interrupt Link [PILC] (IRQs *5)
ACPI: PCI Interrupt Link [PILD] (IRQs *11)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
PCI quirk: region f000-f03f claimed by PIIX4 ACPI
PCI quirk: region f100-f10f claimed by PIIX4 SMB
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Embedded Controller [EC0] (gpe 9)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 10 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:09: ioport range 0xf000-0xf03f could not be reserved
pnp: 00:09: ioport range 0xf100-0xf10f has been reserved
pnp: 00:09: ioport range 0x4d0-0x4d1 has been reserved
PCI: Bridge: 0000:00:01.0
IO window: 8000-8fff
MEM window: 80300000-820fffff
PREFETCH window: disabled.
PCI: Bus 2, cardbus bridge: 0000:00:09.0
IO window: 00001000-000010ff
IO window: 00001400-000014ff
PREFETCH window: 20000000-21ffffff
MEM window: 22000000-23ffffff
ACPI: PCI Interrupt Link [PILB] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [PILB] -> GSI 11 (level, low) -> IRQ 11
Simple Boot Flag at 0x6e set to 0x1
audit: initializing netlink socket (disabled)
audit(1142188243.574:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
Limiting direct PCI/PCI transfers.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI wakeup devices:
SLPB OZ68 OBMO USB0 PX40 LID
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 144k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Thermal Zone [THR2] (30 C)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 0000:00:02.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x9040-0x9047, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x9048-0x904f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.3
hda: IBM-DARA-206000, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: TOSHIBA DVD-ROM SD-C2302, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt Link [PILD] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:02.2[D] -> Link [PILD] -> GSI 11 (level, low) -> IRQ 11
uhci_hcd 0000:00:02.2: UHCI Host Controller
uhci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:02.2: irq 11, io base 0x00009000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hub 1-0:1.0: over-current change on port 2
hda: max request size: 128KiB
hda: 11733120 sectors (6007 MB) w/418KiB Cache, CHS=12416/15/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 >
hdc: ATAPI 24X DVD-ROM drive, 128kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: hda1: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 211336
ext3_orphan_cleanup: deleting unreferenced inode 211335
ext3_orphan_cleanup: deleting unreferenced inode 211333
ext3_orphan_cleanup: deleting unreferenced inode 211332
ext3_orphan_cleanup: deleting unreferenced inode 211331
EXT3-fs: hda1: 5 orphan inodes deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
input: PC Speaker as /class/input/input1
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 440BX Chipset.
agpgart: AGP aperture is 64M @ 0xe0000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
piix4_smbus 0000:00:02.3: Found 0000:00:02.3 device
Yenta: CardBus bridge found at 0000:00:09.0 [1025:1007]
Yenta: Enabling burst memory read transactions
Yenta: Using CSCINT to route CSC interrupts to PCI
Yenta: Routing CardBus interrupts to PCI
Yenta TI: socket 0000:00:09.0, mfunc 0x08871c82, devctl 0x64
Yenta: ISA IRQ mask 0x04b8, PCI irq 11
Socket status: 30000020
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
Floppy drive(s): fd0 is 1.44M
FDC 0 is a National Semiconductor PC87306
Real Time Clock Driver v1.12
pccard: CardBus card inserted into slot 0
IBM TrackPoint firmware: 0x0b, buttons: 3/3
input: TPPS/2 IBM TrackPoint as /class/input/input2
ACPI: PCI Interrupt Link [PILA] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [PILA] -> GSI 5 (level, low) -> IRQ 5
gameport: ES1938 is pci0000:00:08.0/gameport0, io 0x7440, speed 1065kHz
cs: IO port probe 0x100-0x4ff: clean.
cs: IO port probe 0x800-0x8ff: clean.
cs: IO port probe 0xc00-0xcff: clean.
cs: IO port probe 0xa00-0xaff: clean.
mice: PS/2 mouse device common for all mice
Adding 273064k swap on /dev/hda5. Priority:-1 extents:1 across:273064k
EXT3 FS on hda1, internal journal
ndiswrapper version 1.10 loaded (preempt=no,smp=no)
ndiswrapper: driver gplus (D-Link,04/09/2004,6.0.0.18) loaded
PCI: Enabling device 0000:02:00.0 (0000 -> 0002)
ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [PILB] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:02:00.0 to 64
ndiswrapper: using irq 11
wlan0: vendor: 'TNET1130'
wlan0: ndiswrapper ethernet device 00:11:95:6c:ed:b2 using driver gplus, 104C:90 66:1186:3B05.5.conf
wlan0: encryption modes supported: WEP; TKIP with WPA
pcmcia: Detected deprecated PCMCIA ioctl usage.
pcmcia: This interface will soon be removed from the kernel; please expect break age unless you upgrade to new tools.
pcmcia: see http://www.kernel.org/pub/linux/utils/kernel/pcmcia/pcmcia.html for details.
cs: memory probe 0xa0000000-0xa0ffffff: excluding 0xa0000000-0xa0ffffff
cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff
cs: warning: no high memory space available!
ACPI: Battery Slot [BAT0] (battery present)
ACPI: AC Adapter [AC] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
wlan0: no IPv6 routers present
ndiswrapper (send_packet_done:592): packet dropped: C0000001
quand aux logs dans quoi dois-je chercher ??
en tout cas merci pour ton aide stonfi
