Over-current change on port 2 hub
voilà, mes usb fonctionne plus, le courant passe mais aucun periph (clef,souris,imprimante,…) n’est reconnu.
peu avant, j’ai eu lors du boot des message du type …over-current change on port … hub.
Qqu aurait-il une idée ?
merci pour votre aide.
:blush:
voici qq fichier:
kernel:
Linux minnie 2.6.18-4-686 #1 SMP Wed May 9 23:03:12 UTC 2007 i686 GNU/Linux
lspci:
00:00.0 Host bridge: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
00:00.1 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
00:00.3 System peripheral: Intel Corporation 82852/82855 GM/GME/PM/GMV Processor to I/O Controller (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
00:02.1 Display controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 81)
00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC’97 Audio Controller (rev 01)
00:1f.6 Modem: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC’97 Modem Controller (rev 01)
02:00.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev 8d)
02:00.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 13)
02:01.0 Ethernet controller: Intel Corporation 82541GI Gigabit Ethernet Controller
02:02.0 Ethernet controller: Atheros Communications Inc. AR5212 802.11abg NIC (rev 01)
lsusb:
Bus 004 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
dmicode:
dmidecode 2.9
SMBIOS 2.33 present.
56 structures occupying 1945 bytes.
Table at 0x000E0010.
Handle 0x0000, DMI type 0, 20 bytes
BIOS Information
Vendor: IBM
Version: 1UETA5WW (1.55 )
Release Date: 01/07/2005
Address: 0xDC000
Runtime Size: 144 kB
ROM Size: 1024 kB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
EDD is supported
3.5"/720 KB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
AGP is supported
BIOS boot specification is supported
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: IBM
Product Name: 2371H9G
Version: ThinkPad X40
Serial Number: 99WF969
UUID: DB324E81-4764-11CB-97D2-D0235165A4FF
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer: IBM
Version: Not Available
Serial Number: 1Z9TZ53B1LA
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Manufacturer: IBM
Type: Notebook
Lock: Not Present
Serial Number: Not Available
Asset Tag: No Asset Information
Boot-up State: Unknown
Power Supply State: Unknown
Thermal State: Unknown
Security Status: Unknown
OEM Information: 0x00000000
Handle 0x0004, DMI type 126, 17 bytes
Inactive
Handle 0x0005, DMI type 126, 17 bytes
Inactive
Handle 0x0006, DMI type 4, 35 bytes
Processor Information
Socket Designation: None
Type: Central Processor
Family: Pentium M
Manufacturer: GenuineIntel
ID: D6 06 00 00 BF FB E9 AF
Signature: Type 0, Family 6, Model 13, Stepping 6
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel® Pentium® M processor
Voltage: 1.1 V
External Clock: 400 MHz
Max Speed: 1400 MHz
Current Speed: 1400 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x000A
L2 Cache Handle: 0x000B
L3 Cache Handle: Not Provided
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0007, DMI type 5, 20 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 1024 MB
Maximum Total Memory Size: 2048 MB
Supported Speeds:
Other
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 2.9 V
Associated Memory Slots: 2
0x0008
0x0009
Enabled Error Correcting Capabilities:
None
Handle 0x0008, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: DIMM Slot 1
Bank Connections: 0 1
Current Speed: Unknown
Type: DIMM SDRAM
Installed Size: 512 MB (Double-bank Connection)
Enabled Size: 512 MB (Double-bank Connection)
Error Status: OK
Handle 0x0009, DMI type 6, 12 bytes
Socket Designation: DIMM Slot 2
Bank Connections: 2 3
Type: DIMM SDRAM
Installed Size: Not Installed
Enabled Size: Not Installed
Error Status: OK
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: Internal L1 Cache
Configuration: Enabled, Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 KB
Maximum Size: 32 KB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Other
Associativity: 8-way Set-associative
Handle 0x000B, DMI type 7, 19 bytes
Cache Information
Socket Designation: Internal L2 Cache
Configuration: Enabled, Socketed, Level 2
Installed Size: 2048 KB
Maximum Size: 2048 KB
Burst
Installed SRAM Type: Burst
Speed: Unknown
Error Correction Type: Multi-bit ECC
System Type: Unified
Handle 0x000C, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: Not Available
Internal Connector Type: None
External Reference Designator: Serial
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000D, DMI type 8, 9 bytes
External Reference Designator: Infrared
External Connector Type: Infrared
Port Type: Other
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: Parallel
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: External Monitor
External Connector Type: DB-15 female
Port Type: Video Port
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: PS/2 Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0011, DMI type 126, 9 bytes
Inactive
Handle 0x0012, DMI type 126, 9 bytes
Inactive
Handle 0x0013, DMI type 126, 9 bytes
Inactive
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: Microphone Jack
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: Headphone Jack
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: Modem
External Connector Type: RJ-11
Port Type: Modem Port
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: Ethernet
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0018, DMI type 8, 9 bytes
External Reference Designator: USB 1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0019, DMI type 8, 9 bytes
External Reference Designator: USB 2
Port Type: USB
Handle 0x001A, DMI type 126, 9 bytes
Inactive
Handle 0x001B, DMI type 126, 9 bytes
Inactive
Handle 0x001C, DMI type 126, 9 bytes
Inactive
Handle 0x001D, DMI type 9, 13 bytes
System Slot Information
Designation: CardBus Slot 1
Type: 32-bit PC Card (PCMCIA)
Current Usage: Available
Length: Other
ID: Adapter 0, Socket 0
Characteristics:
5.0 V is provided
3.3 V is provided
PC Card-16 is supported
Cardbus is supported
Zoom Video is supported
Modem ring resume is supported
PME signal is supported
Hot-plug devices are supported
Handle 0x001E, DMI type 126, 13 bytes
Inactive
Handle 0x001F, DMI type 126, 13 bytes
Inactive
Handle 0x0020, DMI type 9, 13 bytes
Designation: SD Slot
Type: 32-bit Other
Length: Other
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x0021, DMI type 9, 13 bytes
Designation: Mini-PCI Slot 1
Type: 32-bit PCI
Length: Other
Characteristics:
5.0 V is provided
3.3 V is provided
SMBus signal is supported
Handle 0x0022, DMI type 126, 13 bytes
Inactive
Handle 0x0023, DMI type 10, 6 bytes
On Board Device Information
Type: Other
Status: Disabled
Description: IBM Embedded Security hardware
Handle 0x0024, DMI type 11, 5 bytes
OEM Strings
String 1: IBM ThinkPad Embedded Controller -[1UHTA6WW-1.56 ]-
Handle 0x0025, DMI type 13, 22 bytes
BIOS Language Information
Installable Languages: 1
enUS
Currently Installed Language: enUS
Handle 0x0026, DMI type 15, 25 bytes
System Event Log
Area Length: 0 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Invalid, Not Full
Change Token: 0x00000000
Header Format: Type 1
Supported Log Type Descriptors: 1
Descriptor 1: POST error
Data Format 1: POST results bitmap
Handle 0x0027, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 1 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0028, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0027
Error Information Handle: No Error
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 1
Bank Locator: Bank 0/1
Type: DDR
Type Detail: Synchronous
Speed: Unknown
Manufacturer: Not Specified
Handle 0x0029, DMI type 17, 27 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: SODIMM
Set: None
Locator: DIMM 2
Bank Locator: Bank 2/3
Type: DDR
Speed: Unknown
Handle 0x002A, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x002B, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0001FFFFFFF
Range Size: 512 MB
Physical Array Handle: 0x0027
Partition Width: 0
Handle 0x002C, DMI type 20, 19 bytes
Memory Device Mapped Address
Range Size: 512 MB
Physical Device Handle: 0x0028
Memory Array Mapped Address Handle: 0x002B
Partition Row Position: 1
Handle 0x002D, DMI type 126, 19 bytes
Inactive
Handle 0x002E, DMI type 21, 7 bytes
Built-in Pointing Device
Type: Track Point
Interface: PS/2
Buttons: 3
Handle 0x002F, DMI type 126, 7 bytes
Inactive
Handle 0x0030, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Disabled
Administrator Password Status: Disabled
Front Panel Reset Status: Unknown
Handle 0x0031, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x0032, DMI type 131, 102 bytes
OEM-specific Type
Header and Data:
83 66 32 00 01 00 00 00 00 01 72 03 40 00 AE 80
00 02 00 00 00 00 00 2A 00 40 2A 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 16 00 80 16 00 00
00 00 00 00 00 00
Strings:
IBMCFGDATA
Handle 0x0033, DMI type 131, 17 bytes
OEM-specific Type
Header and Data:
83 11 33 00 01 02 03 FF FF 1F 00 00 00 00 00 02
00
Strings:
BOOTINF 20h
BOOTDEV 21h
KEYPTRS 23h
Handle 0x0034, DMI type 132, 7 bytes
OEM-specific Type
Header and Data:
84 07 34 00 01 D8 36
Handle 0x0035, DMI type 133, 5 bytes
OEM-specific Type
Header and Data:
85 05 35 00 01
Strings:
KHOIHGIUCCHHII
Handle 0x0036, DMI type 134, 13 bytes
OEM-specific Type
Header and Data:
86 0D 36 00 10 04 05 20 00 00 00 00 00
Handle 0x0037, DMI type 127, 4 bytes
End Of Table
dmesg /var/log/messages:
Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed May 9 23:03:12 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001f6e0000 (usable)
BIOS-e820: 000000001f6e0000 - 000000001f6f7000 (ACPI data)
BIOS-e820: 000000001f6f7000 - 000000001f6f9000 (ACPI NVS)
BIOS-e820: 000000001f700000 - 0000000020000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ff800000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
502MB LOWMEM available.
On node 0 totalpages: 128736
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 124640 pages, LIFO batch:31
DMI present.
ACPI: RSDP (v002 IBM ) @ 0x000f7020
ACPI: XSDT (v001 IBM TP-1U 0x00001550 LTP 0x00000000) @ 0x1f6e9b7e
ACPI: FADT (v003 IBM TP-1U 0x00001550 IBM 0x00000001) @ 0x1f6e9c00
ACPI: SSDT (v001 IBM TP-1U 0x00001550 MSFT 0x0100000e) @ 0x1f6e9db4
ACPI: ECDT (v001 IBM TP-1U 0x00001550 IBM 0x00000001) @ 0x1f6f6da9
ACPI: TCPA (v001 IBM TP-1U 0x00001550 PTL 0x00000001) @ 0x1f6f6dfb
ACPI: MADT (v001 IBM TP-1U 0x00001550 IBM 0x00000001) @ 0x1f6f6e2d
ACPI: BOOT (v001 IBM TP-1U 0x00001550 LTP 0x00000001) @ 0x1f6f6fd8
ACPI: DSDT (v001 IBM TP-1U 0x00001550 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:13 APIC version 20
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Detected 1395.548 MHz processor.
Built 1 zonelists. Total pages: 128736
Kernel command line: root=/dev/hda1 ro vga=791
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 502192k/514944k available (1544k kernel code, 12244k reserved, 577k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 2792.82 BogoMIPS (lpj=5585658)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: afe9fbbf 00000000 00000000 00000000 00000180 00000000 00000000
CPU: After vendor identify, caps: afe9fbbf 00000000 00000000 00000000 00000180 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: After all inits, caps: afe9fbbf 00000000 00000000 00000040 00000180 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
CPU0: Intel® Pentium® M processor 1.40GHz stepping 06
Total of 1 processors activated (2792.82 BogoMIPS).
ENABLING IO-APIC IRQs
…TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs… it is
Freeing initrd memory: 5131k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd8c8, last bus=5
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Found ECDT
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:02.0
PCI quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region 1180-11bf claimed by ICH4 GPIO
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: Embedded Controller [EC] (gpe 28) interrupt mode.
ACPI: Power Resource [PUBS] (on)
.PCI0.PCI1.PRT]
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 10 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
PCI: Bus 3, cardbus bridge: 0000:02:00.0
IO window: 00003000-000030ff
IO window: 00003400-000034ff
PREFETCH window: f0000000-f1ffffff
MEM window: d2000000-d3ffffff
PCI: Bridge: 0000:00:1e.0
IO window: 3000-7fff
MEM window: d0200000-dfffffff
PREFETCH window: f0000000-f7ffffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 16 (level, low) -> IRQ 169
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x35 set to 0x1
audit: initializing netlink socket (disabled)
audit(1269332429.128:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
vesafb: framebuffer at 0xe0000000, mapped to 0xe0080000, using 3072k, total 8000k
vesafb: mode is 1024x768x16, linelength=2048, pages=4
vesafb: protected mode interface info at 00ff:44f0
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
ACPI: PCI Interrupt 0000:00:1f.6[B] -> GSI 17 (level, low) -> IRQ 177
ACPI: PCI interrupt for device 0000:00:1f.6 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
Time: tsc clocksource has been installed.
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU] (supports 8 throttling states)
ACPI: Thermal Zone [THM0] (33 C)
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 16 (level, low) -> IRQ 169
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 169, io base 0x00001820
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 185
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 185, io base 0x00001840
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
sdhci: Secure Digital Host Controller Interface driver, 0.12
sdhci: Copyright© Pierre Ossman
Intel® PRO/1000 Network Driver - version 7.1.9-k4-NAPI
Copyright © 1999-2006 Intel Corporation.
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 193
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 193, io base 0x00001860
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.7[D] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 201, io mem 0xd0100000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found<
_________________!!!
hub 4-0:1.0: 6 ports detected
En ne donnant aucune indication sur ton matériel ni sur ton installation, tu risques de ne pas avoir de réponses :slightly_smiling:
Merci, pour cette remarque je vais y remédier
:wink:
