Package manager cesse de fonctionner !
bonjour
j’ai un problème avec mon package manager
[code]root@debian:/opt# apt-get install ia32-libs
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ia32-libs : Depends: ia32-libs-i386 but it is not installable
E: Unable to correct problems, you have held broken packages.
j’ai utilisé
dpkg --configure -a
apt-get install -f
sudo apt-get clean && sudo apt-get update
sudo apt-get upgrade
et c’est toujours bloqué !! pour ce Package , mais avec les autres Package il marche
[16:27:09][root@Sid] ~ # apt-cache policy i32-libs N: Impossible de trouver le paquet i32-libs [16:27:14][root@Sid] ~ #
Selon ton architecture, 32, 64 bits …
[16:27:54][root@Sid] ~ # aptitude install ia32-libs-i386
Cela ira bien mieux …
Non, ça ne marche pas
root@debian:/opt# aptitude install ia32-libs-i386 No candidate version found for ia32-libs-i386 No candidate version found for ia32-libs-i386 No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used.
ia32-libs-i386:i386: Installé : 1:0.4 Candidat : 1:0.4 Table de version : *** 1:0.4 0 500 http://ftp.fr.debian.org/debian/ testing/main i386 Packages 990 http://ftp.fr.debian.org/debian/ unstable/main i386 Packages 100 /var/lib/dpkg/status
Que cherches tu à installer, dans quel but ?
Quel sont ces retours …
[quote=“BelZéButh”]Que cherches tu à installer, dans quel but ?
root@debian:/opt# apt-cache policy ia32-libs-i386 ia32-libs-i386: Installed: (none) Candidate: (none) Version table:
[code]root@debian:/opt# cat /etc/apt/sources.list
deb cdrom:[Debian GNU/Linux wheezy-DI-rc1 Wheezy - Official Snapshot amd64 NETINST Binary-1 20130214-22:44]/ wheezy main
#deb cdrom:[Debian GNU/Linux wheezy-DI-rc1 Wheezy - Official Snapshot amd64 NETINST Binary-1 20130214-22:44]/ wheezy main
deb http://ftp.us.debian.org/debian/ wheezy main
deb-src http://ftp.us.debian.org/debian/ wheezy main
deb http://security.debian.org/ wheezy/updates main
deb-src http://security.debian.org/ wheezy/updates main
mon objectif est d’installer firefox et skype
[quote]ggoodluck47
je n’ai pas compris vorte message
Modifies ton sources.list et recharge. (aptitude update)
[quote]deb ftp.us.debian.org/debian/ wheezy main contrib
#deb-src ftp.fr.debian.org/debian/ wheezy main contrib
deb security.debian.org/ wheezy/updates main contrib
#deb-src security.debian.org/ wheezy/updates main contrib
Notes: firefox sous Debian se nomme iceweasel
[17:33:18][root@Sid] ~ # acp iceweasel iceweasel: Installé : 19.0.2-1 Candidat : 19.0.2-1 Épinglage de paquet : 19.0.2-1 Table de version : *** 19.0.2-1 -30000 98 http://ftp.fr.debian.org/debian/ experimental/main i386 Packages 100 /var/lib/dpkg/status 10.0.12esr-1+nmu1 -30000 990 http://ftp.fr.debian.org/debian/ sid/main i386 Packages 10.0.12esr-1 -30000 980 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages 10.0.12esr-1~bpo60+1 -30000 100 http://backports.debian.org/debian-backports/ squeeze-backports/main i386 Packages 3.5.16-20 -30000 983 http://ftp.fr.debian.org/debian/ squeeze/main i386 Packages 985 http://security.debian.org/ squeeze/updates/main i386 Packages [17:33:21][root@Sid] ~ #
[quote=“BelZéButh”]Modifies ton sources.list et recharge. (aptitude update)
[17:33:18][root@Sid] ~ # acp iceweasel iceweasel: Installé : 19.0.2-1 Candidat : 19.0.2-1 Épinglage de paquet : 19.0.2-1 Table de version : *** 19.0.2-1 -30000 98 http://ftp.fr.debian.org/debian/ experimental/main i386 Packages 100 /var/lib/dpkg/status 10.0.12esr-1+nmu1 -30000 990 http://ftp.fr.debian.org/debian/ sid/main i386 Packages 10.0.12esr-1 -30000 980 http://ftp.fr.debian.org/debian/ wheezy/main i386 Packages 10.0.12esr-1~bpo60+1 -30000 100 http://backports.debian.org/debian-backports/ squeeze-backports/main i386 Packages 3.5.16-20 -30000 983 http://ftp.fr.debian.org/debian/ squeeze/main i386 Packages 985 http://security.debian.org/ squeeze/updates/main i386 Packages [17:33:21][root@Sid] ~ # [/quote]
j’ai modifie mon sources.list et ça marche pas, j’ai une version testing amd64 , même pour installer skype j’ai le problème d’architecture, c’est pour çela je veux installer ia32-libs
Ce paquet n’est pas disponible en amd64.
packages.debian.org/search?suite … -libs-i386
[quote]Certains résultats n’ont pas été affichés en raison des paramètres de recherche.
Vous avez recherché des paquets dont les noms contiennent ia32-libs-i386 dans toutes les suites, toutes les sections, et architecture(s) amd64.
Désolé, votre recherche n’a renvoyé aucun résultat.
Cependant fran.b à créer un dépôt à cette effet (ou le contraire, je ne sais plus) , je recherche le lien …
Je savais bien …
Faire tourner du 32 bits sur 64 bits ou du vieux sur du neuf
[quote=“fran.b”]Cette situation arrive dans les cas suivants:
  • Vous avez une architecture amd64 et c’est un programme i386
  • Vous avez un logiciel propriétaire indispensable, cher et que vous vous devez utiliser mais qui date de 10 ans ou presque
Bien, évidemment ici on suppose que tout a été fait pour avoir la version correcte correspondant à votre architecture.
Bon 3 problèmes se posent
  1. C’est un programme 32 bits sur une machine 64 bits ou encore un programme où il manque des librairies
  2. Le programme utilise une vieille libc6.
  3. la libc5
    Tout d’abord le premier point
  4. Rajout de librairies 32 bits ou de librairies manquantes.
etc …[/quote]
* edit *
Notes: concernant skype tu as un paquet mis à disposition par fran.b
[18:26:12][root@Sid] ~ # acp skype skype: Installé : (aucun) Candidat : 2.0.0.68-1 Table de version : 2.0.0.68-1 0 500 http://boisson.homeip.net/debian/ squeeze/divers i386 Packages [18:26:21][root@Sid] ~ #
* edit *
~ # acp skype
acp est un aliases pour ~ $ apt-cache policy skype
merci pour votre aide,
pour moi, c’est encore flou. pour cette commande acp, j’ai essayé de l’installer avec “apt-get install acp” et je ne l’ai pas trouvé.
et comment obtenir ce paquet de Skype ?
Je te donne simplement l’adresse des dépôts qu’il faut avoir pour trouver ia32 :slightly_smiling:
Bonsoir,
C’est normal que le paquet ia32libs-i386 n’existe plus en Wheezy. Wheezy introduit la notion de multi-architecture, permettant d’installer des paquets d’architectures différentes sur son système. Il faut seulement indiquer à dpkg quelles architectures on souhaite :
[code]# dpkg --add-architecture i386
apt-get update[/code]
La suite devrait bien se dérouler.
Source : debian.org/releases/testing/ … l#ia32libs
[quote=“alpha”]merci pour votre aide,
acp est une abréviation de apt-cache policy donc rien a installer
merci à vous tous, ça a marché , après ajouter cette commande
merci encore un fois.
Oui, bien vu.
Su ma Sid le ia32-libs-i386:i386 est marqué comme “Transitional package to migrate ia32-libs to multiarch”
“It can be removed once nothing on the system depends on it.”
Mais je n’arrive pas encore à m’en débarrasser à cause de google-earth. Ça viendra! :wink:
[quote=“lol”]Salut,
Oui, bien vu.
Mais je n’arrive pas encore à m’en débarrasser à cause de google-earth. Ça viendra! :wink:[/quote]
Commence par virer pieuvre-earth :005
Difficile de trouver un remplaçant à la hauteur…
[quote=“lol”]Salut,
Difficile de trouver un remplaçant à la hauteur…[/quote]
Il est vrai, mais j’ai trouvé ça par exemple.
http://www.geoportail.gouv.fr/accueil
http://worldwind.arc.nasa.gov/java/
Enfin là on digresse un peu beaucoup :blush:
Bon…
J’ai viré ia32 et cie.
Un petit hack sur le deb google-earth pour virer la dépendance, et ça roule.
Skype n’a pas bronché non plus.
Tout fonctionne très bien sans ces bibliothèques à la c… Merci Mr. multiarch! :023
