Pour me connecter à un intranet j’utilise le module AuthPam d’apache et derrière c’est winbind qui fait la liaison avec l’ACTIVE directroy de windows.
Je souhaite dès la connexion monter un disque réseau.
Pour cela j’ai ajouté dans le fichier /etc/security/pam_mount.conf.xml
[code]<?xml version="1.0" encoding="utf-8" ?>
<pam_mount>
<!-- debug should come before everything else,
since this file is still processed in a single pass
from top-to-bottom -->
/usr/bin/lsof %(MNTPT)
<!-- pam_mount parameters: General tunables -->
<!-- pam_mount parameters: Volume-related -->
</pam_mount>[/code]
Ma config pam apache2
auth sufficient pam_winbind.so
auth sufficient pam_unix.so use_first_pass
auth required pam_deny.so
auth required pam_unix.so use_first_pass
auth required pam_mount.so use_first_pass
@include common-auth
@include common-account
@include common-password
@include common-session-noninteractive
@include common-pammount
Mais le disque ne se monte pas. que faut-il faire ?
Voila ce que j’ai dans mes log apache.
Jul 2 09:19:58 srvintranet2 apache2: pam_winbind(apache2:auth): getting password (0x00000000)
Jul 2 09:19:58 srvintranet2 apache2: pam_winbind(apache2:auth): user 'intranet5' granted access
Jul 2 09:19:58 srvintranet2 apache2: pam_winbind(apache2:account): user 'intranet5' granted access
Merci de m’aider.
