pour se mettre en appétit:
ce n’est qu’un warning
Mar 2 09:17:59 alpha30 kernel: [ 5.644225] ACPI Warning: 0x0000000000000428-0x000000000000042f SystemIO conflicts with Region \GP2C 1 (20131115/utaddress-251)
Mar 2 09:17:59 alpha30 kernel: [ 5.644231] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Mar 2 09:17:59 alpha30 kernel: [ 5.644251] lpc_ich: Resource conflict(s) found affecting gpio_ich
Mar 2 09:17:59 alpha30 kernel: [ 5.647914] microcode: CPU2 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.648005] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.648009] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.677167] iTCO_vendor_support: vendor-support=0
Mar 2 09:17:59 alpha30 kernel: [ 5.678466] microcode: CPU3 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.678548] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.678550] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.682014] microcode: CPU4 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.682095] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.682097] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.683470] microcode: CPU5 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.683556] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.683558] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.685061] microcode: CPU6 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.685148] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.685150] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.686551] microcode: CPU7 sig=0x106a5, pf=0x2, revision=0x11
Mar 2 09:17:59 alpha30 kernel: [ 5.686634] platform microcode: Direct firmware load failed with error -2
Mar 2 09:17:59 alpha30 kernel: [ 5.686636] platform microcode: Falling back to user helper
Mar 2 09:17:59 alpha30 kernel: [ 5.687782] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Mar 2 09:17:59 alpha30 kernel: [ 5.719492] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.10
Mar 2 09:17:59 alpha30 kernel: [ 5.719513] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
Mar 2 09:17:59 alpha30 kernel: [ 5.837875] psmouse serio1: alps: Unknown ALPS touchpad: E7=10 00 64, EC=10 00 64
Mar 2 09:17:59 alpha30 kernel: [ 5.903524] [drm] initializing kernel modesetting (CEDAR 0x1002:0x68F9 0x1043:0x0386).
sur chaque core et il manquerait un fichier (erreur -2)
pour vous mettre en appétit:
NMI backtrace for cpu 2
Mar 2 09:40:02 alpha30 kernel: [ 1341.280471] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G O 3.13.0-20140203 #1
Mar 2 09:40:02 alpha30 kernel: [ 1341.280473] Hardware name: Gigabyte Technology Co., Ltd. X58A-UD3R/X58A-UD3R, BIOS FE 12/23/2010
Mar 2 09:40:02 alpha30 kernel: [ 1341.280476] task: ffff8801988af090 ti: ffff8801988de000 task.ti: ffff8801988de000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280478] RIP: 0010:[<ffffffff810a33fa>] [<ffffffff810a33fa>] cpu_startup_entry+0x17a/0x290
Mar 2 09:40:02 alpha30 kernel: [ 1341.280485] RSP: 0018:ffff8801988dfef0 EFLAGS: 00000246
Mar 2 09:40:02 alpha30 kernel: [ 1341.280487] RAX: 0000000400000000 RBX: ffff8801988dffd8 RCX: 0100000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280489] RDX: ffff8801988dffd8 RSI: 0000000000000000 RDI: 0000000000000086
Mar 2 09:40:02 alpha30 kernel: [ 1341.280491] RBP: ffffffff818a0160 R08: 0000000000000000 R09: 0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280494] R10: 00000000000042b9 R11: 0000000000000000 R12: ffff8801988dffd8
Mar 2 09:40:02 alpha30 kernel: [ 1341.280496] R13: ffff8801988dffd8 R14: 0000000000000000 R15: 0000000000000002
Mar 2 09:40:02 alpha30 kernel: [ 1341.280498] FS: 0000000000000000(0000) GS:ffff88019fc40000(0000) knlGS:0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280500] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Mar 2 09:40:02 alpha30 kernel: [ 1341.280503] CR2: 00007f4ca0112000 CR3: 00000000d97fb000 CR4: 00000000000007e0
Mar 2 09:40:02 alpha30 kernel: [ 1341.280504] Stack:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280506] ffff8801988dffd8 c343b8909c3bb31a 0000000000000002 0000000000000002
Mar 2 09:40:02 alpha30 kernel: [ 1341.280510] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280513] ffffffff8103c224 53e5aaa406a2d25a 0000000000000000 0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280517] Call Trace:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280524] [<ffffffff8103c224>] ? start_secondary+0x1d4/0x230
Mar 2 09:40:02 alpha30 kernel: [ 1341.280525] Code: 25 c4 b0 00 00 85 c0 7f 7d fb 66 66 90 66 66 90 65 48 8b 14 25 30 c8 00 00 48 8b 82 38 e0 ff ff a8 08 75 12 0f 1f 44 00 00 f3 90 <48> 8b 82 38 e0 ff ff a8 08 74 f3 8b 05 dd 78 7f 00 65 44 8b 3c
Mar 2 09:40:02 alpha30 kernel: [ 1341.280567] NMI backtrace for cpu 3
Mar 2 09:40:02 alpha30 kernel: [ 1341.280576] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G O 3.13.0-20140203 #1
Mar 2 09:40:02 alpha30 kernel: [ 1341.280584] Hardware name: Gigabyte Technology Co., Ltd. X58A-UD3R/X58A-UD3R, BIOS FE 12/23/2010
Mar 2 09:40:02 alpha30 kernel: [ 1341.280591] task: ffff8801988b1790 ti: ffff8801988e0000 task.ti: ffff8801988e0000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280598] RIP: 0010:[<ffffffff810a33fa>] [<ffffffff810a33fa>] cpu_startup_entry+0x17a/0x290
Mar 2 09:40:02 alpha30 kernel: [ 1341.280611] RSP: 0018:ffff8801988e1ef0 EFLAGS: 00000246
Mar 2 09:40:02 alpha30 kernel: [ 1341.280616] RAX: 0000000400000000 RBX: ffff8801988e1fd8 RCX: 0100000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280618] RDX: ffff8801988e1fd8 RSI: 0000000000000000 RDI: 0000000000000086
Mar 2 09:40:02 alpha30 kernel: [ 1341.280620] RBP: ffffffff818a0160 R08: 0000000000000000 R09: ffff88019fcb4240
Mar 2 09:40:02 alpha30 kernel: [ 1341.280622] R10: 000000000000049a R11: 0000000000000442 R12: ffff8801988e1fd8
Mar 2 09:40:02 alpha30 kernel: [ 1341.280624] R13: ffff8801988e1fd8 R14: 0000000000000000 R15: 0000000000000003
Mar 2 09:40:02 alpha30 kernel: [ 1341.280627] FS: 0000000000000000(0000) GS:ffff88019fc60000(0000) knlGS:0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280629] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Mar 2 09:40:02 alpha30 kernel: [ 1341.280631] CR2: 00007f4ca0112000 CR3: 0000000196d90000 CR4: 00000000000007e0
Mar 2 09:40:02 alpha30 kernel: [ 1341.280633] Stack:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280635] ffff8801988e1fd8 291ed20848f4b17e 0000000000000003 0000000000000003
Mar 2 09:40:02 alpha30 kernel: [ 1341.280639] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280642] ffffffff8103c224 11ccbd0eeeeddc0a 0000000000000000 0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280646] Call Trace:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280651] [<ffffffff8103c224>] ? start_secondary+0x1d4/0x230
Mar 2 09:40:02 alpha30 kernel: [ 1341.280653] Code: 25 c4 b0 00 00 85 c0 7f 7d fb 66 66 90 66 66 90 65 48 8b 14 25 30 c8 00 00 48 8b 82 38 e0 ff ff a8 08 75 12 0f 1f 44 00 00 f3 90 <48> 8b 82 38 e0 ff ff a8 08 74 f3 8b 05 dd 78 7f 00 65 44 8b 3c
Mar 2 09:40:02 alpha30 kernel: [ 1341.280863] NMI backtrace for cpu 6
Mar 2 09:40:02 alpha30 kernel: [ 1341.280867] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G O 3.13.0-20140203 #1
Mar 2 09:40:02 alpha30 kernel: [ 1341.280869] Hardware name: Gigabyte Technology Co., Ltd. X58A-UD3R/X58A-UD3R, BIOS FE 12/23/2010
Mar 2 09:40:02 alpha30 kernel: [ 1341.280871] task: ffff8801988b2050 ti: ffff8801988ea000 task.ti: ffff8801988ea000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280873] RIP: 0010:[<ffffffff810190d0>] [<ffffffff810190d0>] native_read_tsc+0x0/0x10
Mar 2 09:40:02 alpha30 kernel: [ 1341.280879] RSP: 0018:ffff88019fcc3dd8 EFLAGS: 00000006
Mar 2 09:40:02 alpha30 kernel: [ 1341.280881] RAX: 0000027cf046a4b2 RBX: 00000000f046a4b2 RCX: 0000000000f3f7a8
Mar 2 09:40:02 alpha30 kernel: [ 1341.280883] RDX: 0000027cf046a4b2 RSI: 0000000000000200 RDI: 0000000000030675
Mar 2 09:40:02 alpha30 kernel: [ 1341.280885] RBP: 0000000000030675 R08: ffffffff818a0160 R09: 000000000000050b
Mar 2 09:40:02 alpha30 kernel: [ 1341.280887] R10: 0000000000000000 R11: ffff88019fcc3bbe R12: 0000000000000006
Mar 2 09:40:02 alpha30 kernel: [ 1341.280889] R13: 0000000000000096 R14: 0000000000000002 R15: 0000000000000007
Mar 2 09:40:02 alpha30 kernel: [ 1341.280892] FS: 0000000000000000(0000) GS:ffff88019fcc0000(0000) knlGS:0000000000000000
Mar 2 09:40:02 alpha30 kernel: [ 1341.280894] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Mar 2 09:40:02 alpha30 kernel: [ 1341.280896] CR2: 00007fff50c26808 CR3: 00000000d971f000 CR4: 00000000000007e0
Mar 2 09:40:02 alpha30 kernel: [ 1341.280898] Stack:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280899] ffffffff8127248a 00000000000003e9 0000000000001000 0000000000000400
Mar 2 09:40:02 alpha30 kernel: [ 1341.280903] ffffffff8103dd82 000000000000b0ca ffffffff818a0160 ffffffff8103f709
Mar 2 09:40:02 alpha30 kernel: [ 1341.280907] 0000000000000007 0000000000002710 ffffffff8183e180 0000000000000006
Mar 2 09:40:02 alpha30 kernel: [ 1341.280911] Call Trace:
Mar 2 09:40:02 alpha30 kernel: [ 1341.280912] <IRQ>
Mar 2 09:40:02 alpha30 kernel: [ 1341.280914] [<ffffffff8127248a>] ? delay_tsc+0x3a/0x70
Mar 2 09:40:02 alpha30 kernel: [ 1341.280922] [<ffffffff8103dd82>] ? native_safe_apic_wait_icr_idle+0x22/0x50
Mar 2 09:40:02 alpha30 kernel: [ 1341.280927] [<ffffffff8103f709>] ? default_send_IPI_mask_sequence_phys+0xd9/0xe0
Mar 2 09:40:02 alpha30 kernel: [ 1341.280931] [<ffffffff8103f8b3>] ? arch_trigger_all_cpu_backtrace+0x93/0xd0
Mar 2 09:40:02 alpha30 kernel: [ 1341.280935] [<ffffffff810ad8f0>] ? rcu_check_callbacks+0x5a0/0x630
Mar 2 09:40:02 alpha30 kernel: [ 1341.280940] [<ffffffff810b74d0>] ? tick_sched_handle.isra.16+0x60/0x60
si vous en voulez pour le désert
Bon app
JB1
