j’essaie , j’essaie , mais je trouve pas . ou plutôt , je trouve ceci :
root@debian-alain:/home/alain-bellec# apt-cache show libsane-dev
Package: libsane-dev
Source: sane-backends
Version: 1.0.24-8+deb8u1
Installed-Size: 15659
Maintainer: Jörg Frings-Fürst debian@jff-webhosting.net
Architecture: amd64
Replaces: libsane-extras-dev (<< 1.0.18.14)
Depends: libavahi-client-dev, libgphoto2-2-dev, libieee1284-3-dev, libjpeg-dev, libsane (= 1.0.24-8+deb8u1), libtiff-dev, libusb-1.0-0-dev, libv4l-dev, pkg-config
Recommends: libsane-extras-dev
Description-en: API development library for scanners [development files]
SANE stands for “Scanner Access Now Easy” and is an application
programming interface (API) that provides standardized access to any
raster image scanner hardware (flatbed scanner, hand-held scanner,
video- and still-cameras, frame-grabbers, etc.). The SANE standard is
free and its discussion and development are open to everybody. The
current source code is written to support several operating systems,
including GNU/Linux, OS/2, Win32 and various Unices and is available
under the GNU General Public License (commercial applications and
backends are welcome, too, however).
This package contains the files needed to build your applications
using SANE.
Description-md5: e6830c8c64fd71c7d57f14514612572c
Homepage: http://www.sane-project.org
Tag: devel::library, role::devel-lib, works-with::image,
works-with::image:raster
Section: libdevel
Priority: optional
Filename: pool/main/s/sane-backends/libsane-dev_1.0.24-8+deb8u1_amd64.deb
MD5sum: 3a99fcee6b3b8ea894c702c568cc7765
SHA1: ec47ea538acba9a8bf2150121361d40d08ae8de3
SHA256: 70b1f22cfa8e9dc9373a6e9efb84ed369ed105b6312e8443173d7cb78d48b126
root@debian-alain:/home/alain-bellec# apt-get --reinstall install libsane-dev
que vous avez demandé l’impossible, ou bien, si vous utilisez
la distribution unstable, que certains paquets n’ont pas encore
été créés ou ne sont pas sortis d’Incoming.
L’information suivante devrait vous aider à résoudre la situation :
libsane-dev : Dépend: libgphoto2-2-dev mais ne sera pas installé
E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l’état ».
root@debian-alain:/home/alain-bellec# apt-get --reinstall install libgphoto2-2-dev
libgphoto2-2-dev : Dépend: libgphoto2-dev (= 2.5.4-1.1+b2) mais ne sera pas installé
voilà un début de réponse mais , partant de là on fait quoi ?
partant de là , je ne sais plus quoi faire …
j’aimerai bien quand mème , que quelqun m’apprenne à me dépanner pour les paquets cassés . je vais pas tout le temps vous appeler à l’aide .
vous e n aurez très vite marre …
