Coucou. ![]()
J’ai viré KDM pour installer Slim à la place.
J’ai modifié le fichier de configuration original slim.conf de la sorte :
# Path, X server and arguments (if needed)
# Note: -xauth $authfile is automatically appended
default_path /usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
default_xserver /usr/bin/X11/X
xserver_arguments -nolisten tcp
# Commands for halt, login, etc.
halt_cmd /sbin/shutdown -h now
reboot_cmd /sbin/shutdown -r now
console_cmd /usr/bin/xterm -C -fg white -bg black +sb -T "Console login" -e /bin/sh -c "/bin/cat /etc/issue.net; exec /bin/login"
#suspend_cmd /usr/sbin/suspend
# Full path to the xauth binary
xauth_path /usr/bin/X11/xauth
# Xauth file for server
authfile /var/run/slim.auth
# Activate numlock when slim starts. Valid values: on|off
# numlock on
# Hide the mouse cursor (note: does not work with some WMs).
# Valid values: true|false
# hidecursor false
# This command is executed after a succesful login.
# you can place the %session and %theme variables
# to handle launching of specific commands in .xinitrc
# depending of chosen session and slim theme
# NOTE: if your system does not have bash you need
# to adjust the command according to your preferred shell,
# i.e. for freebsd use:
# login_cmd exec /bin/sh - ~/.xinitrc %session
login_cmd exec /bin/bash -login /etc/X11/Xsession %session
# Commands executed when starting and exiting a session.
# They can be used for registering a X11 session with
# sessreg. You can use the %user variable
# sessionstart_cmd some command
# sessionstop_cmd some command
# Start in daemon mode. Valid values: yes | no
# Note that this can be overriden by the command line
# options "-d" and "-nodaemon"
# daemon yes
# Available sessions (first one is the default).
# The current chosen session name is replaced in the login_cmd
# above, so your login command can handle different sessions.
# see the xinitrc.sample file shipped with slim sources
sessions awesome
# Executed when pressing F11 (requires imagemagick)
screenshot_cmd scrot /root/slim.png
# welcome message. Available variables: %host, %domain
welcome_msg Welcome to %host
# Session message. Prepended to the session name when pressing F1
# session_msg Session:
# shutdown / reboot messages
shutdown_msg The system is halting...
reboot_msg The system is rebooting...
# default user, leave blank or remove this line
# for avoid pre-loading the username.
default_user *********
# Focus the password field on start when default_user is set
# Set to "yes" to enable this feature
focus_password yes
# Automatically login the default user (without entering
# the password. Set to "yes" to enable this feature
#auto_login no
# current theme, use comma separated list to specify a set to
# randomly choose from
current_theme debian-moreblue-orbit
# Lock file
lockfile /var/run/slim.lock
# Log file
logfile /var/log/slim.log
Le but étant que Awesome soit le WM présélectionné. Or, malgré ce fichier, c’est KDE qui est choisi par défaut.
Si vous avez une suggestion…
