bonjour,
Je voudrais mettre eb place un serveur de partage local avec Samba, malheureusement je n’arrive pas à le configurer malgré les tutos suivis …
de plus, j’avais sauvé mon fichier smb.conf qui fonctionnait sous Squeeze, mais il ne fonctionne pas sous Wheezy…
autre chose, j’ai trouvé que le fichier a changé, à moins que je ne me trompe…
bref, je viens pour vous demander un peu d’aide svp…
voici mon fichier via tesparm :
[code]Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
Processing section "[allusers]"
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
[global]
server string = %h server
interfaces = 127.0.0.0/8, eth0
bind interfaces only = Yes
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = Enter\snew\s\spassword:* %n\n Retype\snew\s\spassword:
- %n\n password\supdated\ssuccessfully .
unix password sync = Yes
syslog = 0
log file = /var/log/samba/log.%m
max log size = 1000
domain master = Yes
dns proxy = No
wins support = Yes
usershare allow guests = Yes
panic action = /usr/share/samba/panic-action %d
idmap config * : backend = tdb
[allusers]
comment = All Users
path = /home/shares/allusers
valid users = @users
force group = users
read only = No
create mask = 0660
directory mask = 0771
[homes]
comment = Home Directories
valid users = %S
create mask = 0700
directory mask = 0700
browseable = No
[printers]
comment = All Printers
path = /var/spool/samba
create mask = 0700
printable = Yes
print ok = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
merci par avance pour votre aide
