Je ne parviens pas à partager mon hdd externe sur le reseau.
Reseau : pc équipé de debian + 1 xbox avec xbmc dans le salon.
Je ping la xbox sans problème mais le partage samba ne fonctionne pas.
ci-joint la config de samba :
netbios name = Samba24
server string = Samba file and print server
workgroup = WORKGROUP
security = user
hosts allow = 127. 192.168.0.
interfaces = 127.0.0.1/8 192.168.0.0/24
bind interfaces only = yes
remote announce = 192.168.0.255
remote browse sync = 192.168.0.255
printcap name = cups
load printers = yes
cups options = raw
printing = cups
guest account = smbguest
log file = /var/log/samba/samba.log
max log size = 1000
null passwords = no
username level = 6
password level = 6
encrypt passwords = yes
unix password sync = yes
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
local master = no
domain master = no
preferred master = no
domain logons = no
os level = 33
logon drive = m:
logon home = \%L\homes%u
logon path = \%L\profiles%u
logon script = %G.bat
time server = no
name resolve order = wins lmhosts bcast
wins support = no
wins proxy = no
dns proxy = no
preserve case = yes
short preserve case = yes
client use spnego = no
client signing = no
client schannel = no
server signing = no
server schannel = no
nt pipe support = yes
nt status support = yes
allow trusted domains = no
obey pam restrictions = yes
enable spoolss = yes
client plaintext auth = no
disable netbios = no
follow symlinks = no
update encrypted = yes
pam password change = no
passwd chat timeout = 120
hostname lookups = no
username map = /etc/samba/smbusers
passdb backend = tdbsam
passwd program = /usr/bin/passwd '%u’
passwd chat = Newpassword* %n\n ReTypenewpassword %n\n passwdchanged*\n
add user script = /usr/sbin/useradd -d /dev/null -c ‘Samba User Account’ -s /dev/null '%u’
add user to group script=/usr/sbin/useradd -d /dev/null -c ‘Samba User Account’ -s /dev/null -g ‘%g’ '%u’
add group script = /usr/sbin/groupadd '%g’
delete user script = /usr/sbin/userdel '%u’
delete user from group script = /usr/sbin/userdel ‘%u’ '%g’
delete group script = /usr/sbin/groupdel '%g’
add machine script = /usr/sbin/useradd -d /dev/null -g sambamachines -c ‘Samba Machine Account’ -s /dev/null -M '%u’
machine password timeout = 120
idmap uid = 16777216-33554431
idmap gid = 16777216-33554431
template shell = /dev/null
winbind use default domain = yes
winbind separator = @
winbind cache time = 360
winbind trusted domains only = yes
winbind nested groups = no
winbind nss info = no
winbind refresh tickets = no
winbind offline logon = no
[homes]
comment = Home Directories
path = /home
read only = no
available = yes
browseable = yes
writable = yes
guest ok = no
public = no
printable = no
locking = no
strict locking = no
[netlogon]
comment = Network Logon Service
path = /home/netlogon
read only = no
available = yes
browseable = yes
writable = no
guest ok = no
public = no
printable = no
locking = no
strict locking = no
[profiles]
comment = User Profiles
path = /var/samba/profiles
read only = no
available = yes
browseable = no
writable = yes
guest ok = no
public = no
printable = no
create mode = 0600
directory mask = 0700
locking = no
strict locking = no
[printers]
comment = All Printers
path = /var/spool/samba
browseable = yes
writable = no
guest ok = no
public = no
printable = yes
locking = no
strict locking = no
[pdf-documents]
path = /home/pdf-documents
comment = Converted PDF Documents
available = yes
browseable = yes
writeable = yes
guest ok = yes
locking = no
strict locking = no
[pdf-printer]
path = /tmp
comment = PDF Printer Service
printable = yes
guest ok = yes
use client driver = yes
printing = bsd
print command = /usr/bin/gadmin-samba-pdf %s %u
lpq command =
lprm command =
[pbell]
path = /media/Hd
comment = No comment
read only = no
available = yes
browseable = yes
writable = no
guest ok = no
public = no
printable = no
locking = no
strict locking = no
[hdd1to]
path = /media/HDD_EXTERNE
read only = no
available = yes
browseable = yes
writable = no
guest ok = no
public = no
printable = no
locking = no
strict locking = no
