Partitionner un raid1
Je viens de me prendre une formule hybrid flambante neuve sur laquelle j’ai installé proxmox.
Je me retrouve avec la conf suivante (par défaut lors de l’install):
Raid1 de SSD sur lequel se trouvent les partitions
/var/lib/vz
swap
Raid1 de Sata sur lequel se trouve la partition
/data
voici la conf d’origine en faisant un fdisk -l:
[code]Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders
Disk identifier: 0x0009e5df
/dev/sda1 * 1 1306 10485760+ fd Linux raid autodetect
/dev/sda2 1306 14528 106204160 fd Linux raid autodetect
/dev/sda3 14528 14593 526304 82 Linux swap / Solaris
Disk /dev/sdb: 120.0 GB, 120034123776 bytes
Disk identifier: 0x0000d51d
/dev/sdb1 * 1 1306 10485760+ fd Linux raid autodetect
/dev/sdb2 1306 14528 106204160 fd Linux raid autodetect
/dev/sdb3 14528 14593 526304 82 Linux swap / Solaris
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sdc’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
/dev/sdc1 1 243201 1953512001 83 Linux
Partition 1 does not start on physical sector boundary.
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sdd’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes
/dev/sdd1 1 243202 1953514583+ ee GPT
Disk /dev/md1: 10.7 GB, 10737352704 bytes
2 heads, 4 sectors/track, 2621424 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk /dev/md1 doesn’t contain a valid partition table
Disk /dev/md2: 108.8 GB, 108752994304 bytes
2 heads, 4 sectors/track, 26551024 cylinders
Disk /dev/md2 doesn’t contain a valid partition table
Disk /dev/md0: 1907.7 GB, 1907725893632 bytes
2 heads, 4 sectors/track, 465753392 cylinders
Alignment offset: 3072 bytes
Disk identifier: 0xca1dad4d
Disk /dev/dm-0: 107.7 GB, 107671977984 bytes
255 heads, 63 sectors/track, 13090 cylinders
Disk /dev/dm-0 doesn’t contain a valid partition table[/code]
Le fstab :
1 /dev/md1 / ext3 errors=remount-ro 0 1 2 /dev/pve/data /var/lib/vz ext3 defaults 0 2 3 /dev/sda3 none swap defaults 0 0 4 /dev/sdb3 none swap defaults 0 0 5 /dev/md0 /data ext3 defaults 0 2 6 proc /proc proc defaults 0 0 7 sysfs /sys sysfs defaults 0 0
Ce que je voudrais, c’est créer une partition de 100GB pour le snapshot.
En gros, je voudrais que mon Raid1 Sata ait les partitions suivante :
/stock
/var/lib/vz/dump
J’ai vu pas mal de tutos à ce sujet, mais soit je trouve pour un disque non raid, ou je trouve la construction d’un raid…
Pouvez vous m’aider pour cette manip svp ?
Merci.
Le plus simple à mon sens dans ton cas et de traiter le périphérique /dev/md0 monter sur /data :
  • démonter /data (cf umount)
  • créer une couche lvm sur /dev/md0 (cf pvcreate et vgcreate)
  • créer trois volumes logiques sur ce lvm nommés data, stock et dump (cf lvcreate)
  • modifier le fichier /etc/fstab
Tu peux le faire sans LVM si tu préfères, dans ce cas il faudra jouer avec cfdisk sur /dev/md0.
L’avantage d’utiliser LVM est que tu pourras facilement adapter la taille de tes partitions dans le futur si le besoin se montre.
Houlaaa. je ne suis pas expert…
Oui effectivement, en lvm, ça serait intéressant, mais je ne sais pas comment marchent les commandes puis que je ne l’ai jamais fait sur un raid…
Donc si tu pouvais me taper les commandes, ce serait très généreux de ta part.
Merci beaucoup !
Pour comprendre comment manipuler LVM je t’invite à lire cette documentation :
doc.ubuntu-fr.org/lvm
C’est pour ubuntu mais comme ubuntu est basé sur debian, les commandes sont les mêmes dans la plupart des cas.
Si un point est trop flou, n’hésite pas à nous dire lequel.
ok j’y suis arrive, merci pour ton aide précieuse !
