lorsque je tape 127.0.0.0 j’ai 127.0.0.0/ sur la barre et 'unable to connect’
127.0.0.1 j’ai 127.0.0.1/apache2-default/ et … it works (sur fond blanc)
127.0.0.2 j’ai 127.0.0.2/apache2-default/ et …mon site
phiphi j’ai phiphi/apache2-default/ et … it works (sur fond blanc)
ca c’est pour les infos. par contre phiphi:~# file /etc/apache2/httpd.conf
/etc/apache2/httpd.conf: empty !!
mais j’ai un httpd.conf dans /etc/apache/apache-ssl que voila
si quelqu’un pouvait y jeter un coup d’oeil pour verifier si rien ne cloche de ce côté-là
httpd.conf – Apache HTTP server configuration file
Debian maintainers note:
all the SSL configuration directives are located at the end of this file.
Based upon the NCSA server configuration files originally by Rob McCool.
This is the main Apache server configuration file. It contains the
configuration directives that give the server its instructions.
the directives.
Do NOT simply read the instructions in here without understanding
what they do. They’re here only as hints or reminders. If you are unsure
consult the online docs. You have been warned.
After this file is processed, the server will look for and process
/etc/apache-ssl/srm.conf and then /etc/apache-ssl/access.conf
unless you have overridden these with ResourceConfig and/or
AccessConfig directives here.
The configuration directives are grouped into three basic sections:
1. Directives that control the operation of the Apache server process as a
whole (the ‘global environment’).
2. Directives that define the parameters of the ‘main’ or ‘default’ server,
which responds to requests that aren’t handled by a virtual host.
These directives also provide default values for the settings
of all virtual hosts.
3. Settings for virtual hosts, which allow Web requests to be sent to
different IP addresses or hostnames and have them handled by the
same Apache server process.
Configuration and logfile names: If the filenames you specify for many
of the server’s control files begin with “/” (or “drive:/” for Win32), the
server will use that explicit path. If the filenames do not begin
with “/”, the value of ServerRoot is prepended – so “logs/foo.log”
with ServerRoot set to “/usr/local/apache” will be interpreted by the
server as “/usr/local/apache/logs/foo.log”.
Section 1: Global Environment
The directives in this section affect the overall operation of Apache,
such as the number of concurrent requests it can handle or where it
can find its configuration files.
ServerType is either inetd, or standalone. Inetd mode is only supported on
Unix platforms.
SSL Servers MUST be standalone, currently.
ServerType standalone
ServerRoot: The top of the directory tree under which the server’s
configuration, error, and log files are kept, unless they are specified
with an absolute path.
NOTE! If you intend to place this on an NFS (or otherwise network)
mounted filesystem then please read the LockFile documentation
you will save yourself a lot of trouble.
Do NOT add a slash at the end of the directory path.
ServerRoot /etc/apache-ssl
The LockFile directive sets the path to the lockfile used when Apache
is compiled with either USE_FCNTL_SERIALIZED_ACCEPT or
USE_FLOCK_SERIALIZED_ACCEPT. This directive should normally be left at
its default value. The main reason for changing it is if the logs
directory is NFS mounted, since the lockfile MUST BE STORED ON A LOCAL
DISK. The PID of the main server process is automatically appended to
the filename.
LockFile /var/lock/apache-ssl.lock
PidFile: The file in which the server should record its process
identification number when it starts.
PidFile /var/run/apache-ssl.pid
ScoreBoardFile: File used to store internal server process information.
Not all architectures require this. But if yours does (you’ll know because
this file will be created when you run Apache) then you must ensure that
no two invocations of Apache share the same scoreboard file.
ScoreBoardFile /var/run/apache-ssl.scoreboard
In the standard configuration, the server will process this file,
srm.conf, and access.conf in that order. The latter two files are
now distributed empty, as it is recommended that all directives
be kept in a single file for simplicity. The commented-out values
below are the built-in defaults. You can have the server ignore
these files altogether by using “/dev/null” (for Unix) or
“nul” (for Win32) for the arguments to the directives.
#ResourceConfig /etc/apache-ssl/srm.conf
#AccessConfig /etc/apache-ssl/access.conf
Timeout: The number of seconds before receives and sends time out.
Timeout 300
KeepAlive: Whether or not to allow persistent connections (more than
one request per connection). Set to “Off” to deactivate.
KeepAlive On
MaxKeepAliveRequests: The maximum number of requests to allow
during a persistent connection. Set to 0 to allow an unlimited amount.
We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
KeepAliveTimeout: Number of seconds to wait for the next request from the
same client on the same connection.
KeepAliveTimeout 15
Server-pool size regulation. Rather than making you guess how many
server processes you need, Apache dynamically adapts to the load it
sees — that is, it tries to maintain enough server processes to
handle the current load, plus a few spare servers to handle transient
load spikes (e.g., multiple simultaneous requests from a single
Netscape browser).
It does this by periodically checking how many servers are waiting
for a request. If there are fewer than MinSpareServers, it creates
a new spare. If there are more than MaxSpareServers, some of the
spares die off. The default values are probably OK for most sites.
MinSpareServers 5
MaxSpareServers 10
Number of servers to start initially — should be a reasonable ballpark
figure.
StartServers 5
Limit on total number of servers running, i.e., limit on the number
of clients who can simultaneously connect — if this limit is ever
reached, clients will be LOCKED OUT, so it should NOT BE SET TOO LOW.
It is intended mainly as a brake to keep a runaway server from taking
the system with it as it spirals down…
MaxClients 150
MaxRequestsPerChild: the number of requests each child process is
allowed to process before the child dies. The child will exit so
as to avoid problems after prolonged use when Apache (and maybe the
libraries it uses) leak memory or other resources. On most systems, this
isn’t really needed, but a few (such as Solaris) do have notable leaks
in the libraries. For these platforms, set to something like 10000
or so; a setting of 0 means unlimited.
NOTE: This value does not include keepalive requests after the initial
request per connection. For example, if a child process handles
an initial request and 10 subsequent “keptalive” requests, it
would only count as 1 request towards this limit.
MaxRequestsPerChild 100
Listen: Allows you to bind Apache to specific IP addresses and/or
ports, in addition to the default. See also the
directive.
#Listen 3000
#Listen 12.34.56.78:80
The default port for SSL is 443…
Listen 443
BindAddress: You can support virtual hosts with this option. This directive
is used to tell the server which IP address to listen to. It can either
contain “*”, an IP address, or a fully qualified Internet domain name.
See also the and Listen directives.
#BindAddress *
Dynamic Shared Object (DSO) Support
To be able to use the functionality of a module which was built as a DSO you
have to place corresponding `LoadModule’ lines at this location so the
directives contained in it are actually available before they are used.
Please read the file README.DSO in the Apache 1.3 distribution for more
details about the DSO mechanism and run `apache -l’ for the list of already
built-in (statically linked and thus always available) modules in your apache
binary.
Please keep this LoadModule: line here, it is needed for installation.
Include /etc/apache-ssl/modules.conf
ExtendedStatus: controls whether Apache will generate “full” status
information (ExtendedStatus On) or just basic information (ExtendedStatus
Off) when the “server-status” handler is called. The default is Off.
ExtendedStatus On
Section 2: ‘Main’ server configuration
The directives in this section set up the values used by the ‘main’
server, which responds to any requests that aren’t handled by a
definition. These values also provide defaults for
any containers you may define later in the file.
All of these directives may appear inside containers,
in which case these default settings will be overridden for the
virtual host being defined.
If your ServerType directive (set earlier in the ‘Global Environment’
section) is set to “inetd”, the next few directives don’t have any
effect since their settings are defined by the inetd configuration.
Skip ahead to the ServerAdmin directive.
Port: The port to which the standalone server listens. For
ports < 1023, you will need apache to be run as root initially.
Port 443
If you wish apache to run as a different user or group, you must run
apacheas root initially and it will switch.
User/Group: The name (or #number) of the user/group to run apache as.
. On SCO (ODT 3) use “User nouser” and “Group nogroup”.
. On HPUX you may not be able to use shared memory as nobody, and the
suggested workaround is to create a user www and use that user.
NOTE that some kernels refuse to setgid(Group) or semctl(IPC_SET)
when the value of (unsigned)Group is above 60000;
don’t use Group nobody on these systems!
User www-data
Group www-data
ServerAdmin: Your address, where problems with the server should be
e-mailed. This address appears on some server-generated pages, such
as error documents.
ServerAdmin webmaster@phiphi
ServerName: allows you to set a host name which is sent back to clients for
your server if it’s different than the one the program would get (i.e., use
“www” instead of the host’s real name).
Note: You cannot just invent host names and hope they work. The name you
define here must be a valid DNS name for your host. If you don’t understand
this, ask your network administrator.
If your host doesn’t have a registered DNS name, enter its IP address here.
You will have to access it by its address (e.g., 123.45.67.89/)
anyway, and this will make redirections work in a sensible way.
ServerName phiphi-conques.org
#ServerName new.host.name
DocumentRoot: The directory out of which you will serve your
documents. By default, all requests are taken from this directory, but
symbolic links and aliases may be used to point to other locations.
DocumentRoot /var/www
Each directory to which Apache has access, can be configured with respect
to which services and features are allowed and/or disabled in that
directory (and its subdirectories).
First, we configure the “default” to be a very restrictive set of
permissions.
Options SymLinksIfOwnerMatch
AllowOverride None
Note that from this point forward you must specifically allow
particular features to be enabled - so if something’s not working as
you might expect, make sure that you have specifically enabled it
below.
This should be changed to whatever you set DocumentRoot to.
<Directory /var/www/>
This may also be “None”, “All”, or any combination of “Indexes”,
“Includes”, “FollowSymLinks”, “ExecCGI”, or “MultiViews”.
Note that “MultiViews” must be named explicitly — “Options All”
doesn’t give it to you.
Options Indexes Includes FollowSymLinks MultiViews
This controls which options the .htaccess files in directories can
override. Can also be “All”, or any combination of “Options”, “FileInfo”,
“AuthConfig”, and “Limit”
AllowOverride None
Controls who can get stuff from this server.
Order allow,deny
Allow from all
UserDir: The name of the directory which is appended onto a user’s home
directory if a ~user request is received.
UserDir public_html
# Control access to UserDir directories. The following is an example
# for a site where these directories are restricted to read-only.
AllowOverride FileInfo AuthConfig Limit
Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
Order allow,deny
Allow from all
Order deny,allow
Deny from all
DirectoryIndex: Name of the file or files to use as a pre-written HTML
directory index. Separate multiple entries with spaces.
DirectoryIndex index.html index.htm index.shtml index.cgi index.php
AccessFileName: The name of the file to look for in each directory
for access control information.
AccessFileName .htaccess
The following lines prevent .htaccess files from being viewed by
Web clients. Since .htaccess files often contain authorization
information, access is disallowed for security reasons. Comment
these lines out if you want Web visitors to see the contents of
.htaccess files. If you change the AccessFileName directive above,
be sure to make the corresponding changes here.
Also, folks tend to use names such as .htpasswd for password
files, so this will protect those as well.
<Files ~ “^.ht”>
Order allow,deny
Deny from all
CacheNegotiatedDocs: By default, Apache sends “Pragma: no-cache” with each
document that was negotiated on the basis of content. This asks proxy
servers not to cache the document. Uncommenting the following line disables
this behavior, and proxies will be allowed to cache the documents.
#CacheNegotiatedDocs
UseCanonicalName: (new for 1.3) With this setting turned on, whenever
Apache needs to construct a self-referencing URL (a URL that refers back
to the server the response is coming from) it will use ServerName and
Port to form a “canonical” name. With this setting off, Apache will
use the hostname:port that the client supplied, when possible. This
also affects SERVER_NAME and SERVER_PORT in CGI scripts.
UseCanonicalName Off
TypesConfig describes where the mime.types file (or equivalent) is
to be found.
TypesConfig /etc/mime.types
DefaultType is the default MIME type the server will use for a document
if it cannot otherwise determine one, such as from filename extensions.
If your server contains mostly text or HTML documents, “text/plain” is
a good value. If most of your content is binary, such as applications
or images, you may want to use “application/octet-stream” instead to
keep browsers from trying to display binary files as though they are
text.
DefaultType text/plain
The mod_mime_magic module allows the server to use various hints from the
contents of the file itself to determine its type. The MIMEMagicFile
directive tells the module where the hint definitions are located.
mod_mime_magic is not part of the default server (you have to add
it yourself with a LoadModule [see the DSO paragraph in the 'Global
Environment’ section], or recompile the server and include mod_mime_magic
as part of the configuration), so it’s enclosed in an container.
This means that the MIMEMagicFile directive will only be processed if the
module is part of the server.
MIMEMagicFile /usr/share/file/magic.mime
HostnameLookups: Log the names of clients or just their IP addresses
e.g., www.apache.org (on) or 204.62.129.132 (off).
The default is off because it’d be overall better for the net if people
had to knowingly turn this feature on, since enabling it means that
each client request will result in AT LEAST one lookup request to the
nameserver.
HostnameLookups Off
Note that Log files are now rotated by logrotate, not by apache itself.
This means that apache no longer attempts to magically determine
where your log files are kept; you have to fill out stanzas in
/etc/logrotate.d/apache-ssl yourself.
ErrorLog: The location of the error log file.
If you do not specify an ErrorLog directive within a
container, error messages relating to that virtual host will be
logged here. If you do define an error logfile for a
container, that host’s errors will be logged there and not here.
ErrorLog /var/log/apache-ssl/error.log
LogLevel: Control the number of messages logged to the error_log.
Possible values include: debug, info, notice, warn, error, crit,
alert, emerg.
LogLevel warn
The following directives define some format nicknames for use with
a CustomLog directive (see below).
LogFormat “%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i” “%{forensic-id}n” %T %v” full
LogFormat “%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i” “%{forensic-id}n” %P %T” debug
LogFormat “%h %l %u %t “%r” %>s %b “%{Referer}i” “%{User-Agent}i” “%{forensic-id}n”” combined
LogFormat “%h %l %u %t “%r” %>s %b “%{forensic-id}n”” forensic
LogFormat “%h %l %u %t “%r” %>s %b” common
LogFormat “%{Referer}i -> %U” referer
LogFormat “%{User-agent}i” agent
The location and format of the access logfile (Common Logfile Format).
If you do not define any access logfiles within a
container, they will be logged here. Contrariwise, if you do
define per- access logfiles, transactions will be
logged therein and not in this file.
#CustomLog /var/log/apache-ssl/access.log common
If you would like to have agent and referer logfiles, uncomment the
following directives.
#CustomLog /var/log/apache-ssl/referer.log referer
#CustomLog /var/log/apache-ssl/agent.log agent
If you prefer a single logfile with access, agent, referer and forensic
information (Combined Logfile Format) you can use the following directive.
CustomLog /var/log/apache-ssl/access.log combined
ForensicLog /var/log/apache-ssl/forensic.log
Debugging information. With apache 1.3.31 two new debugging modules have been
introduced to facilitate this task: mod_backtrace and mod_whatkilledus.
They must NOT be used in production environment if not for debugging!
You must know what you are doing before enabling the modules and
uncommenting the following lines.
EnableExceptionHook On
# Backtrace logs are written to error.log but optionally they can be
# redirected to a different file.
# BacktraceLog /var/log/apache-ssl/backtrace.log
# Whatkilledus logs are written to error.log but optionally they can be
# WhatKilledUsLog /var/log/apache-ssl/whatkilledus.log
Optionally add a line containing the server version and virtual host
name to server-generated pages (error documents, FTP directory listings,
mod_status and mod_info output etc., but not CGI generated documents).
Set to “EMail” to also include a mailto: link to the ServerAdmin.
Set to one of: On | Off | EMail
ServerSignature On
This directive controls whether Server response header field which is
sent back to clients includes a description of the generic OS-type of
the server as well as information about compiled-in modules.
Set to one of: Prod[uctOnly] | Min[imal] | OS | Full
If the directive is not specified the default is set to Full.
#ServerTokens Full
Aliases: Add here as many aliases as you need (with no limit). The format is
Alias fakename realname
Note that if you include a trailing / on fakename then the server will
require it to be present in the URL. So “/icons” isn’t aliased in this
example, only “/icons/”…
Alias /icons/ /usr/share/apache/icons/
<Directory /usr/share/apache/icons>
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /images/ /usr/share/images/
<Directory /usr/share/images>
Options MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
ScriptAlias: This controls which directories contain server scripts.
ScriptAliases are essentially the same as Aliases, except that
documents in the realname directory are treated as applications and
run by the server when requested rather than as documents sent to the client.
The same rules about trailing “/” apply to ScriptAlias directives as to
Alias.
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
“/usr/lib/cgi-bin” could be changed to whatever your ScriptAliased
CGI directory exists, if you have that configured.
<Directory /usr/lib/cgi-bin/>
AllowOverride None
Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
Redirect allows you to tell clients about documents which used to exist in
your server’s namespace, but do not anymore. This allows you to tell the
clients where to look for the relocated document.
Format: Redirect old-URI new-URL
Directives controlling the display of server-generated directory listings.
# FancyIndexing: whether you want fancy directory indexing or standard
IndexOptions FancyIndexing NameWidth=*
# AddIcon* directives tell the server which icon to show for different
# files or filename extensions. These are only displayed for
# FancyIndexed directories.
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/deb.gif .deb
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
# DefaultIcon: which icon to show for files which do not have an icon
# explicitly set.
DefaultIcon /icons/unknown.gif
# AddDescription: allows you to place a short description after a file in
# server-generated indexes. These are only displayed for FancyIndexed
# directories.
# Format: AddDescription "description" filename
#AddDescription "GZIP compressed document" .gz
#AddDescription "tar archive" .tar
#AddDescription "GZIP compressed tar archive" .tgz
# ReadmeName: the name of the README file the server will look for by
# default, and append to directory listings.
# HeaderName: the name of a file which should be prepended to
# directory indexes.
# The module recognize only 2 kind of mime-types, text/html and
# text/*, but the only method it has to identify them is via
# the filename extension. The default is to include and display
# html files.
ReadmeName README.html
HeaderName HEADER.html
# Otherwise you can comment the 2 lines above and uncomment
# the 2 below in order to display plain text files.
# ReadmeName README.txt
# HeaderName HEADER.txt
# IndexIgnore: a set of filenames which directory indexing should ignore
# and not include in the listing. Shell-style wildcarding is permitted.
IndexIgnore .??* *~ *# HEADER.html HEADER.txt RCS CVS *,v *,t
# Uncomment the following IndexIgnore line to add README.* to the file
# list that will not be displayed by mod_autoindex.
# It is not enabled by default on Debian system to permit users to properly
# browse Debian documentation (/doc/)
#IndexIgnore README.*
Document types.
# AddEncoding allows you to have certain browsers (Mosaic/X 2.1+)
# uncompress information on the fly. Note: Not all browsers support
# this. Despite the name similarity, the following Add* directives
# have nothing to do with the FancyIndexing customization
# directives above.
AddEncoding x-compress Z
AddEncoding x-gzip gz tgz
# AddLanguage: allows you to specify the language of a document. You can
# then use content negotiation to give a browser a file in a language
# it can understand.
# Note 1: The suffix does not have to be the same as the language
# keyword --- those with documents in Polish (whose net-standard
# language code is pl) may wish to use "AddLanguage pl .po" to
# avoid the ambiguity with the common suffix for perl scripts.
# Note 2: The example entries below illustrate that in quite
# some cases the two character 'Language' abbriviation is not
# identical to the two character 'Country' code for its country,
# E.g. 'Danmark/dk' versus 'Danish/da'.
# Note 3: There is 'work in progress' to fix this and get
# the reference data for rfc3066 cleaned up.
# Danish (da) - Dutch (nl) - English (en) - Estonian (ee)
# French (fr) - German (de) - Greek-Modern (el)
# Italian (it) - Portugese (pt) - Luxembourgeois (lb)
# Spanish (es) - Swedish (sv) - Catalan (ca) - Czech(cs)
# Polish (pl) - Brazilian Portuguese (pt-br) - Japanese (ja)
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .ee
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage it .it
AddLanguage ja .ja
AddCharset ISO-2022-JP .jis
AddLanguage pl .po
AddCharset ISO-8859-2 .iso-pl
AddLanguage pt .pt
AddLanguage pt-br .pt-br
AddLanguage lb .lu
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .se
AddLanguage cs .cz
# LanguagePriority: allows you to give precedence to some languages
# in case of a tie during content negotiation.
# Just list the languages in decreasing order of preference. We have
# more or less alphabetized them here. You probably want to change
# this.
<IfModule mod_negotiation.c>
LanguagePriority en da nl et fr de el it ja pl pt pt-br lb ca es sv
</IfModule>
# AddType allows you to tweak mime.types without actually editing
# it, or to make certain files to be certain types.
# For example, the PHP 3.x module (not part of the Apache
# distribution - see [php.net](http://www.php.net)) will typically use:
#AddType application/x-httpd-php3 .php3
#AddType application/x-httpd-php3-source .phps
# And for PHP 4.x, use:
#AddType application/x-httpd-php .php
#AddType application/x-httpd-php-source .phps
AddType application/x-tar .tgz
AddType image/bmp .bmp
# hdml
AddType text/x-hdml .hdml
# AddHandler allows you to map certain file extensions to "handlers",
# actions unrelated to filetype. These can be either built into
# the server or added with the Action command (see below).
# If you want to use server side includes, or CGI outside
# ScriptAliased directories, uncomment the following lines.
# To use CGI scripts:
#AddHandler cgi-script .cgi .sh .pl
# To use server-parsed HTML files mod_include has to be enabled.
<IfModule mod_include.c>
AddType text/html .shtml
AddHandler server-parsed .shtml
</IfModule>
# Uncomment the following line to enable Apache's send-asis HTTP
# file feature.
#AddHandler send-as-is asis
# If you wish to use server-parsed imagemap files, use
#AddHandler imap-file map
# To enable type maps, you might want to use
#AddHandler type-map var
# End of document types.
AddDefaultCharset on
Action: lets you define media types that will execute a script whenever
a matching file is called. This eliminates the need for repeated URL
pathnames for oft-used CGI file processors.
Format: Action media/type /cgi-script/location
Format: Action handler-name /cgi-script/location
MetaDir: specifies the name of the directory in which Apache can find
meta information files. These files contain additional HTTP headers
to include when sending the document
#MetaDir .web
MetaSuffix: specifies the file name suffix for the file containing the
meta information.
#MetaSuffix .meta
Customizable error response (Apache style)
these come in three flavors
1) plain text
#ErrorDocument 500 "The server made a boo boo.
n.b. the (") marks it as text, it does not get output
2) local redirects
#ErrorDocument 404 /missing.html
to redirect to local URL /missing.html
#ErrorDocument 404 /cgi-bin/missing_handler.pl
N.B.: You can redirect to a script or a document using server-side-includes.
3) external redirects
#ErrorDocument 402 some.other_server.com/subscription_info.html
N.B.: Many of the environment variables associated with the original
request will not be available to such a script.
# The following directives modify normal HTTP response behavior.
# The first directive disables keepalive for Netscape 2.x and browsers that
# spoof it. There are known problems with these browser implementations.
# The second directive is for Microsoft Internet Explorer 4.0b2
# which has a broken HTTP/1.1 implementation and does not properly
# support keepalive when it is used on 301 or 302 (redirect) responses.
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
# The following directive disables HTTP/1.1 responses to browsers which
# are in violation of the HTTP/1.0 spec by not being able to grok a
# basic 1.1 response.
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
If the perl module is installed, this will be enabled.
Alias /perl/ /var/www/perl/
SetHandler perl-script
PerlHandler Apache::Registry
Options +ExecCGI
Allow http put (such as Netscape Gold’s publish feature)
Use htpasswd to generate /etc/apache-ssl/passwd.
You must unremark these two lines at the top of this file as well:
#LoadModule put_module modules/mod_put.so
#AddModule mod_put.c
Alias /upload /tmp
#<Location /upload>
EnablePut On
AuthType Basic
AuthName Temporary
AuthUserFile /etc/apache-ssl/passwd
EnableDelete Off
umask 007
require valid-user
Change the “.your_domain.com” to match your domain to enable.
#<Location /server-status>
SetHandler server-status
Order deny,allow
Deny from all
Allow from .your_domain.com
Allow remote server configuration reports, with the URL of
#<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
Allow access to local system documentation from localhost.
(Debian Policy assumes /usr/share/doc is “/doc/”, at least from the localhost.)
Alias /doc/ /usr/share/doc/
<Location /doc>
order deny,allow
deny from all
allow from 127.0.0.0/255.0.0.0
Options Indexes FollowSymLinks MultiViews
There have been reports of people trying to abuse an old bug from pre-1.1
days. This bug involved a CGI script distributed as a part of Apache.
By uncommenting these lines you can redirect these attacks to a logging
script on phf.apache.org. Or, you can record them yourself, using the script
support/phf_abuse_log.cgi.
#<Location /cgi-bin/phf*>
Deny from all
# Proxy Server directives. Uncomment the following lines to
# enable the proxy server:
#ProxyRequests On
#<Directory proxy:*>
# Order deny,allow
# Deny from all
# Allow from .your_domain.com
#</Directory>
# Enable/disable the handling of HTTP/1.1 "Via:" headers.
# ("Full" adds the server version; "Block" removes all outgoing Via: headers)
# Set to one of: Off | On | Full | Block
#ProxyVia On
# To enable the cache as well, edit and uncomment the following lines:
# (no cacheing without CacheRoot)
#CacheRoot "/var/cache/apache-ssl"
#CacheSize 5
#CacheGcInterval 4
#CacheMaxExpire 24
#CacheLastModifiedFactor 0.1
#CacheDefaultExpire 1
#NoCache a_domain.com another_domain.edu joes.garage_sale.com
# End of proxy directives.
Section 3: Virtual Hosts
VirtualHost: If you want to maintain multiple domains/hostnames on your
machine you can setup VirtualHost containers for them.
for further details before you try to setup virtual hosts.
You may use the command line option ‘-S’ to verify your virtual host
configuration.
If you want to use name-based virtual hosts you need to define at
least one IP address (and port number) for them.
#NameVirtualHost 12.34.56.78:80
VirtualHost example:
Almost any Apache directive may go into a VirtualHost container.
DocumentRoot /www/docs/host.some_domain.com
ServerName host.some_domain.com
ErrorLog logs/host.some_domain.com-error.log
CustomLog logs/host.some_domain.com-access.log common
#<VirtualHost default:*>
----------------------------SSL----------------------------------
This is an example configuration file for Apache-SSL.
Copyright © 1995,6,7,8,9,2000,2001 Ben Laurie
Adapted to the Debian configuration by the Debian Apache Maintainers Team.
Note that all SSL options can apply to virtual hosts.
Disable SSL version 2 (you should always do this)
Debian maintainers note: this options has been disabled since it seems
to give some problems in certain setups but
should be used whenever possible.
#SSLNoV2
Disable CA list sending for testing…
#SSLNoCAList
Load some randomness.
This is loaded at startup, reading at most 1024 bytes from /dev/urandom.
You may prefer to use /dev/random, but be aware that some OSes (e.g. Linux)
insist on returning all 1024 bytes, thus blocking the server until the
randomness is available.
The randomness will be shared between all server instances. You can have
as many of these as you want.
SSLRandomFile file /dev/urandom 1024
And this one will be loaded before SSL is negotiated for each connection.
Again, you can have as many of these as you want, and they will all be used
at each connection.
#SSLRandomFilePerConnection egd /path/to/egd/socket 1024
SSLRandomFilePerConnection file /dev/urandom 1024
Disable SSL. Useful in combination with virtual hosts. Note that SSLEnable is
now also supported.
#SSLDisable
SSLEnable
Set the path for the global cache server executable.
If this facility gives you trouble, you can disable it by setting
CACHE_SESSIONS to FALSE in apache_ssl.c
#SSLCacheServerPath …/src/modules/ssl/splashcache 3333@scuzzy ssl
SSLCacheServerPath /usr/lib/apache-ssl/gcache
Set the global cache server port number, or path. If it is a path, a Unix
domain socket is used. If a number, a TCP socket.
#SSLCacheServerPort 1234
SSLCacheServerPort /var/run/gcache_port
Directory for the cache server to run in (in case of crashes). Optional.
#SSLCacheServerRunDir /tmp
Set the session cache timeout, in seconds (set to 15 for testing, use a
higher value in real life)
SSLSessionCacheTimeout 15
Set the CA certificate verification path (must be PEM encoded).
(in addition to getenv(“SSL_CERT_DIR”), I think).
#SSLCACertificatePath /home/ben/work/apache-ssl/apache_1.3.4-ssl/SSLconf/conf
#SSLCACertificatePath /etc/apache-ssl
Set the CA certificate verification file (must be PEM encoded).
(in addition to getenv(“SSL_CERT_FILE”), I think).
#SSLCACertificateFile /some/where/somefile
#SSLCACertificateFile /home/ben/work/apache-ssl/apache_1.3.4-ssl/SSLconf/conf/httpsd.pem
Point SSLCertificateFile at a PEM encoded certificate.
If the certificate is encrypted, then you will be prompted for a pass phrase.
A test certificate can be generated with “make certificate”.
#SSLCertificateFile /home/ben/work/apache-ssl/apache_1.3.4-ssl/SSLconf/conf/httpsd.pem
SSLCertificateFile /etc/apache-ssl/apache.pem
If the key is not combined with the certificate, use this directive to
point at the key file. If this starts with a ‘/’ it specifies an absolute
path, otherwise it is relative to the default certificate area. That is, it
means “/private/”.
#SSLCertificateKeyFile /some/place/with/your.key
Set SSLVerifyClient to:
0 if no certicate is required
1 if the client may present a valid certificate
2 if the client must present a valid certificate
3 if the client may present a valid certificate but it is not required to
have a valid CA
SSLVerifyClient 0
How deeply to verify before deciding they don’t have a valid certificate
SSLVerifyDepth 10
CRL Handling
N.B. Cached sessions are not rechecked against the CRL, so make sure
SSLSessionCacheTimeout is set low enough.
Add this directive to check the client cert against its CRL
OpenSSL will look for the CRL in the CA path (i.e. the path set with
SSLCACertificatePath), and will expect to find a symlink from .r
to the CRL in PEM format. It is up to you to ensure an in-date CRL is
available at that location. This hash can be generated like so:
hash=openssl crl -hash -in $file -noout
ln -sf $file $hash.r0
SSLUseCRL
Check all certificates in the client certificate chain instead of just
the final one.
SSLCRLCheckAll
Allow revoked certificates through, but set an environment variable (to YES)
SSLOnRevocationSetEnv SSL_REVOKED
Allow a certificate with an expired CRL through, but set an environment
variable (to YES). Note that with this unset, the error returned is
certificate expired (TLS doesn’t have an error for CRL expired! Doh!)
SSLOnCRLExpirySetEnv SSL_CRL_EXPIRED
Allow a certificate with no CRL through, but set an environment variable
(to YES)
SSLOnNoCRLSetEnv SSL_NO_CRL
If you have enabled client cert exports (in buff.h) you need to use
SSLExportClientCertificates to enable them. Note that the server still has to
mess about with certs even if this is disabled (and exports are enabled)
because the cert chain is received before we can know whether it is needed or
not.
Export client certificates and the certificate chain behind them to CGIs.
The certificates are base 64 encoded in the environment variables
SSL_CLIENT_CERT and SSL_CLIENT_CERT_CHAIN_n, where n runs from 1 upwards.
#<Location /cgi-bin/>
Translate the client X509 into a Basic authorisation. This means that the
standard Auth/DBMAuth methods can be used for access control. The user name
is the “one line” version of the client’s X509 certificate. Note that no
password is obtained from the user. Every entry in the user file needs this
password: xxj31ZMTZzkVA. See the code for further explanation.
SSLFakeBasicAuth
List the ciphers that the client is permitted to negotiate. See the source
for a definitive list. For example:
#SSLRequiredCiphers RC4-MD5:RC4-SHA:IDEA-CBC-MD5:DES-CBC3-SHA
These two can be used per-directory to require or ban ciphers. Note that (at
least in the current version) Apache-SSL will not attempt to renegotiate if a
cipher is banned (or not required).
You should probably at least ban the null encryption ciphers.
#SSLRequireCipher
#SSLBanCipher NULL-MD5:NULL-SHA
A home for miscellaneous rubbish generated by SSL. Much of it is duplicated
in the error log file. Put this somewhere where it cannot be used for symlink
attacks on a real server (i.e. somewhere where only root can write).
Don’t use this anymore! Now everything is logged in the error log.
#SSLLogFile /var/log/apache-ssl/ssl.log
Custom logging
CustomLog /var/log/apache-ssl/ssl.log “%t %{version}c %{cipher}c %{clientcert}c”
Watch what’s going on
#TransferLog /var/log/apache-ssl/transfer.log
these are just examples on how some SSL directives might be used.
(adapted from the original httpd.conf file provided by Ben Laurie)
#<Directory /<path_to_some_dirs>>
This directive forbids access except when SSL is in use. Very handy for
defending against configuration errors that expose stuff that should be
protected
SSLRequireSSL
Conversely, you can forbid SSL with…
SSLDenySSL
This directive disable SSL for a specific virtualhost
#SSLDisable
Conversely, you can enable it with…
#SSLEnable
If you want, you can disable SSL globally, and enable it in a virtual host…
#SSLDisable
SSLEnable
Automatically added by the post-installation script
as part of the transition to a config directory layout
similar to apache2, and that will help users to migrate
from apache to apache2 or revert back easily
Include /etc/apache-ssl/conf.d
