Pas de connexion wifi sur stretch
Bonsoir
J’ai un gros souci de connexion wifi sur debian stretch
J’ai bien installé le pilote firmware-misc-nonfree_20161130-2_all.deb
Pour Stretch
Je vois bien ma freebox ains que mes voisins mais je ne peux me connecter
Sur débian Jessie pas de soucis , je souhaiterais rester en Stretch si possible
Le réseau filaire fonctionne trés bien
La clé wifi usb est bien reconnu par le noyau
J’ai passé beaucoup de temps à essayer de comprendre avant de poste ce message
Merci pour votre aide
Olivier
authenticating
Feb  7 19:03:36 debian kernel: [ 8755.824066] wlx0008d338129a: aborting authentication with f4:ca:e5:c2:12:b4 by local choice (Reason: 3=DEAUTH_LEAVING)
Feb  7 19:03:36 debian wpa_supplicant[575]: wlx0008d338129a: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="freebox_VQLIHU" auth_failures=2 duration=20 reason=CONN_FAILED
Feb  7 19:03:36 debian NetworkManager[538]: <info>  [1486490616.4034] device (wlx0008d338129a): supplicant interface state: authenticating -> disconnected
Feb  7 19:03:39 debian NetworkManager[538]: <warn>  [1486490619.5458] device (wlx0008d338129a): Activation: (wifi) association took too long, failing activation
Feb  7 19:03:39 debian NetworkManager[538]: <info>  [1486490619.5459] device (wlx0008d338129a): state change: config -> failed (reason 'ssid-not-found') [50 120 53]
Feb  7 19:03:39 debian NetworkManager[538]: <warn>  [1486490619.5465] device (wlx0008d338129a): Activation: failed for connection 'Auto freebox_VQLIHU'
Feb  7 19:03:39 debian NetworkManager[538]: <info>  [1486490619.6036] device (wlx0008d338129a): state change: failed -> disconnected (reason 'none') [120 30 0]
Feb  7 19:03:39 debian kernel: [ 8759.059678] IPv6: ADDRCONF(NETDEV_UP): wlx0008d338129a: link is not ready
Feb  7 19:03:39 debian NetworkManager[538]: <info>  [1486490619.7090] device (wlx0008d338129a): set-hw-addr: set MAC address to C2:07:2C:72:05:4C (scanning)
Feb  7 19:03:39 debian kernel: [ 8759.243129] IPv6: ADDRCONF(NETDEV_UP): wlx0008d338129a: link is not ready
Feb  7 19:03:40 debian NetworkManager[538]: <info>  [1486490620.9234] device (wlx0008d338129a): supplicant interface state: disconnected -> inactive
Quel noyau utilises-tu?
Bonsoir
Le noyau est 4.7.0.1-amd64
Ça doit faire un bout de temps que tu n’as pas fait de MàJ alors…, si tu es en Stretch.
je vais essayer un dist-upgrade
j’ai fait l’installation cet après midi
upgrade uniquement
Prends tes précautions avec le dist-upgrade et fais notamment attention aux éventuels paquets qui seront proposés pour suppression, Stretch est en phase de freeze, mais elle fait encore partie de Testing…
Par ailleurs en faisant un dist-upgrade tu as de grandes chances de passer au noyau 4.9, et il y a quelques bugs notamment pour le wifi dont je fais également les frais en ce moment.
4.9.0.1 amd64 à présent
Mais toujours pas de connexion
Bonne soirée
Olivier
Bonjour à tous
J’ai vraiment besoin d’aide
Je bloque totalement
Je vous remercie
Olivier
Essayer de créer un nouvel utilisateur puis, après déconnexion, tester dans la session de ce nouvel utilisateur. Sait-on jamais…
Merci je vais essayer
Bonne journée
olivier
C 'est fait mais toujours pareil
profil créé avec droits admin
Bon ok reprenons depuis le début,
Comment vois-tu ta freebox et tes voisins? À l’aide d’une commande en terminal ou bien au travers de Network-Manager?
C’est à dire? Avec les droits “root”? Si c’est le cas alors c’était pas une bonne idée et il faut supprimer ce compte.
Enfin peux tu nous donner les retours des commandes suivantes :
# lspci | grep Network
# dmesg
# systemctl status wpa_supplicant
# journalctl -u wpa_supplicant
Je vois mes voisins avec Network-Manager
j’ai créé un profil avec droits administrateur
j’ai réinstallé la jessie tout fonctionne bien à présent
je vais attendre un peu avant de réinstaller debian stretch
Certainement un bug
pas encore trés stable je pense
Merci beaucoup pour votre aide
bonne soirée
olivier
