voici mon fstab le lecteur disquette et cdrom ont étés commentés
[code]# /etc/fstab: static file system information.
Use ‘vol_id --uuid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
proc /proc proc defaults 0 0
/ was on /dev/hda1 during installation
UUID=cb7aa6d0-acf2-40d0-b3aa-4c4881074544 / ext3 errors=remount-ro 0 1
/home was on /dev/hda2 during installation
UUID=0dc222af-5d8b-40ee-9fdc-6510d9f20fb2 /home ext3 defaults 0 2
swap was on /dev/hda3 during installation
UUID=f9d7d241-fc29-4378-a25c-9294f831acff none swap sw 0 0
#/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
#/dev/fd0 /media/floppy0 auto rw,user,noauto 0 0
/home/dvd/iso/debian-testing-i386-DVD-1.iso /home/dvd/dvd1 udf,iso9660 user,loop 0 0
Et les entrées syslog quand un disque dur USB est connecté
Jun 25 16:01:40 debian kernel: [ 705.516114] usb 1-1: new full speed USB device using uhci_hcd and address 6
Jun 25 16:01:41 debian kernel: [ 705.675176] usb 1-1: New USB device found, idVendor=067b, idProduct=2506
Jun 25 16:01:41 debian kernel: [ 705.675183] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 25 16:01:41 debian kernel: [ 705.675189] usb 1-1: Product: Mass Storage Device
Jun 25 16:01:41 debian kernel: [ 705.675194] usb 1-1: Manufacturer: Prolific Technology Inc.
Jun 25 16:01:41 debian kernel: [ 705.675199] usb 1-1: SerialNumber: 00
Jun 25 16:01:41 debian kernel: [ 705.675383] usb 1-1: configuration #1 chosen from 1 choice
Jun 25 16:01:41 debian kernel: [ 705.684083] scsi6 : SCSI emulation for USB Mass Storage devices
Jun 25 16:01:41 debian kernel: [ 705.684471] usb-storage: device found at 6
Jun 25 16:01:41 debian kernel: [ 705.684475] usb-storage: waiting for device to settle before scanning
Jun 25 16:01:46 debian kernel: [ 710.685397] usb-storage: device scan complete
Jun 25 16:01:46 debian kernel: [ 710.721401] scsi 6:0:0:0: Direct-Access ST940815 A 3.AL PQ: 0 ANSI: 0
Jun 25 16:01:46 debian kernel: [ 710.736230] sd 6:0:0:0: [sdb] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
Jun 25 16:01:46 debian kernel: [ 710.741369] sd 6:0:0:0: [sdb] Write Protect is off
Jun 25 16:01:46 debian kernel: [ 710.741378] sd 6:0:0:0: [sdb] Mode Sense: 03 00 00 00
Jun 25 16:01:46 debian kernel: [ 710.741384] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Jun 25 16:01:46 debian kernel: [ 710.754354] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Jun 25 16:01:46 debian kernel: [ 710.757543] sdb: sdb1
Jun 25 16:01:46 debian kernel: [ 710.794157] sd 6:0:0:0: [sdb] Assuming drive cache: write through
Jun 25 16:01:46 debian kernel: [ 710.798281] sd 6:0:0:0: [sdb] Attached SCSI disk
Jun 25 16:02:07 debian kernel: [ 732.264149] usb 1-1: USB disconnect, address 6
