Mon imprimante Epson (3 en 1) DX 9400F est bien reconnue pour l’impression mais impossible de scanner avec. Xscan indique qu’il n’a pas trouvé de matériel.
Distrib. : Linux PC-Bureau 2.6.30-2-amd64 #1 SMP Fri Sep 25 22:16:56 UTC 2009 x86_64 GNU/Linux
PC-Bureau:/home/patrick# sane-find-scanner
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x04b8, product=0x083a) at libusb:002:009
found USB scanner (vendor=0x147a [Formosa21], product=0xe018 [Beanbag Emulation Device]) at libusb:002:007
found USB scanner (vendor=0x15a9 [Ralink], product=0x0004 [802.11 bg WLAN]) at libusb:001:002
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
PC-Bureau:/home/patrick# scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
Merci pour votre aide.
Hello
J’avais bien pensé à ce lien mais il ne comprend pas la 9400F
J’avais trouvé ceux-ci
avasys.jp/eng/linux_driver/
nabble.com/epson-cx-9400fax(all-in-one-scanner-not-detected-td24039653.html
Mais n’ayant jamais été confronté à la situation, je n’ai pu aider plus !
Des retours ?
Cyrille
[quote=“Cyrilleb”]Hello
Des retours ?
Cyrille[/quote]
Oui, à tester
avasys.jp/lx-bin2/linux_e/spc/DL2.do
attention avec squeeze, problème de boot possible
avasys.jp/eng/linux_driver/faq/id000623.php
Au fait tu as bien ajouter ton user au groupe scanner ?
J’ai essayé d’aller sur Avasys mais, au moment de télécharger le driver pour le scan, il indique, sur le site, qu’il ne faut pas l’installer car il y a des problèmes de boot. Dommage …
Oui, j’ai bien ajouté mon user. Donc, ça ne vient pas de ça.
Merci quand même.
J’ai tout fait ce que vous m’aviez conseillé et ce que j’ai lu mais ça reste inexorablement infructueux !
Avasys ne fonctionne pas avec le 9400F et les autres manips de fichiers non plus. L’autre jour, j’y suis arrivé sans trop savoir comment et là, depuis que je me suis mis sous squeeze/sid, c’est à nouveau ce message aucun matériel détecté à l’ouverture de Xsane !
Help !
tu t’es bien mis dans le groupe scanner ?
Oui, m’sieur Cyrille, c’est l’une des premières choses que je fis.
Par contre, qq part, j’ai lu qu’on pouvait aussi configurer les libsane et autres libsane-extras. Qu’en est-il ?
Bon, en fait, je me suis lancé et j’ai installé le paquet avasys - iscan. Et là, tout fonctionne avec epkowa. Par contre, au démarrage, j’ai le choix entre deux chemins pour mon scan “epson2:lib …” qui plante et “epkowa: …” qui fonctionne très bien. Comment ôter la première possibilité sur ces deux ? C’est pas handicapant mais ça gêne un peu. J’ai lu la réponse il y a quelques jours mais je ne retrouve pas trace de ça.
Bon, eh bien, j’ai trouvé tout seul, d’abord !
Edition de /etc/sane.d/dll.conf
et # devant epson et epson2 et le tour est joué.
ça roule impec. Je scanne comme je veux ! Tu 'rends compte ?
Merci quand même à tous ceux qui m’ont aidé.
Pour faire fonctionner un scanner epson sur debian il suffit de télécharger iscan sur leur site de support : http://download.ebz.epson.net/dsc/search/01/search/searchModule
Recherchez le driver en mettant le nom de votre imprimante, téléchargez-le, décompressez le fichier, ouvrez iscan-bundle, installez en 1er iscan-data, puis iscan, puis iscan network (si nécessaire) et tout fonctionne sans soucis.
PS : çà serait bien de faire un tuto là-dessus, non ?
2 commandes utiles
sane-find-scanner et scanimage -L
ca m’a servi pour mon imprimante Canon Pixma MG3650
