J’ai mis mon Debian à jour hier soir et, depuis, je n’ai plus de son. Pourtant, quand je teste sur mplayer ou vlc, je n’ai aucun message d’erreur, et speaker-test fonctionne. Je vous rassure, le son n’est pas coupé, et je le prouve :
# amixer -c 0 get Master
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined penum
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 37 [58%] [-20.25dB] [on][/code]
Voici les informations qui me semblent pertinentes, et excusez-moi si j'en oublie.
[code]# uname -a
Linux queneau 3.2.0-4-amd64 #1 SMP Debian 3.2.41-2 x86_64 GNU/Linux[/code]
[code]# lspci -v|grep -A9 Audio
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
Subsystem: Dell Device 0410
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at f5460000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel[/code]
[code]# alsactl init
Found hardware: "HDA-Intel" "Intel IbexPeak HDMI" "HDA:111d7605,10280410,00100104 HDA:80862804,80860101,00100000" "0x1028" "0x0410"
Hardware is initialized using a generic method[/code]
[code]# lsmod|grep snd
snd_hda_codec_hdmi 30824 1
snd_hda_codec_idt 53792 1
snd_hda_intel 26259 0
snd_hda_codec 78031 3 snd_hda_intel,snd_hda_codec_idt,snd_hda_codec_hdmi
snd_hwdep 13186 1 snd_hda_codec
snd_pcm_oss 41081 0
snd_mixer_oss 17916 1 snd_pcm_oss
snd_pcm 68083 4 snd_pcm_oss,snd_hda_codec,snd_hda_intel,snd_hda_codec_hdmi
snd_page_alloc 13003 2 snd_pcm,snd_hda_intel
snd_seq_midi 12848 0
snd_seq_midi_event 13316 1 snd_seq_midi
snd_rawmidi 23060 1 snd_seq_midi
snd_seq 45126 2 snd_seq_midi_event,snd_seq_midi
snd_seq_device 13176 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 22917 2 snd_seq,snd_pcm
snd 52889 12 snd_timer,snd_seq_device,snd_seq,snd_rawmidi,snd_pcm,snd_mixer_oss,snd_pcm_oss,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_idt,snd_hda_codec_hdmi
soundcore 13065 1 snd[/code]
[code]# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: STAC92xx Analog [STAC92xx Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: Intel [HDA Intel], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
Subdevice #0: subdevice #0[/code]
[code]# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=Intel
HDA Intel, STAC92xx Analog
Default Audio Device
sysdefault:CARD=Intel
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=Intel,DEV=0
HDA Intel, HDMI 0
HDMI Audio Output
hdmi:CARD=Intel,DEV=1
HDA Intel, HDMI 1
HDMI Audio Output[/code]
[code]# cat /proc/asound/cards
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xf5460000 irq 44[/code]
[code]# cat /dev/urandom > /dev/audio
[bruit horrible]
^C
J’ai fait tous les forums et je n’ai rien trouvé. J’ai désinstallé et réinstallé ALSA, j’ai testé avec et sans pulseaudio.
Merci d’avance pour votre aide !
