Pas de son
Salut a tous,
J’ai pasde son.
Il me semble qu’il y a un conflit avec ma carte son integré, et ma carte de son pci.
voila un petit lspci:
e101mk2@debian:~$ lspci
00:00.0 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:00.5 PIC: VIA Technologies, Inc. K8M890CE I/O APIC Interrupt Controller
00:00.6 Host bridge: VIA Technologies, Inc. Device 6290
00:00.7 Host bridge: VIA Technologies, Inc. K8M890CE Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI bridge [K8T800/K8T890 South]
00:02.0 PCI bridge: VIA Technologies, Inc. K8T890 PCI to PCI Bridge Controller
00:0f.0 RAID bus controller: VIA Technologies, Inc. VT8251 AHCI/SATA 4-Port Controller
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 90)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8251 PCI to ISA Bridge
00:11.7 Host bridge: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 7c)
00:13.0 PCI bridge: VIA Technologies, Inc. VT8251 Host Bridge
00:13.1 PCI bridge: VIA Technologies, Inc. VT8251 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
02:00.0 VGA compatible controller: ATI Technologies Inc RV410 [Radeon X700]
02:00.1 Display controller: ATI Technologies Inc Device 5e6f
04:01.0 Audio device: VIA Technologies, Inc. VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller)
05:09.0 Class ffff: Network Appliance Corporation Device 5880 (rev 02)
Je suis sous alsa, eclairez ma lanterne, j’ai testez le 2 carte son, et aucune fonctionne, si vous avait besoin d’autre info, n’ésitez pas.
Merci de votre aide.
Question bête : as-tu désactivé au préalable ta carte son intégrée dans le BIOS ? :slightly_smiling:
Je ne pense pas, vue que mon frere utilise la carte son integré (sur son windaube). Jusqu’a present j’utilisez la carte son externe, vue qu’elle etait trés bien reconnu.
Sauf qu’un jour, je n’ais plut de son!
Oki… Dans ce cas, est-ce que tu as essayé de reconfigurer simplement une des deux cartes avec alsaconf ? Peut-être qu’une mise à jour récente a modifié ton fichier de configuration sans que tu n’y fasses gaffe.
Ce qui me semble bizarre, par contre, c’est que si mes lunettes ne m’induisent pas en erreur, on ne voit que ton chipset son intégré sur la sortie de ton lspci.
Aprés quelque magouille, j’ai réussit.
Seul dieux c’est comment j’ai fait, mais j’ai réussit!
