bonsoir ,
ok , j’ai je crois trouvé la référence du noyau : bpo.4-amd64 ;
ceci dit impossible de le mettre en place : ci joint le script :
[size=50][size=85]debian:/home/user# aptitude -t backports install linux-image-2.6.32-x-bpo.4-amd64
Lecture de l’information d’état étendu
Initialisation de l’état des paquets… Fait
Lecture des descriptions de tâches… Fait
Impossible de trouver un paquet dont le nom ou la description correspond à « linux-image-2.6.32-x-bpo.4-amd64 »
bsh{u} bsh-gcj{u} capplets-data{u} cdrdao{u} cheese{u} deskbar-applet{u} desktop-file-utils{u}
dmz-cursor-theme{u} dvd+rw-tools{u} ekiga{u} eog{u} evince{u} evolution-data-server{u}
evolution-data-server-common{u} evolution-webcal{u} fast-user-switch-applet{u} file-roller{u} finger{u}
gcalctool{u} gconf-editor{u} gdm{u} gdm-themes{u} gedit{u} gedit-common{u} gnome-about{u}
gnome-backgrounds{u} gnome-cards-data{u} gnome-control-center{u} gnome-desktop-data{u} gnome-games{u}
gnome-games-data{u} gnome-media{u} gnome-media-common{u} gnome-menus{u} gnome-netstatus-applet{u}
gnome-nettool{u} gnome-network-admin{u} gnome-panel{u} gnome-panel-data{u} gnome-power-manager{u}
gnome-screensaver{u} gnome-session{u} gnome-settings-daemon{u} gnome-spell{u} gnome-system-tools{u}
gnome-themes{u} gnome-themes-extras{u} gnome-user-guide{u} gnome-utils{u} gnome-vfs-obexftp{u}
gnome-volume-manager{u} gnuchess{u} gstreamer0.10-gnomevfs{u} gstreamer0.10-tools{u} gtk2-engines{u}
gtk2-engines-pixbuf{u} gtkhtml3.14{u} gucharmap{u} guile-1.8-libs{u} libao2{u} libapm1{u} libavahi-ui0{u}
libblas3gf{u} libbluetooth2{u} libdmx1{u} libebook1.2-9{u} libecal1.2-7{u} libedata-book1.2-2{u}
libedata-cal1.2-6{u} libedataserverui1.2-8{u} libegroupwise1.2-13{u} libepc-1.0-1{u} libepc-ui-1.0-1{u}
libexchange-storage1.2-3{u} libgalago3{u} libgda3-3{u} libgda3-common{u} libgdata-google1.2-1{u}
libgdata1.2-1{u} libgdl-1-0{u} libgdl-1-common{u} libgfortran3{u} libggz2{u} libggzcore9{u} libggzmod4{u}
libgksu1.2-0{u} libgksuui1.0-1{u} libgnome-media0{u} libgnome-pilot2{u} libgnome-window-settings1{u}
libgnomecups1.0-1{u} libgnomekbd-common{u} libgnomekbd2{u} libgnomekbdui2{u} libgnomeprint2.2-0{u}
libgnomeprint2.2-data{u} libgnomeprintui2.2-0{u} libgnomeprintui2.2-common{u} libgnomevfs2-bin{u}
libgpgme11{u} libgpod3{u} libgtk-vnc-1.0-0{u} libgtkhtml3.14-19{u} libgtksourceview-common{u}
libgtksourceview1.0-0{u} libgtksourceview2.0-0{u} libgtksourceview2.0-common{u} libgucharmap6{u}
libgweather-common{u} libgweather1{u} libhsqldb-java{u} libhsqldb-java-gcj{u} libhtml-parser-perl{u}
libhtml-tagset-perl{u} libhtml-tree-perl{u} libjaxp1.3-java{u} libjaxp1.3-java-gcj{u} libjline-java{u}
libkpathsea4{u} liblapack3gf{u} liblircclient0{u} libmetacity0{u} libmtp7{u} libnautilus-burn4{u}
libnet-dbus-perl{u} liboobs-1-4{u} libopal-2.2{u} libopenobex1{u} libpisock9{u} libpisync1{u}
libpt-1.10.10{u} libpt-1.10.10-plugins-alsa{u} libpt-1.10.10-plugins-v4l{u} libpth20{u} libsdl1.2debian{u}
libsdl1.2debian-alsa{u} libservlet2.4-java{u} libslab0{u} libspectre1{u} libspeexdsp1{u}
libsuitesparse-3.1.0{u} libsvga1{u} libtrackerclient0{u} libvorbisfile3{u} libwww-perl{u}
libxerces2-java{u} libxerces2-java-gcj{u} libxklavier12{u} libxml-parser-perl{u} libxml-twig-perl{u}
lp-solve{u} metacity{u} metacity-common{u} nautilus{u} nautilus-cd-burner{u} nautilus-data{u}
openoffice.org-calc{u} openoffice.org-draw{u} openoffice.org-impress{u} openoffice.org-math{u} p7zip{u}
pkg-config{u} python-4suite-xml{u} python-eggtrayicon{u} python-gdata{u} python-gdbm{u} python-gmenu{u}
python-gnome2-desktop{u} python-gnome2-extras{u} python-gst0.10{u} python-gtkhtml2{u}
python-gtkmozembed{u} python-gtksourceview2{u} python-notify{u} python-sexy{u} python-xdg{u} rhythmbox{u}
seahorse{u} serpentine{u} sound-juicer{u} svgalibg1{u} swfdec-gnome{u} system-config-printer{u}
system-tools-backends{u} totem-common{u} totem-gstreamer{u} totem-mozilla{u} totem-plugins{u}
transmission-common{u} transmission-gtk{u} ttf-liberation{u} unzip{u} vinagre{u} vino{u} zenity{u} zip{u}
0 paquets mis à jour, 0 nouvellement installés, 196 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0o d’archives. Après dépaquetage, 538Mo seront libérés.
Voulez-vous continuer ? [Y/n/?] n
Abandon.
debian:/home/user#[/size][/size]
Je pense que je vais stopper avec debian : Ubuntu avait tout configuré correctement au départ . J’ ai voulu changé pour la stabilité vantée sur plusieurs sites . Ma petite expérience de Mandriva datant de 4 ans ne m’a pas posé autant de soucis .
J’ai investi dans une config récente : Micro AMD Athlon 4 coeurs , 4 ghz de ram ,… pour faire du multimédia ( audio , divx , dvd , photos …) et malheureusement je doute de cette distribution pour mon besoin .
je suis en dual boot avec XP . je vais peut etre garder ce systeme en ajoutant ubuntu ou mandriva sur une autre partition .
Merci encore pour votre aide et disponibilité.
Peut etre reviendrai je tres vite pour essayer de comprendre .
A bientot donc .
